Replace CFL with LED or wait till CFL burns out?
23 posts / 0 new
Bort
Bort's picture
Last seen: 2 hours 5 min ago
I have long ago replaced all the 60W eq CFLs with LED bulbs, but 100W LEDs cost far too much. Last fall they were on an amazing sale 1600 Lumen, 3000K 15W and $5 each. I bought 5, and replaced 3 already. The last two i have been waiting for the CFLs to burn out but they seem to be immortal, already lasting over twice their rated lifetime.
When calculating payback one calculates energy savings compared to replacement cost and decides whether to buy or not.
In this case i already have the LEDs and the calculated savings are about $4 a year, but then throwing away working CFLs bugs me, yet i wonder how much longer the CFLs will last (they now give off a somewhat rose coloured light mind you).
Your thoughts?
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
WillyD
Last seen: 1 day 21 hours ago
Life is short man…replace those lights! Plus, I can’t stand CFLs.
Andyman
Last seen: 1 month 1 week ago
IMO a big factor is whether you like the CFL’s – in some cases, tint and warm-up time can be annoying. In other cases, they’re a non-issue. I’ve done some of each – I still have a few CFLs in various spots around the house, but others I’ve tossed after a few months, even when they had plenty of life left and the LED alternative was notably more expensive.
StandardBattery
Last seen: 1 month 6 days ago
If the CFL is working for you and you don’t have a real need for it then keep it until it’s dead.
Streamer
Streamer's picture
Last seen: 11 hours 33 min ago
I put my remaining CF’s outside on lamp posts, porch lights, etc….put the cooler running led’s in the home.
Jack Kellar
Jack Kellar's picture
Last seen: 27 min 43 sec ago
Toss the CFLs in the backburner for replacements or new light fixture additions, and get the LED bulbs.
I personally can’t stand CFL and their “hospital bleach” feeling.
wle
wle's picture
Last seen: 10 hours 38 min ago
remember the LEDs are not going to last their stated hours, that is for the led only, the electronics usually find some way to fail in about 1/4 the led life.
there are CFLs with decent warm tint, and the energy saving isn’t much vs LEDs, you have to use that bulb a LOT to pay for a $5 LED bulb, when the difference is only say 4 watts.
$5 / (4watts / ($.001/watt-hour) ) = 1250 hours of USE time, not just time ..
that is 2 years at 3.4 hours a day..
wle
dchomak
I still have some high lumen CFLs going. Also a table lamp next to my chair in the den has 2. I just can’t find an LED bulb small enough and bright enough to replace them
Lexel
Lexel's picture
Last seen: 3 hours 52 min ago
Also consider CFLs loose lumens over time, in industry they get replaced before they fail to maintain the brightness that is required
Color rendering of 80+ CRI Led lights is also better, no heat up time
Dave G
Dave G's picture
Last seen: 1 month 4 days ago
I couldn’t stand the “warm-up” time of CFL’s on cold days. When I turn on the light switch to see something quickly and end up pacing around the room until I can see anything, that drove me nuts. There were some good instant rebates on 40, 60 and 100 watt equivalent LED bulbs with nice color tints about a year ago. I replaced all of the bulbs. They were cheap and actually use a little bit less power than the CFL bulbs.
dchomak
On the other hand, warm up time can be an advantage. In our Master Bath I purposely have CFL’s. I don’t want full brightness immediately in the middle of the night when I turn the light on.
BTW, “warm up time”
CFL’s act differently than LED’s When a CFL warms up, it gets brighter. An LED, when it warms up, gets dimmer
and BTW, both CFL’s and LED’s get dimmer with age.
I’m not defending CFL’s, just pointing out that there are still some applications where they can be useful.
Even a 100W incandescent can be useful as a small, inexpensive 100W heater. Big Smile
Bort
Bort's picture
I think i am just wanting to know how long these bulbs i have can live which is why i have not tossed them yet.
BTW, “warm up time”
Interesting perspective. I despise the warm up on CFLs, i have not had the issue you use them for.
LEDs do lose brightness, though i have never been able to tell the difference, CFL its very noticeable.
If you go LED in the master bath perhaps a dimmer would work?
dchomak
Bort, you want to know how long the CFL will last? I don’t know.
