Brightest single 18650 edc flashlight now is??
101 posts / 0 new
vresto
vresto's picture
Last seen: 1 hour 23 min ago
Dales quad X6 xpls? or? iam lost in it…probably the brightest will be 26650 flashlights no?
EDC- Jetbeam E40R,Emisar D4V2 XPLHI
Headlamp-Thrunite th30
Lexel
Lexel's picture
Last seen: 41 min 41 sec ago
26650 high drain cells can push a quad harder than the best 18650
Also more mass is better as you deal with a shitload of heat
XPL W2, XML U4 or XPL2 V6 should give an impressive amount of lumens
Rufusbduck
Rufusbduck's picture
Last seen: 10 months 2 weeks ago
Lumens or Lux, stock light or mod?
Scott
vresto
vresto's picture
probably the modded one will be much brighter:))
DB Custom
DB Custom's picture
Last seen: 11 hours 32 min ago
And a top 32650 can do more than a top 26650, but the original question was about a single 18650 so, given that, I’d say a quad X6 at some 4200+ lumens with Nichia 219C 5000K emitters and an LG HE4 at 21A draw at the tail would be the most I’ve seen.
For lux, somewhere in the 170-200Kcd range is probably about the highest from a single 18650. Modding can push that considerably further, I’ve seen a de-domed XP-G2 in a Convoy S2 mounted under a 6” diameter Ledil Sienna making well over 500Kcd. There are a lot of possibilities, especially if an aspheric is brought into the picture. There are some fairly largish aspheric lights that use 2 18650’s, these can be modified with an FET driver and a dummy cell to make very nice throw numbers as well.
A stock Nitecore P30 is a nice thrower, illuminating a barn at 610 yds fairly well even though quite underpowered with only 1000 lumens.
Probably something I’m forgetting, surely someone knows of some other options… Wink
papaslightsaber
papaslightsaber's picture
Last seen: 2 years 1 month ago
I’m not exactly sure, but I did just get a quad XP-L drop in with a nice tail switch from modder Vinh, and now waiting for my Solarforce host to arrive tomorrow. Looking forward to testing lumens once I get this light setup.
For the price… maybe the Astrolux S41 4x xp-g2 and it’s Manker equivalent. $40. all in.
Jerommel
Jerommel's picture
Last seen: 2 days 6 hours ago
Wouldn’t the S41 with XP-G3 be brighter?
Lower Vf and more efficient LED than XP-G2, isn’t it?
papaslightsaber
You’re right. It’s probably the better of the two. I read somewhere about the tint of XP-g3 being like off, and then a couple negative tidbits and I got dismissive. Actually, that’s just what happens when you base assumptions on small amounts of information. Thanks for the correction. I still have yet to get my hands on any XP-G3 light.
Jerommel
Jerommel's picture
With the tiny TIRs it’s a fairly even tinted flood.
light junkie
light junkie's picture
Last seen: 6 months 1 week ago
U have a Rochester as31 modded by Tome pumping out over 1700+lumens with a xml2-u4 emitter I don’t remember the lux reading off the top of my head but estimated a throw in the neighborhood of 400 meters.
Lj
Danglerb
Last seen: 1 year 3 months ago
Seems like we are bumping into cell amp limits and device heat dissipation, maybe waiting on next gen LED or cells for much of a bump.
I’ll take a guess the next step will be in better optics.
Still a bit dim
vresto
vresto's picture
i guess,xplhi in quad have to by the highest lumens firestarter…nichias,xpgs,xmls are just less no?
lionheart_2281
lionheart_2281's picture
Last seen: 22 hours 54 min ago
Vinh made a 4000 lumen S41S, probably LED lumens I guess?
leaftye
Last seen: 2 weeks 13 hours ago
Key words? XP-G3 and XP-L/XP-L2 should be brighter, but you haven’t personally seen that yet?
I love that we’re building single 18650 lights that outperform modded SRK’s from a few years ago. We used to get excited about an honest 3000 lumens in a soda can light, and now we can fit that in a pocket.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
kramer5150
kramer5150's picture
Last seen: 3 weeks 2 days ago
Curious… Why are there no multi-die XHP emitter options? Is it the 6-12 Vf ?
mrheosuper
Last seen: 4 days 5 hours ago
you know, we can build Quad Xp-l2(over 1500 lumen)
that mean 6000 lumen in the pocket
Forgot my pen
DB Custom
DB Custom's picture
XP-G3 doesn’t make a nice beam, even under optics. Nichia 219C has a low Vf, allows for a great pull and output. Haven’t really gotten enough of the XP-L W2 emitters on hand at one time to find out what it’d do in a quad, except for in my 18350 Ti/Cu Quad and there they didn’t fare so well, not enough cell to provide for em.
