Jetbeam Jet-UV Review
30 posts / 0 new
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 8 hours 40 min ago
!DSC_3052!
Hey folks today we will be reviewing the Jetbeam Jet-UV this should be a short and quick review seeing as its a specific purpose flashlight. Well it has many uses but they are kind of all the same I guess. I am going to load this review full of pics so you can decide for your self. I always do that any ways but yea! The other thread was for testing to see what LED the Jet-UV has.
As per usual the Jet-UV was sent to me by Gearbest for review they have it for a good price of 12 USD if you use the attached coupon. You can not go wrong at that price!
Jetbeam Jet-UV
Coupon: JETUV Price: $11.99
!DSC_3044!
So the Jet-UV is a UV flashlight its basically the same size as the Jetbeam Jet-u. No doubt they used the same shell but changed the color to blue or red its your choice. I like the color the Jet-UV comes in! You can actually swap the pill from the Jet-UV and Jet-u around that makes for a cool flashlight. The beam pattern isnt the best once inside the Jet-u it works better with the reflector system then using optics. This is probably the main difference between the Jet-UV and the Jet-u well besides the Jet-UV is a UV LED flashlight derrr.
!DSC_3054!
So unlike the Jetbeam Jet-u that uses a Cree XPG2 the Jetbeam Jet-UV uses a 3535 365nm UV LED. Jetbeam make no mention of the LED branding that is used in the Jet-UV for a while they said it was a Cree but as far as we know Cree does not make UV LED’s. So the LED is from an unknown company or a generic LED. We do know its a 3535 foot print so basically its 3.5mm by 3.5mm in size. It appears to be a much smaller LED then a standard 3535. I just measured the LED its defiantly a 3535 sized LED but the dome is so tiny. Its hard for me to test the 365nm wavelength so I can only test the LED on things like bank notes and dirt. The actual out put of visible light isn’t that much being a UV LED but when you shine it on surfaces it does a good job and you can see the Jet-UV illuminating object at 5 meters away very clear. Funnily enough Jetbeam did put this 3535 UV LED on a Cree branded MCPB its the same MCPB found in the Jet-u. I am not sure why they done this? Maybe they had heaps of these boards left over who knows. I don’t think they done it to trick people but if you didn’t know LEDs it could be a bit misleading.
!DSC_3041!
From what I can see the Jet-UV uses the same boost driver as the one found in the Jet-u its just modded so you now only have 1 mode instead of 3. I think most UV flashlight are single modes either way. Doesn’t really make sense being able to select a bunch of different modes in a UV flashlight. Actually I kind of retract this statement the Jet-UV is a tad to bright to use on money when you are close so maybe a mode selection would have been good lol. If your an expert at looking at bank notes under UV lights I am sure you do not have the same issue as me. The Jet-UV uses the same twist activation as the Jet-U so this is awesome if you need to EDC a UV flashlight. It shouldn’t turn on in your pockets! The size of the Jet-UV is perfect for a key ring EDC.
!DSC_3061!
What are most people going to use a flashlight like the Jet-UV for? I would say mainly hunting purposes for following blood trails. Or maybe a mechainic shop can see a lot of use in this UV flashlight or obviously a bank. Hunting is a great use for the Jet-UV seeing as it is so light and tiny and only uses a single AAA battery for power. Using AAA batteries for a UV LED flashlight like the Jet-UV makes sense seeing as you do not need to output that much light.
The Jetbeam Jet-UV can be used with all standard AAA batteries except for 10440 usually I would try but I know how sensitive the UV LED’s can be. UV LED’s do not have to be run at high power to get good output.
!DSC_3039!
  • Ni-MH- 1.2v
The Jet-UV will run on.
  • Alkaline battery- 1.5v
  • None-rechargeable lithium’s- 1.5v
Seeing as the Jet-UV will be used outside a lot in the field. Jetbeam has given the Jet-UV an IPX rating of 8 so it should be able to handle most wet conditions. The Jet-UV also get a drop resistance rating of 1 meter which is good for EDC use. Most flashlights with a boost driver don’t come with huge drop resistant ratings.
!DSC_3078!
Size wise the Jet-UV is probably one of the smallest UV LED flashlight on the market. The Jet-UV comes in at 70.4mm (7.04cm) in length and its head diameter is 14.8mm (1.48cm) in width and the body diameter is 14.2mm (1.42cm) in diameter and the Jet-UV weight a tiny 13.2 grams. So it is comparable to the Jetbeam Jet-u that has pretty much the same specs in the size department. The Jet- UV is using a SMO reflector instead of the optics that are found in the Jet-u after swapping the pills around I can see why Jetbeam went this route. It makes more sense to use a proper reflector system. The Jetbeam Jet-UV uses a standard glass lens because if you used AR coated glass you would lose output. So this is the one case where none AR coated glass is better.