But I do know this, IF you want it to burn out so that you can replace it with an LED, it will last forever! Big Smile
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 2 hours 11 sec ago
I think if you buy brand name LEDs they will last year’s. I have some LEDs and some halogens the halogens have a bad life span but they are cheap. LEDs can pay for them selves quickly. Running 10 60 watt bulbs is 600 watt hours. It’s like 20 cents per kW/h. Running those lights per 5 hours a night is 3kw so 60 cents.
Equivalent led output cost. 10 watts each bulb so 100 watt hours. So 500 watts total for the night. That would equal 10 cents. Saving 50 cents a night adds up quickly.
Most people probably don’t leave 10 lights on at once lol.
Wow my maths was super bad on this lol
Bort
Bort's picture
Indeed, they have no counter on them but they are at at least double the rated lifetime, maybe even triple.
Probably helps that they are turned on once a day only, no on/off that kills them fast.
A watches pot truly never boils!
They are truly quality Philips bulbs, its weird that i actually want them to die.
I’ve been typically buying only high end LED bulbs (on sale/clearance), most of mine are Philips and Sylvania, though the 100W eqs are Feit.
will34
will34's picture
Last seen: 17 hours 18 min ago
I replaced a 11W warm CFL bulb with a 7W NW LED in my room… couldn’t be happier! instant turn on, uniform light, the tint is much better and because the light is directed down it looks a lot brighter. Best $4 spent on any light bulb!
SawMaster
Last seen: 1 year 3 months ago
If you’ve got the replacement or can get it cheaply enough and want to , then replace it (and do something useful with the CFL or gift it afterward Smile ). Most of the time I choose to be lazy and not bother with replacing bulbs till I have to, especially if they’re not easy to get at. Just me, not a recommended approach for anyone else Wink
Phil
dchomak
Phil
question:
“How may flashaholics does it take to change a light bulb?”
answer:
“only 1, but he really wants to have to change” Big Smile
Bort
Bort's picture
First CFL bulb unexpectedly died today, almost a year from this thread creation!
Both have virtually identical use profiles so i expect the second one to die very soon.
There is charring on the beginning of the tube so it looks like it tried to ignite itself, iirc they legally have to use flame resistant plastic for the base, it seems to have prevented ignition. I hope LEDs have the same requirement.
leaftye
I’ve done both. I’ll change everything in a fixture. I’ll also replace all the ceiling lights in a room at the same time.
The CFL’s still get used. I use them in the garage opener because that is a bulb killer. They’ll go in the enclosed outdoor lights that are unfriendly to LED’s, and I don’t really care about the outdoor lights. The rest are backups. Fortunately $1 60W LED bulbs are easy to get now, and $1 100W bulbs are popping up, so I won’t mind when I finish burning through my stash of backups. My CFL last a long time though, about as long as LED’s overall, although Cree bulbs are really dragging down the average LED bulb life.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
adnj
Last seen: 1 day 17 hours ago
For $4, think of the time that you spent thinking about it. Lower your frustration and replace it now. Keep the CFL on shelf for just in case.
Bort
Bort's picture
I already have a drawer full of LED bulbs for future needs, its not about frustration, i just wanted to see how long the CFL would last, they have already butchered their rated lifetime by maybe 3-4x.
slmjim
Last seen: 9 hours 40 min ago
When CFL's came down in price a few years after were introduced I bought a few of them. Not long after, our local power company started shipping free CFL's to their customers who signed up as being interested. 25w, 40w, 75w and 100w equivalents. Boxes of two of four would just appear in the mailbox every few months for a couple of years. Even a few boxes of 3-ways!
There are now a couple of drawers full of CFL's of all sizes, probably 25 or 30 bulbs total.
The vast majority are instant-on, with a few of the early ones that exhibit the half-second or so delay to energize. I've learned to live with that, along with the ramp up in brilliance once on. They just keep plugging along. Out of 24 or so CFL's in service, I've only replaced three that failed (not counting the 'fridge bulb). Two just failed to energize after many service hours, one in a table lamp smoked it's ballast years ago after just a few hours. I put that down to infant mortality in the electronics.
I tried one in a refrigerator that didn't last long, whether from the cold or repeated short-cycling, or both.
So, until I work through all these free CFL's, I don't see any LED's in my future except for a few shop lights.
Great... Carnac the Magnificent tells me I just signed up for yet another expensive hobby.
