Another little driver that won't be much use to most of you guys
86 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 9 hours 40 min ago
!!! Update April 13, 2017 !!! I need help again. See post #71. I’m trying to re-design my driver board, because I realized it wasn’t going to work. I decided to upgrade to a FET at the same time. I need some help trying to arrange the components on the tiny (now ~11mm) board.
!!! Update January 20, 2017 !!! I added even more vias to the alternate board. The newest alternate board is shown in post #62.
!!! Update January 19, 2017 !!! I added some more vias to the alternate board as Rufusbduck suggested. The newest alternate board is shown in post #59. I guess I need to go back and add vias to the regular driver board as well.
!!! Update January 16, 2017 !!! The latest revision of this driver is in post #47. And, there’s another board in post #50 which is a bit different.
!!! Update January 06, 2017 !!! The newest board design is in post #42 now. All components are within 5.5mm of center so it can be sanded down to 11mm diameter. Just sanding down the OSH Park Edge­­™ will leave you with 12.5mm diameter.
!!! Update in post #29 !!! Sorry, the board in post 29 won’t work. See post 40 from DEL.
Hey guys. I just wanted to post this up in case someone might be interested in it. It’s not for the barn burners. But not everybody wants to light up the whole world at once from a single hand-held device. Sometimes, just a little light is all you might need. Also, since I’m still very new at driver building, let alone driver designing, I’d like somebody who does know a little about this stuff to give me some feedback if ya don’t mind.
So, here we go. The driver outline is 13.28mm, according to OSH Park. Just sand down the OSH Park Edge­­™ to make this a 12.5mm diameter linear LED driver with only a single AMC7135 chip to regulate current for very small flashlights. The MCU is Atmel attiny13a MMU. The resistors R1 and R2 have a 0603 footprint, but 0805 resistors will fit. I used 0805 footprint for both Capacitors C1 and OTC.
I was really hoping to get a simple (old style around here) linear driver down to 11mm if possible, but I haven’t figured out how to squeeze this stuff any tighter, even with using the smaller MMU footprint of the tiny13 MCU. If any of you Eagle Masters wouldn’t mind helping me figure out how to cram this stuff into a tighter space, I would appreciate it. I know putting some components on the other side would work. Two sided drivers as small as 10mm have already been done, but I’m trying to keep this single sided.
I made this driver for (hopefully) modding a little Lux-Pro zoomie I found at Lowe’s a few weeks back. It has a rear clicky switch, and uses four little button cells to directly power a cheap LED. It’ll take some work, but I’m planning to squeeze in some kind of driver (maybe this one) and a better LED, and replace the button cells with a single 10180 Li-Ion to make around 150 LED lumens. Alternatively, I thought about stringing multiple LEDs inside a tube epoxied into the bezel to make a sorta stick light that will be small enough to pocket. With the added efficiency from splitting the current, it might reach close to 200lm output.
Here’s what I’ve got so far:
- The YKK Philosophy
Edited by: DavidEF on 04/13/2017 - 20:26
mattlward
mattlward's picture
Last seen: 2 days 13 hours ago
Wow! That is tiny. And looks good!
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Rufusbduck
Rufusbduck's picture
Last seen: 1 year 6 months ago
Shorter traces save board space so you could eliminate the outside loop and shorten the other trace for the voltage ladder by moving R1/R2 and led + around next to D1. Rotate U1 ~90 clockwise to their previous location. That puts everything connecting to B+ in the same area with a minimum of vias. D1 and C1 could stand to move south and inboard a bit more since you have two traces of separation from the mmu and it can’t be programmed after install there’s no need for clip clearance. You still might need to go to 0603 for the caps as well but this should get you closer.
Scott
Rufusbduck
If that’s still not enough R1/R/2 are the thinnest components if shifted to the bottom and beyond that D1 and both caps can be easily connected to the mcu with vias. Probably need only a small B+ post and pad(3-4mm) with whatever of those parts necessary arranged around it. It might not be necessary. Just start by moving things to minimize trace lengths and blank areas as that’s the acreage you dont have to spare. Continuous ground is only needed on the bottom, just use vias to reach it.
Scott
DavidEF
DavidEF's picture
Thanks RBD! I’ll try moving the resistors around to the other side. I know this driver doesn’t need space for a clip because of the MMU package. I thought about using 0603 Caps, but with my present design, there’s no significant gain in board space. Maybe when I move things around, making smaller pads for the caps will make sense. For the light I have, this driver is the right size already (after removing the OSH Park Edge­­™ ). But, I’d like to cram things in tighter for other lights that don’t have ~13mm of interior space for a driver. If I can make it reducible to ~11mm, that would be nice.