The build quality is awesome it is second to none! Jetbeam done a really good and i love the colors and the overall finish is great. The threads are prefect and match so good you do not even need any lube (That is what she said). The hard anodizing type 3 is thick i have had the Jet-UV for a months and it still looks perfect.
!DSC_3024!
!DSC_3020!
Jetbeams listed uses for the Jet-UV
  • Underwear
  • Skin care
  • Baby care
  • Toiletries
  • Counterfeit notes
This list sounds like a good weekend for some people if you connect the dots if you know what I mean lol.
!DSC_3037!
The real question is does it work? Yes it works and it works very good. If you are a UV LED expert you will have different expectations to me I guess. I have no other UV LED’s to compared the Jetbeam Jet-UV against so we will do our own testing and see what we can find out. The beam pattern is floody but it does have a very bright hot spot so I was having to angle the Jet-UV on the side so the money didn’t look way to washed out. Visible light if I shine it on the table the Jet-UV isn’t very bright to the naked eye I think that is better for a UV flashlight it shows that the LED is actually 365nm.
!DSC_3094!
Times like this it would be great to have UV paint laying around but instead I will place paper on the floor at certain distances and then we can see how well the Jet-UV works.
!DSC_3095!
What is included in the pack?
  • Jetbeam Jet-UV
  • Stainless steel clip
  • Lanyard
  • Instructions
  • Spare O-ring
  • Warranty Card
  • Cert of Approval
!DSC_3107!
Overall its small and tiny and light weight and it does a very good. It its very well built and feel sturdy the jet-UV is very well finished nothing is out of place and the paint job looks awesome. So i really can not complain. Even if i do not need a UV flashlight buy it and use the pill from the Jet-u inside this shell it works so good i will add pics after dinner.
These are all at different angles i went full photography today!
!DSC_3114!
!DSC_3117!
!DSC_3112!
!DSC_3121!
!DSC_3126!
!DSC_3122!
Paper 2 meters away
!DSC_3128!
Paper 4 meters away
!DSC_3130!
Paper 5 meters away
!DSC_3131!
Inside the shed about 4 meters away
!DSC_3139!
Work light and Jetbeam Jet-UV on at the same time
!DSC_3109!
This is probably pointless but this is the Jet-u pill inside the Jet-UV the beam is awesome the pattern is really good with the reflector i am using a Soshine 10440.
!DSC_3142!
With the SMO reflector it reaches 100m
!DSC_3145!
Thanks for reading!
Regards Chris
Edited by: everydaysurvivalgear on 01/08/2017 - 12:34
Lexel
Lexel's picture
Last seen: 11 hours 49 min ago
Do you got any info how much deep UV signs your money should have?
For Euros I know that cheap lights stated to have 365nm did light up deep UV signs very weak as the main output is around 375nm and they have also visible wastelight, while a true 365nm Nichia made em light up very strong, not haveing yellow or white wastelight.
Here an example of cheap 365nm LED vs a Nichia 365nm.
Hey mate i found this link.
Fluorescent Ink
A bird, the serial number and year of print fluoresce under UV light.
Highlight of fluorescent ink on the new $5 banknote.
To validate the UV fluorescent features on Australia’s banknotes, it is recommended that a UV black light with a wavelength that is centred around 365nm be used, and that it is done so in low ambient lighting conditions. Many UV black lights that use Light Emitting Diodes (LEDs) emit wavelengths between 395 – 400nm, which are not suitable for viewing the UV features
http://banknotes.rba.gov.au/counterfeit-detection/list-of-security-featu...
This is from the website. What do you think?
!Note!
Lexel
Lexel's picture
I think its better than some noname 365nm LEDs.
To compare it with other LEDs like Nichia it needs a direct comparism in fluorescense, brightness and how much visible light compared to UV light emitted.
For its size its a useful light with some UV output.
The color of the LED surface is different from high quality emitters.
When I use my camera on the Nichia emitter it shows almost no visible light off the hotspot.
Shaun
Last seen: 8 months 1 week ago
imho jetbeam-uv much better then nitecore tube-uv, at least red still shown like review(above) photo.
Lexel
Lexel's picture
For anything below 375nm you need glass and reflector as the plastic of a 5mm LED absorbs most of the 365nm light
mrheosuper
Last seen: 9 sec ago
Here is a comparison between jetbeam UV and a nitecore Tube UV
Jetbeam has less purple light, higher power output, more throw
Both are rated 365nm, but i think jetbeam has shorter wave lenghth
Forgot my pen
mrheosuper
Oops, somehow my image cant be displayed
Forgot my pen
-X3-
-X3-'s picture
Last seen: 19 hours 19 min ago
You can dramatically improve the fluorescence by filtering any visible light with a ZWB2 glass.
