What are your least used/biggest let down lights of 2016
49 posts / 0 new
dekozn
Last seen: 2 weeks 6 days ago
What lights u bought were the biggest let down of 2016 and why?
For me the skilhunt h15. The ui is really annoying: it needs 2 long presses to turn of, I don t see the point of that red flashing light. It could be nice as an option but the way it s incorporated now just pisses me of. Also the size and weight for a single aa light is just to much.
will34
will34's picture
Last seen: 2 weeks 16 hours ago
Lumintop prince, it looks pretty but after a tiny drop on hard floor the bezel got deformed pretty badly. Never got any real use
giorgoskok
giorgoskok's picture
Last seen: 1 hour 49 min ago
Jetbeam jet-i mk and imalent dn11 . I would actually sell them if i could find buyer Silly
alphazeta
alphazeta's picture
Last seen: 3 weeks 2 days ago
Mine was a Lumintop Cu Nichia Worm – Nicely finished light but it’s twisty was way too tight to be remotely practical. It lives in a storage bag & until I saw this thread I had forgotten I even own this. Sick
hIKARInoob
hIKARInoob's picture
Last seen: 7 min 26 sec ago
Nitecore TM26GT
Lot of great properties, but they simply do not outweigh the cons:
- only 3500 lumens with freshly charged cells; you quickly end up with only 1800 lumens available…
- dual stage switch doesn’t work too well. Happens regularly that light switches on immediately after switching it off; it’s annoying and feels budget
- charges only to 4.13V
- Sure, tint is not so good, but this is actually just something minor compared to other disadvantages…
- Stupid high MSRP gives the light a pretentious vibe; just doesn’t give me a good feeling about it…
The Miller
The Miller's picture
Last seen: 1 week 6 days ago
Olight R50
harsh tint and it gets way too hot
Think there is an issue with step down (my review sample doesn’t do that)
I might swap the led with a 3000K XHP70 to see if that turns things around
Nice topic though!
Jerommel
Jerommel's picture
Last seen: 1 month 1 day ago
I kind of agree with OP about the H15, except for the fact that it’s a very pretty light (i.m.o.), and it’s actually smaller than a SK68.
But indeed, the H03 (even stranger UI) is only slightly bigger.
I was very disappointed in my Pop Lite 2x C-cell wannabee LedLenser.
Bezel is glued and heating could mean deforming the TIR, so it’s just sitting in its box…
2x Astrolux M01 also in box waiting for nothing… Tired
…and my new Olight i3s, which is not as good as my older one, just sits in its box too…
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
keltex78
keltex78's picture
Last seen: 7 min 52 sec ago
I’d have to say that mine is the UniqueFire 1508 with 75mm optic. Unfortunately, I had committed to order the light in early January, and about a week later, discovered that our landlord was evicting us so he could sell the property we were renting from him.
As a result, we were moving during the time when I received the light. It ended up being several months before I could even do anything with the light. After moving, I no longer have a workshop/workbench area, so I haven’t been able to do any serious modding in about a year now. I finally threw a pill together for this light using a 3A 105c/Qlite and a XP-G2 (domed) emitter I had in my kit. After putting it together, I found that the head has to be nearly unthreaded before the light is focused properly. Even so, I haven’t had time or facility to fine tune or build a proper hard-driven setup with a dedomed emitter to really push this light.
My results are similar to what NeilP posted here: http://budgetlightforum.com/comment/998629#comment-998629
…with the head fully threaded in place being on the right, and one just barely threaded on the left.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
The Miller
Dang Keltex that’s sad!
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 33 min 6 sec ago
Nitenumen NE01. It wasn’t really cheap and it was nasty!
