Workshop and machinery mods and tips,
124 posts / 0 new
lostheplot
lostheplot's picture
Last seen: 1 week 1 day ago
I was thinking it would be good to share our little tricks and mods we do in the workshop
this can be as simple or complex as you please.
Or even a link to something interesting.
and as always please stay on topic..
*Disclaimer carry out any modifications at your own risk
always think of safety before using machinery…!
sorry all images down
thanks photobucket
Edited by: lostheplot on 01/02/2017 - 21:11
lostheplot
Ok I will throw up todays little mod
my lathe has a 38 mm (11/2”) hollow spindle and the 3jaw chuck has a 39 mm hole
behind where the chuck fits there is a large Morse taper which starts at 45 mm id
here is the chuck stripped down remember to mark the pieces for orientation..
I then bored the empty shell to 45mm.(1 3/4”)
here we are after cleaning and reassembly the piece of metal in the chuck is 42mm 200mm long
previously this would have sat in front of the chuck face .needing a centre or steadyrest.
Another little mod was my rudimentary milling machine
simply a piece of round bar with a hole for a tool and a vice clamped to the top slide
thanks photobucket
Jerommel
Jerommel's picture
Gotta get me a lathe too…
Only a small one, or just the spinning chuck part would help a lot.
2Q19
Jerommel
Jerommel's picture
Your milling set up looks very effective. Thumbs Up
2Q19
scianiac
scianiac's picture
Last seen: 3 months 15 hours ago
Nothing super clever but I used the super glue trick the other day to thin down some very small parts on the lathe. Was working on a S2+ triple shortie with a 18500 and was really really tight on space. I threw a scrap rod of aluminum in the lathe and faced it, super glued my part to it, hit it with some kicker and was able to cut them down. It was the switch retainer ring and switch/boot spacer. These would be nearly impossible to hold otherwise since they are so thin, and yet I needed to make them even thinner. The retainer ring I was sure the super glue wouldn’t hold due to the small surface area but it held fine. Just hit them with the heat gun to pop them off.
Co-owner/Engineer at STO Flashlights.
lostheplot
Jerommel wrote:
Gotta get me a lathe too… Only a small one, or just the spinning chuck part would help a lot.
a lathe is nice ,but some of the members here do great work with a drill press and a hacksaw blade
I hope they chime in,.
scianiac,,
that is a great tip with the superglue I would never have thought of it..
thanks photobucket
Jerommel
Jerommel's picture
Haven’t got a drill press either.. Smile
I usually mess around with drills and and what not.
But a lathe head can hold a flashlight tube, a drill can’t (without McGyvering).
2Q19
leaftye
Last seen: 2 weeks 4 days ago
It took me a long time to figure that one out. It was because of the saying that lathes can make bigger lathes. The flat parts didn’t make sense for me until I realized a vice could be mounted to the carriage, which make the chuck a toolholder, and the lathe becomes a 2 axis horizontal mill. Your implementation is especially nice since the tool is supported at both ends.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
lostheplot
some lathes have t bolt slots for this purpose (mrs dnf’s has them)
for facing you can mount a tool in the chuck ,handy for tools that are to high just mount them side ways
and take a skim
there are also commercial arrangements available..
https://www.bing.com/images/search?q=lathe+milling+attachment&qpvt=lathe...
thanks photobucket
Rufusbduck
Rufusbduck's picture
Last seen: 1 month 6 days ago
Chime Maple block clamped to drill press table with a hack saw blade attached with screws 1 1/4” oc. It helps to scallop the wood for extra clearance before adding the blade. The work is mounted on any conveneient size drill bit that fits in the chuck by wrapping the bit with tape until it’s snug(largest bit with least amount of tape is best). Farther up the bit the flutes end and you have a true cylinder with minimal wobble. It’s critically important that cuts are kept to the barest minimum as the side loading this method causes can cause a tapered chuck to come loose and do some serious harm. I’ve been using the same blade for various projects for over a year now. I used a 5/8” 2-flute bit for this Sipik mod after using a 1/2” bit wrapped with tape and 180w/d to bore it out for a 16mm cell.
Scott
sedstar
A drill press? is kind of a “must have”, i found out.
even before all this hobby, maybe once a year i needed a drill press, lol.
I bought a BIG old one, that seemed pretty good shape. I bolted the biggest “x-y” table harbor freight has to it… and i use it as a “sort of” milling machine.
it allowed me to do a few facing and other operations i otherwise could not have done. Various budget HS steel cutting bits from harbor freight? never fail to amaze me, i can actually get a decent surface.
in addition to getting a few operations done? It introduced me to machining, and i realized i could use a small lathe, which i eventually bought.
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
Terry White
Terry White's picture
Last seen: 10 months 3 weeks ago
lostheplot wrote:
Jerommel wrote:
Gotta get me a lathe too... Only a small one, or just the spinning chuck part would help a lot.
a lathe is nice ,but some of the members here do great work with a drill press and a hacksaw blade I hope they chime in,. scianiac,, that is a great tip with the superglue I would never have thought of it..
And a Dremel... Can't leave out the Dremel.