HarleyQuin
HarleyQuin's picture
Last seen: 1 week 3 days ago
Hi DavidEF,
good work, keep it up, and thanks for sharing. Don’t worry whether someone else is nedding it, yet.
Do you really want to use the 20pin MMU (20M1)?
When I tried the MMU, I used the 10pin version (10M1). You have more space on the board and can better use traces under the MMU.
And I really love this OSH Park Edge­­™ remark. You made my day. LOL
@RBD: He does not need to worry about a clip, I know of no clip that can reprog the MMU, the “pins” can hardly be seen at the sides, let alone reached by anything but a fine needle.
And what’s wrong with his number of vias (“with a minimum of vias”), I see 5 GND vias and a BAT+ via, all of them either useful or necessary.
Oshpark Boards:
HQ ProgKey: Universal Driver Programming Key . Boost: HQ 15mm/17mm programmable boost driver with ATtiny13A
46mm Triple-Channel: BLF SRK FET v3 . 17mm Linear: HQ10D / HQ4D / HQ4S . Contact Boards: 22/24/26mm
CRX
CRX's picture
Last seen: 2 weeks 4 days ago
Looks like a good start Thumbs Up
DavidEF
DavidEF's picture
HarleyQuin wrote:
Hi DavidEF,
I don’t really have any attachment to the 20 pin MMU. It’s just that it’s the version available at Mountain. I don’t flash MCU’s so I have to get them where available. Now, if you wanted to sell me some pre-flashed 10-pin MMU’s, I’d change the board for that! Wink I like to have three or four lighting levels starting from low (or moon), mode memory, and no step-down. Big Smile
Texas_Ace
Texas_Ace's picture
Last seen: 4 min 48 sec ago
What size components are those, they look like 0805? I would drop down to 0603 for sure for that driver (except for C1 naturally). You can still use 0805 components on the pads but 0603 is really not hard to work with.
Also, can the tiny13 use the internal voltage reference like the tiny25 so that it could handle LVP without the low voltage divider? That could eliminate the R1/R2 and save a lot of space.
HarleyQuin
Just a proof of concept, obviously vias and ground plane are missing:
outline is 13.2
yellow circle is 12.5
even 11 looks doable with this design
R1, R2, OTC are 0603
C1 is 0805
MCU is the 10pin (10M1)
It’s not like I reenvented the wheel, you’ll find it quite similar to my HQ10D, which itself consists of parts and ideas others were sharing and I did pick up.
Oshpark Boards:
DavidEF
DavidEF's picture
I just looked at the ATtiny13 datasheet. It does have an internal voltage reference, which it says is useful for brownout detection. I don’t know anything about it, other than that. Is the internal voltage reference a yes/no deal? Does it just being there mean that you can use it for LVP, or are there other considerations? Sorry I don’t know anything. Facepalm
HarleyQuin
I see your point with the 20pin MMU. If I start making a fortune by selling pre-flashed MCUs, you be the first to know…
In the meantime
With the 20pin version GND sits differently (which is the least concern). It’s larger. And lot’s of Do-Not-Connects on both sides.
You use Eagle? You might want a custom part stripped of DNC pads so you can use wires under the MCU.
Oshpark Boards:
DavidEF
DavidEF's picture
outline is 13.2
C1 is 0805
Is there going to be a problem with the MCU because of the back/bottom GND plate not being soldered down?
Texas_Ace
Texas_Ace's picture
I have no idea what is needed either, only that it apparently works lol.
Since I do not see this driver being used in anything but a 1S setup using an internal voltage reference should work well.
HarleyQuin
Only if the MCU produces more heat than the package can dispose of without the soldered back. I can’t find anything substantial in the datasheet. But I truly assume that, as our Attiny13A are in sleep mode almost all the time, that it will work fine without the added heatbridge.
Oshpark Boards:
DavidEF
DavidEF's picture
You’re probably right. Additionally, this driver only has a single 7135 regulator, and will be running off a very small Lithium cell. So heat from all sources will be quite low.
Edit: So, any chance you’d sell me some pre-flashed 10 pin MMU’s?
HarleyQuin
Yeah, I think there is even more heat coming from the LED to the driver to the MCU than is generated in the MCU itself.
As I wrote, if I start making a fortune by selling pre-flashed MCUs, you be the first to know…
No, honestly, I do not sell, I only have a flimsy breakout board and I’m not capable of testing post-flash. Did I already mention I sit in europe?
But RMM might be able to do it, if he already sells the 20pin, why not the 10pin? Might just ask him.
Oshpark Boards:
DavidEF
DavidEF's picture
Oops! I missed that post of yours before. Facepalm
I hadn’t thought about making a new library part. That would work well enough for what I need. If I do that, as well as removing the LVP parts and moving everything around a bit, I could possible get the driver under 11mm diameter. Then it should work for most 10mm cell size lights (10180, 10250, and 10440/AAA) as long as they have length enough in the driver cavity.