Also an Ultrafire C8. I ended up getting a solid pill for it and a proper reflector and AR coated lens i made it good.
juaquin
Last seen: 1 week 1 day ago
BLF X5/X6 SS/Cu – great lights, impressive driver and firmware, love the tailcap illumination – but just too heavy to reasonably carry. They sit on the shelf and occasionally get used around the house. That’s on me and not the lights, of course.
nightshark
Why don’t you like the Jetbeam? I was thinking about getting that one.
giorgoskok
A lot of people thinks it is great , but i don’t like the tint (and it has a lot of glue inside , a little hard to change LED) and the fact that it is a twisty . Just my point of view .
tekwyzrd
tekwyzrd's picture
Last seen: 9 hours 45 min ago
Crelant v4a. Too much parasitic loss and run time is a fraction of my ea41w. Changing batteries leads to a struggle to get it to work. I install freshly charged nimh and get a dim flashing. Clean all contacts, try different cells, unscrew the tailcap a bit… working. Switch it off and on… flashing again. It may be a decent light if I replace the driver but as it is it is my #1 disappointment for 2016.
RobertB
RobertB's picture
Last seen: 15 hours 6 min ago
everydaysurvivalgear wrote:
Nitenumen NE01. It wasn’t really cheap and it was nasty! Also an Ultrafire C8. I ended up getting a solid pill for it and a proper reflector and AR coated lens i made it good.
I got one of those ultrafire C8’s also. What a POS. Tossed in the garbage can. Good thing I only paid 6 dollars for it
RobertB
RobertB's picture
I like my Jetbeam Jet I MK, but then again, I like well made twistys, and knew it was a twisty when I bought it. The beam is on the cool side but not bad outdoors. I try not to judge by shining them on a wall inside the house. If you buy one, get a 14500 for it. It’s weak with a AA alkaline IMO.
Ragsy
Ragsy's picture
Last seen: 50 min 53 sec ago
Yunmai Y3 (convoy s2+ style)
My expectations may have been too high for a light that was only $8AU but nonetheless it’s far from the claimed 1000 lumen
Thin construction
Gets hot fast
Extremely visible PWM except on high
They just sit in wait in the spare lights drawer (yes I actually bought 2 to make things worse)
Oh We're From Tigerland.....YELLOW AND BLACK!!!
gangstead
I got a CooYoo Particle L (same as MecArmy PT16). It had good build quality and a good feel, nice-ish LEDs, very bright, but the most awful UI I’ve come across. I ended up giving it to a family member.
Supposedly there are newer versions of the light with a slightly better UI but it’s impossible to tell what you are going to get so I just gave up on them.
ReManG
Last seen: 2 weeks 2 days ago
My Cometa, not due to the quality issues even. I had fun modding one and tightening the zoom threads with JB weld, etc… Dropped new emitters into see how they looked… Then I realized, the zoomies are not my thing…
I bought two… Anyone wants two cometas for $50 shipped (US only) shoot me a PM. One is an XPL HI V3 2A and the other is a domed 219C 5000K 320 I believe… Trades are good too… I got to put a WTS thread up and clear the shelf…
ALL of my links are non-affiliated for your pleasure...
My Reviews
Lithium Ion Battery Safety 101
You bought yourself some good lights, now  go buy yourself some great pants... Bluffworks
I have no affiliation with Bluffworks, except as a very satisfied customer...
richbuff
Last seen: 1 month 1 week ago
I do not have any "let down" lights, but I have lights that are least used, because I bought them to add to my collection. Non collection lights, for use: Two of my largest lights get used for my night walks, while my other large lights are less used.
Acebeam X45vnXHP70.2, K70vn, EC50vn, two X65Vn. Eagletac SX25L3 MT-G2, MX25L4CvnT XP-L. Fenix TK75vnQ70 dome on. 47's MMU-X3. Manker MK34Vn. Nitecore TM06Svn 4 x XHP50.2. Niwalker MM15, and MM15MBvnSpec1. Noctigon Meteor M43vn XP-L dd. Olight S2 Baton. P60vn Quad XP-L HD 2 cell host Cryos Cu head. Thrunite TN36UTvn, TN42vn.
carmantl
Last seen: 2 hours 5 min ago
ReManG, you have PM.