I filed down a 20mm glass from Simon’s store and installed it in my Jet UV.
The result is as good as my liteON 3535 SF348 with ZWB2 !
The tricky part is to be really careful while grinding the glass because, eh, it’s glass ^^
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
mrheosuper
Well, some visible light maybe not so bad
Forgot my pen
-X3-
-X3-'s picture
The problem is that visible light totally hide some fluorescence most of the time…
I did the test in the bathroom and the difference is huge
mrheosuper
Well, i am not good at grinding
So, i think i will order convoy s2+ and an UV filter, more power, less effort( and more costing, sadly)
Forgot my pen
-X3-
-X3-'s picture
Bulkier, also. But yeah, way more powerful !
I did a shorty S2+ with 3*7135 and that is the sweet spot to have both high output and prevent over-heating of the LED. I reflowed the LED on a Noctigon though.
Nicolicous
Nicolicous's picture
Last seen: 40 min 12 sec ago
can we ask simon to make smaller size ZWB2 lens?
I dont like my convoy UV because it’s bulky to carry
djozz
djozz's picture
Last seen: 14 hours 18 min ago
The ideal size is 12mm diameter, so it can be used in many AAA-lights. I have not found 12mm ZWB2 filters anywhere sofar.
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
djozz
djozz's picture
Chris, a tip for taking pictures of 365nm fluorescence: the camera picks up deeper into UV than our eyes do. To make the pictures more like what you really see you can take the pictures with safety googles in front of the camera, it filters out much of the UV under 400nm, so you do not see the purple glare on the pictures (that you also do not see with your eyes).
link to djozz tests
-X3-
-X3-'s picture
I made a 12mm and a 10mm with my Dremel equipped with a thin cutting disc (standard) and then a grinding Wheel.
Took some patience, but was about 1 hour of work for both.
The key is to make a straight cut at the surface with th disc, then trying to cut deeper. The glass will crack following the line.
You then make about 5or 6 more straight lines to make a rough round shape.
Once you have a round shape, you can finish with the grinding wheel. The key is to remove material slowly, and not over heating.
There still is some small chips on the edge, but once installed in the flashlight there are hidden by the bezel anyway.
Nicolicous
i found some but they cost $10usd for 12mm whereas 20.5mm cost $1.5USD
dont know why smaller size cost so much but the material is much less
djozz
djozz's picture
ZWB2 filters are extremely cheap to make, you can find manufacturers on alibaba that offer all kinds of sizes. But the demand is virtually zero, so the few sellers that do offer them on Aliexpress can ask what they like, there is no competion taking place. And there’s Simon from Convoy who has ordered a batch directly from a manufacturer (20.5mm diameter), and Gearbest ordered 20mm ones. So those are cheap.
link to djozz tests
Mkduffer
Last seen: 7 hours 18 min ago
I agree. I have both and the security strip on older Benjamins don’t even show up with the Tube-UV. With the JETBeam, you can at least make them out. On newer bills the security strip is easy to make out with the JETBeam. Does a decent job on dog piss too. My daughter just got a new puppy. AngryBig Smile
I have a WF502b UV (395 nm, I believe). The JETBeam clearly outperforms it. Not quite as good as my UV Convoy S2+ though. Considering the power source and package size, I’m pretty impressed.
People say I’m a flashaholic like it’s a bad thing…
Lexel
Lexel's picture
The Jetbeam UV could run a Nichia 276 UV LED at 3.8V and 500mA rated specs easily.
anyone opened one and checked how much current the LED takes?
jon_slider
Last seen: 2 hours 20 min ago
Mkduffer wrote:
The JETBeam… Not quite as good as my UV Convoy S2+ though. Considering the power source and package size, I’m pretty impressed.
Any idea what the UV output of the 1.5v Jet-UV AAA is, compared to the 3.7v 18650 Convoy?
Im guessing about 60% less, so
IF a Convoy outputs 780mw from a 3.7v source, the Jet-UV from a 1.5v source would proportionally produce 316mw. Sound Reasonable?
and in that case the 365nm AA Jaxman E3 UV should have similar UV output power as the Jet-UV, but longer runtime, yes?
Mkduffer
I’m clearly no expert, but I think you also have to consider current output. I don’t know enough to know whether or not the max output of each cell is going to affect overall power output, but since watts = volts x amps, I’d think it would have to, assuming the LED could handle more power than the cell could provide. Even in the case of the Jaxman, perhaps instead of only longer run times, you have a combination of increased run time and power output?