HarleyQuin
Don’t give up on the 20pin MMU yet, being able to get these preflashed from RMM is still a major asset.
Here another proof of concept, which might be very much along the lines RBD suggested:
Make C1 an 0603, use 0.254 instead of 0.3048 wires, squeeze everything tight together and you might even hit the 11mm mark… But the 20pin is huge compared to the 10pin…
Oshpark Boards:
DavidEF
DavidEF's picture
Thanks HQ! Party
HarleyQuin
My pleasure Beer
Oshpark Boards:
Rufusbduck
Time zone trailer, I’m missing the fun. Yes, I meant that since you can’t flash after there no need for clip clearance. Blank areas, traces, and vias all take up space so smaller blank areas, shorter traces, and sharing vias with no top side ground ring all will help. Post 19 is along the lines I was thinking only better, I hadn’t thought out how to arrange them. Even just eliminating the mmu pads on the left side will allow the R1/R2 trace to pass underneath so you can squeeze the 7135 down a bit more. When Mattaus did the first tiny10 it took some time but in the end it made sense looking at it.
Scott
HarleyQuin
It’s usually we CET-guys that are missing the action Smile
Oshpark Boards:
ImA4Wheelr
Nice work DavidEF. Sounds like it will make a nice driver.
You could save some space by nixing the reverse polarity protection.  Not sure what impact that would have on internal reference LVP.
Rufusbduck
Another thought, with left side mmu pads eliminated, swap the 7135 with everything but OTC and route pwm under mmu. Maybe rotate the mmu so the gnd side flat is aligned to the board edge instead of it’s corner and put a gnd via under the mmu.
Scott
HarleyQuin
The inner yellow circle has a 5.5mm radius (->11mm).
Getting closer.
Gaining space below the MCU doesn’t help, no component fits. So I swapped D1 to the right again.
Still the notorius OSH Park Edge­­™ has to be considered. Sad
But it looks promising.
@DavidEF, if you want the .brd with the custom parts, PM me an email (preferably an anonymous one).
Now my TimeZoneGap will commence.
Goodnight.
Oshpark Boards:
Rufusbduck
L+/L- could be much smaller(1mm) if they were vias solder able from the bottom. 10xxx cells are all small contact on the positive end so a .4mm (?) via should work for L- if between B+ pad and outer ground ring. B+ input via becomes L+ eliminating that pad altogether.
Scott
DavidEF
DavidEF's picture
Wow! You guys are great help! RBD, thanks for all the great space-crunching ideas. I meant to work on this board again this afternoon, but I forgot. I’ll have to try to remember tomorrow afternoon. HQ, thanks for all the work you’ve done on those board designs. Don’t worry about the OSH Park Edge­­™ being a problem. These boards can be sanded down pretty easily. I’ve been adding extra diameter to my boards just to accommodate it. If we can get the real diameter to be as small as possible, then the OSH Park Edge­­™ doesn’t really hurt anything except making the boards cost a bit more.
DavidEF
DavidEF's picture
Update January 4, 2017: Ignore this post. See post 40 from DEL. This board isn’t going to work.
I made a new, even uglier version of the driver! I deleted R1 and R2. LVP will have to be implemented using the internal voltage reference. By doing that, and also using a chopped down MMU part, I was able to add another 7135 and still squeeze everything into 11mm! To clarify, the overall size of the board is still 13.28mm including the OSH Park Edge­­™, but all the components are fit within a 5.5mm radius from center, so it can be sanded down as far as 11mm diameter. Just sanding down the OSH Park Edge­­™ only still gives a 12.5mm diameter, which is what I’ll be using if I get to do my mod.
Did I say it was ugly? Sick
That weird shaped exposed copper at the top left is the LED – and the other one at the right, hanging dangerously close to the ground pad of the 7135, is the LED+ solder pad. Sorry RBD, I didn’t use your idea to make those into vias. I also didn’t label very well. Only D1, C1 and OTC are even labeled at all. But at least I got my name on the back! LOL! I may go back later and clean up the look of this board a little and add labeling for components. Maybe. I’m tired now. Tired
Texas_Ace
Texas_Ace's picture
What size is the C1 pads? The smallest 10uf I know of is 0805, which can be installed on an 0603 pad but nothing smaller.
DavidEF
DavidEF's picture
It’s a 0603 pad, but it will indeed be a 0805 cap. I guess for consistency’s sake, I could either make the OTC pads also 0603 or change the C1 pads back to 0805. I just didn’t think about that last night. I guess I was more tired than I realized. Tired