Gunga
Gunga's picture
Last seen: 21 hours 28 min ago
I’d but your mk1 but shipping from Greece to Canada probably won’t work (too costly).
Lightbringer
Lightbringer's picture
Last seen: 6 hours 46 min ago
Wellp, you may’ve found a buyer… Big Smile
I keep banging the same drum, but a twisty in your pocket or bag is nigh impossible to accidentally turn on.
I’ve done both to tail-clickies and side-clickies, more often than I’d like to admit.
Lightbringer
Heretic! Big Smile
Crappy innards, but with a nice solid brass pill from Fasttech, they still make great hosts for XP-E2s and other lower-power LEDs. Even the crap tailswitch can easily handle 1.5A or so.
Not exactly a 9.5 on the Richter scale of lumens, but holds the hotspot together nice and far for excellent throw!
Never tried dedoming an XP-E2, but that would probably kick…
Lightbringer
Okay… biggest letdown? Gotta confess, my S2+.
Love the host, love the tint, really like the semi-floody beam for closer-in work, even like the spread of L/M/H, but that damned blink-on-low still drives me absolutely buggy. It’s a poke in the eye every time I use it…
And I’ve just been too lazy to take it apart and try reflashing it.
L2? Beautiful thrower, but no idea what’s up with the sandpaper-finish anodisation. It’s really rough and chalky. It’s a bit unnerving.
My (Convoy) C8 is a gray matte-finish, yet still pretty smooth to the touch.
Other (clone) C8s are smooth and glossy… and black.
Love the Jet II (regular, not pro), but I really wish it’d fit 18350s as well as 16340s…
Aside from the S2+‘s UI, they’re pretty minor gripes, so thankfully I haven’t gotten bitten too badly this year.
Woytas
Last seen: 3 weeks 3 hours ago
For me it was SingFire SF-348 – strange beam, pretty dim, feels chep. Tint is not great also.
PS. I love my Skilhunt H15 – agree that it’s a bit heavy and has annoying red blink, but…but besides that it’s really versatile and powerful (for AA) light. It has great balance between power/runtime.
mrheosuper
Last seen: 2 hours 54 min ago
Less used light is
Actually, it’s manker e14
Because the dome of leds flew out all the time
So it shows strange annoying blue tint
Forgot my pen
MiG0
Last seen: 3 days 4 hours ago
My biggest let down is Klarus G30.
It suddenly stopped operation while in turbo mode. The
flashlight was warm, but not hot. The battery voltage was about 3.9V per
each of the three protected cells. The flashlight did not reacted to
pressing of either of the switches. Upon releasing and tightening again
of the tail cap the light starts operation in some random mode, and it
does not react to the switches; the only way to shut it down is by
release of the tail cap. The mode it enters after tightening of the tail
cap is completely unpredictable.
I notified the Klarus customer service yesterday and awaiting their response (assuming that they will respond).
giorgoskok
I think shipping will be double the price of the light Silly
wle
wle's picture
Last seen: 1 hour 16 min ago
My 2nd DQG Tiny 18650 IV – which died after 3 months – due to one drop from normal hand height to a wood [or concrete] floor – can’t remember the exact drop.
Became intermittent, then finally cannot be revived.
Took it apart, can not fix or find problem.
(The first one died when the switch failed 2 ways at once.)
Gearbest did give me half my money back, but still, I’m stuck now with the idea that 18650 lights just can’t be that small and cheap, and be reliable.
Now I’ve got a Manker U11, which is nice but way bigger than the Tiny, and an Astrolux S1, which is very nice, and the same tininess as the Tiny, but at the expense of smaller, uncommon battery (18350).
I’d rather just have 18650, 85mm long, plus durability/reliability for $30.
wle
eric800
Last seen: 2 weeks 3 hours ago
Jetbeam Jet I MK, I only used it once. not pocket friendly light for being unintentionally power on when get stuck in your pants and when you need it battery drained out even the clip have a light grasp.