I’ve done a Quad XHP-50 that made over 7000 lumens, maybe more, don’t remember exactly, what I DO remember is that it heated up the X6 in about 20 seconds to the point of burn level. I put 3 XHP-70’s in a BTU Shocker for up to nearly 15,000 lumens on a pair of 18650’s. 3 PF’s took it to about 20,000 lumens but it was killing traces on the spring pcb. I beefed up the pcb but never tried it again after that.
I have more of the XP-L W2 1D on the way from AlliExpress, never got the situation with Cutter resolved, they quit talking to me. So I’ve got V6 1A’s where I ordered W2 2B’s. (W2’s are XP-L2 with the smaller dome)
leaftye
Short bursts are perfect for me. It’s enough to blast through the coolant to see if a tool is still there, or to see if that critter is a skunk or not. It may not be able to stay on as long as a big light, but like cameras, the best one is what you have. It’s rare when I’m carrying one of my big lights, but I almost always have a 1×18650 light in my pocket.
BrianK
Yup, I suspect that the way most folks use these hot rod lights. I know that’s how I use them with the majority of my shining pleasure being at the lower output levels. I even use the L6 that way.
DB Custom
DB Custom's picture
Normal use is like that, day to day, but on Thursday night I blast away for 10 – 15 minutes on my weekly walk to the road with the trash can. Smile “Fire in the HOLE!” Big Smile
Stereodude
Last seen: 1 month 4 weeks ago
You must melt a lot of holes in your trash cans. Innocent
light junkie
Well i know Tom E went with an xml2 u4 over a xplhi or xplv6 becuase it has more out put at the emitter and it is really up by here as far as throw Lost up to my modded maxtoch sniper as far as throw if that counts for anything.
Lj
vresto
vresto's picture
iam crazy……xml2 are brighter than xpl?? xpl are after all newest….and xpl-hi more newest no??:))
Jerommel
Jerommel's picture
Waiting for XP-L2 HI Smile
DB Custom
DB Custom's picture
For absolute small emitter output, the XP-L W2 2B in a Convoy C8 is pretty ridiculous at some 2024 lumens. This is single cell, single emitter.
The XP-L and XM-L2 use the same die, sitting on a different substrate, so they are very similar in output. There have been some small changes and as such the XP-L can sometimes take more current but that is not in and of itself always the best path to the most lumens.
Nice entertaining the possibilities of the XP-L2, acquiring the emitters is not as easy as all that at this time.
light junkie
Brighter,yes less throw you can look up flashlight Wiki xpl hi has a concentrated beam the xml2-u4 is the highest xml2 bin
Lj
DB Custom
DB Custom's picture
There is a phenomenon where de-doming an XM-L2 (or any Cree for that matter) causes a loss of lumens and a warming of the tint. The XP-L HI is, more or less, factory de-domed. The HI has lower output than it’s equivalent HD brother, so this being a given then yes, the XM-L2 is typically brighter than an XP-L. There are changes to the XP-L line-up that are causing it to catch up though, like the XP-L W2 or the XP-L2 maybe they’re calling it. I’ve seen this emitter make over 2000 lumens, where the most I’ve seen from an XM-L2 is 1811.
Variance abounds. The best emitters can be (read usually are) difficult to obtain.
light junkie
Thanks Dale I wasn’t aware of a xpl 2 yet , but could probably wrong. I think a and I better double check but in manker u21 that Tom E saved for may have a xpl2 but don’t quote me yet on it i have to go through piles of pms either that is grateful info and iam happy with my new edc Tom built for me my manker with a 1000 meter reach pmeantu of usable spill I’ll be happy for quite a while.
Lj
vresto
vresto's picture
i open this thread again:) is it now emisar d4?:)
patmurris
patmurris's picture
Last seen: 4 days 17 hours ago
Just came across this early 2017 thread… and yes it seems to me the D4 is the brightest stock single 18650 light around – be it for a few seconds. The XPL version does 4k+ i think.
djozz
djozz's picture
Last seen: 7 hours 20 min ago
I re-measured my D4 with Luxeon V’s yesterday and got 5200 at start, 4850 at 12 seconds when thermal stepdown starts (on a 30Q), and my djozz-lumen even is conservative compared to the lumens on the other side of the pond.
Do I win?