Hopefully someone more knowledgeable will chime in?
Oh and thanks. Now I have another light I may have to buy. Big Smile
ggf31416
Last seen: 13 hours 59 min ago
It’s not linear on the voltage. You can’t even run a red LED with 1.5v, much less an UV led. You need to increase the voltage to the Vf of the led, about 3.8V, to obtain any usable output, so any uv flashlight with a single AA/AAA battery uses a boost driver for that. The current will depend on the driver and how much load the battery can handle. For example on a thrunite ti3 XP-G2 the high mode is 120 Lumens (high for a 1xAAA light), looking at the Cree Product Characterization Tool we can see that for a XP-G2 (S2 bin) such output is consistent with 250 mA with a Vf of 2.86V. The 135 Lm output of the Jetbeam mk1 is consistent with 280mA at 2.87V
A similar driver to the Mk1 may give to an UV led 0.28 A * 2.87 V / 3.8 V = about 210 mA at 3.8V. The higher the voltage difference of a boost driver, the lower the efficiency will be , so the current input to the led may be lower, say 90% of that, 190mA. If the 276A emits 780mW of UV at 500mA and 25ºC (per specs), we can assume linearly that 190mA gives 190/500 * 780 = about 300 mW. We need to increase that value somewhat because leds are more efficient at lower current and decrease it again because the temperature is higher than 25ºC, so 300mW would be a good estimate if the led was an nichia NCSU276A.
However the led on the jetbeam is not a 276A but a cheaper led, so we can expect that the efficiency would be lower, therefore the uv output would be lower for the same current.
jon_slider
ggf31416][quote=jon_slider wrote:
316mw. Sound Reasonable? 300mW would be a good estimate… However …we can expect that the efficiency would be lower
thanks
so
if AAA is ~ 25% as bright as 18650, we would be looking at ~200mw UV output
the AAA works up close, on money, now we need someone in Arizona to see how well it works at Scorpion range Smile
ggf31416
jon_slider][quote=ggf31416 wrote:
thanks
so
18650 are much more than 4x as ‘powerful’ as AAA, but the limiting factor for 18650 UV flashlights is heat dissipation at the led (even more for the 276A). For visible light you can use much higher currents than 700mA without problems. For a AAA flashlight the limiting factors would be the ability of the small boost driver to handle high currents and the voltage drop of the batteries, as well as the need of a reasonable runtime.
jon_slider
Thank, you, yes, I agree.
Im just putting together some general estimates of what to expect when comparing a Jet-U to a Convoy S2
both will light up a redline on a US $100
but the convoy will do it from further away, and will spot Scorpions from further away
The Jet-U won’t have as long a runtime either, which is a trade off because the AAA battery weights 33% as much as an 18650.. plus the body weight differences..
the whether to choose a Jet-UV or an S2-UV, depends on how heavy a light one wants to carry, based on how far away the target is, and runtime. Same considerations as regular lights, it comes down to a choice of battery, personal preference, based on the primary application or intended use.
Mkduffer
I bought them both. The Convoy stays in my backpack, whereas the Jetbeam is always on me. Kinda similar to my strategy with my EDC lights. On my person, I carry 16340, AA or AAA lights and leave the big guns in my fanny and back packs. Recently, I’ve shifted to AA/14500 for the most part for a variety of reasons.
Jon, have you seen this? Might be a neat keychain solution. They claim 365nm output on the UV LED. No deals that I could find, though and kind of expensive, IMO.
jon_slider
Mkduffer wrote:
I bought them both. The Convoy stays in my backpack, whereas the Jetbeam is always on me. … Jon, have you seen this?
good info, I take it you mean the AAA Jet-UV
yes, Ive seen the MecArmy SGN3, it does seem to have a true 365nm, and uses a USB rechargeable 3v LiPo afaict, Im guessing the output is similar to the AAA Jet-U, good for close up, such as money
I have no info on how well the Jet-U AAA or SGN3 UV LEDs work for lighting up mid range distances, such as inspecting a hotel room.
How would you describe the usefulness difference between the 18650 Convoy and the AAA Jet-U
I am a PWM snob, so the SGN3 is not on my Radar because it pulses on its low and mid with the cool white and Low CRI LED, but it does have some interesting red and UV LEDs:
SGN3 PWM:
UPz wrote:
patmurris
patmurris's picture
Last seen: 1 day 13 hours ago
I have both and this would be comparing a real car with a toy car… kind of.
The Jet UV is ok at very short range but lacks both power and a UV filter. The S2+ UV on the other hand is much more powerful and can be equipped with a ZWB2 UV pass filter so that very few visible light interferes with the induced luminescence. If you want to inspect a room or spot things outdoor, that’s what you would want.