Terry White
Skype terrywhite1@live.com
lostheplot
[quote=sedstar]A drill press? is kind of a “must have”, i found out.
keen to see some pictures of your setup and work.
and we wont forget the dremel (mines a Chinese knockoff of a dremel)
thanks photobucket
Terry White
lostheplot][quote=sedstar wrote:
A drill press? is kind of a "must have", i found out. even before all this hobby, maybe once a year i needed a drill press, lol. I bought a BIG old one, that seemed pretty good shape. I bolted the biggest "x-y" table harbor freight has to it... and i use it as a "sort of" milling machine. it allowed me to do a few facing and other operations i otherwise could not have done. Various budget HS steel cutting bits from harbor freight? never fail to amaze me, i can actually get a decent surface. keen to see some pictures of your setup and work. and we wont forget the dremel (mines a Chinese knockoff of a dremel)
We have a coupe of those knock off's in the shop at work. They seem to work just as well as the brand Dremel. One of them is a good deal stronger. It came in a kit with a drill press attachment, a small vice, and a snake hand attachment.
I may get me one of those myself.
Terry White
leaftye
It’s about time I accept that I’ve become too much of a machine snob to use my drill press. In the last couple of years, I’ve only used a drill press once, not including training new guys. If there’s any way I can use a mill, I’ll use that as a fancy drill press every time. The best use I can think of for a drill press is as a sacrificial machine for the kind of people we bought $1-3 flashlights to loan to. That said, if you don’t have access to fancier machinery, a drill press can be a very useful tool.
pinkpanda3310
pinkpanda3310's picture
Last seen: 20 hours 29 min ago
I made up an extension handle for the cross slide on the lathe. It is not fixed, I have to slip it on each time to use it. It made it easier to quickly move the slide or in other cases give me that little bit more control. The reason it’s not fixed is it can foul with the ‘carriage hand wheel handle’ at certain points.
Doing some works (like facing) I got sick of all the winding… check this for a lazy-arse auto feed -
MRsDNF
MRsDNF's picture
Last seen: 1 hour 13 min ago
Nice pp. Smile This is a good thread here with lots of creative novel ideas. Looking forward to seeing and hearing about more. Thumbs Up
Rufusbduck
You don’t need fiberglass cloth to play with epoxy, any old T-shirt or rag will do. You can thin it with a few drops of isopropyl alcohol to get thinner layers, reduce bubbles, and soak into the cloth better.
Scott
lostheplot
nice pp. is that a cut off Vernier for a dro ?.
I didn’t no isopropyl alc thinned epoxy
thanks photobucket
pinkpanda3310
Lol, vernier it is not. It was a cheap set of digital calipers that I modified for the task. Being cheap I’m not worried about it getting swarf and oil all over it. Good for working within cooee and then switch to checking the work with calipers.
I’ll try and keep that epoxy tip in mind but by the time I’ll find a use for it the knowledge will probably have leaked out my ear Steve
Lights-Out
Lights-Out's picture
Last seen: 6 months 3 weeks ago
I stripped down my mini drill press and added a tred mill motor and controller to make it variable speed Smile
LightRider
LightRider's picture
Last seen: 12 months 4 days ago
Any pics!:)
Lights-Out
Let me see if I have any on my phone, if not I’ll post some later
pinkpanda3310
I made up a handle for the lathe spindle. I don’t have a use for it yet so haven’t put it through it’s paces. It’s made from a 20mm concrete expansion anchor and some other bits and pieces. The first time I use it I’ll get a feel for how tight I need to crank it, and if it can withstand the torque etc… I’m hoping it will slip out easily afterwards but if it doesn’t I have a redesign in mind.
Rufusbduck
Works with Devcon 2-ton, JB weld, and wood restorer. Not my idea but I can vouch for it with those three products.
Scott
lostheplot
added dro’s to the lathe cross slide and saddle the small one came from banggood the long one off ebay, look like the same units.
also found these 2 screws loose they hold the nut for the cross slide .may explain some inaccuracy I have been having (perhaps cuased from milling?)routine maintenance I guess.
thanks photobucket
MRsDNF
MRsDNF's picture
You won’t know yourself with the dro. Nice mod.
pinkpanda3310
Nice! A DRO on both axis. I only have one.
Not a mod but an unusual request, I had a work mate ask me to buff up his darts. Using the lathe also made it easier to straighten the bent ones. Here are some before and after shots.
At the owners instruction I didn’t do the body on these ones as he wanted to retain the coating. Just the tip, tail and grooves but I did forget to clean out the rear grooves when I took this pic Facepalm
So by the end I figured all I was doing was cleaning his sticky finger jam off Sick It was a fun little project that didn’t take much time.
pinkpanda3310
I started this a couple weeks ago but didn’t have an 8mm tapper so only finished it this weekend. On my drill press I ground back the mounting point for the depth gauge so it’s flat across the top. I didn’t get a before shot but it was an awful angle that point loaded the nut.
I also added another guide/aligning screw to give it some rigidity and spin true. I wouldn’t say it is perfect now but it’s much better than it was.
MRsDNF
MRsDNF's picture
Whats the two threaded bolts in the main housing for?
pinkpanda3310
That’s the guide/aligning screws (sorry I don’t know the proper terminology). You can see a groove in the spindle shaft (above the chuck when it’s extended down), these screws stop the shaft from rattling around in the main housing. Other (more expensive drills…. yes I cheaped out…..again), have a bolt that clamps the housing around the shaft. This model relied on one screw pushing into the shaft. Now it’s got 2.
Hope I explained it better this time Blushing
