DQG Tiny 26650 III Review - 7x XP-G2 2,500lm Pocket rocket!
90 posts / 0 new
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
Liitokala
2Q19
Flashy Mike
Flashy Mike's picture
Last seen: 5 hours 51 min ago
adirondackdestroyer wrote:
Quick question, I have a pair of the 69.5mm protected keeppowers on the way, do you think they’ll fit in this light? They aren’t button top, but they aren’t flat top either. The entire top protrudes slightly.
I had no electrical problems using this cell (5200 mAh version). But due to the length of the cell the tailcap makes only about one and a half turns when screwing down. It’s solid nevertheless.
thommy
Last seen: 8 hours 28 min ago
What about the KeepPower 5200mAh 26650 IMR Flat Lithium Battery Max 30A  -  BLACK ?
Damned, DQG Tiny 26650 III sold out at this moment Angry
patmurris
patmurris's picture
Last seen: 5 days 11 hours ago
NW version seems still available
“In stock, usually dispatched in 4-7 business days”
Kusie
Kusie's picture
Last seen: 17 hours 40 min ago
In MHANLEN´s review the ThorFire 26650 battery fits nicely. Those are good budget cells (unprotected!) that also work flawlessly in my L6 and S70…
Still waiting for a hi CRI version (Nichias?!?) of this light..
K.
Firelight2
Firelight2's picture
Last seen: 21 min 6 sec ago
Got my DQG a couple days ago and I’m impressed. This is my first 26650 light. The output and size are quite nice and it feels great in the hand. I don’t think I’ll EDC it though…. 26650 cells are just too heavy for my pockets.
For modding, I suppose output could be significantly increased by replacing the XPG2s with XPL HIs. I don’t think I’ll bother though as the light is great as-is.
Siftah
Last seen: 2 days 11 hours ago
Have been looking at this one as a replacement to a Klarus G20 which I stupidly lost!
It looks like a great light, but the lack of USB charging and no strobe is a kind of pain.
Doesn’t look like anyone makes a 26650 cell with built-in USB charging yet either Sad
I think I’ll hold off for a while to find a G20 replacement, this one looks very close, but not enough to make me buy :\
strayz
Last seen: 3 days 16 hours ago
Tagging to follow
DB Custom
DB Custom's picture
Last seen: 2 hours 14 min ago
Really don’t understand the desire for charging a Li-ion cell inside the light, worst possible way to do it, can’t monitor temperature and you’re trusting a very very cheap charging system to get it right. I’d much rather use the inexpensive XTar Rocket charger at 2A so it doesn’t take so long on the big cells. There are places that convenience is an inconvenience, using a cheap built in charger could be one of those places. Seems dangerous to me.
Agro
Last seen: 4 hours 9 min ago
If you’re travelling with a backpack, carrying another item is inconvenient.
patmurris
patmurris's picture
Convoy BD06 has built-in charging but it’s less then half as bright – not dim either at 1000 lumen.
However reflector and usb charging do add up on the light size. What’s really impressive with the DQG 26650 is it’s very compact size.
Flashy Mike
I’ ve seen small 18650 chargers powered by USB which also serve as powerbank.
Btw 18650 cells fit in the DQG (with adapter), even protected ones. Don’t know though whether cells with integrated charging fit.
patmurris
patmurris's picture
Liitokala Lii100 – can often be found for less then $3.
https://www.gearbest.com/chargers/pp_272183.html
Siftah
If you’re not charging at 2A then overheating and explosion isn’t such a big risk Smile
When I’m at home and I can, I charge my lights with the cells in a good quality charger. But the convenience of being able to charge from a USB socket is huge as I use my lights for camping/sailing/cycling and other outdoor activities where I don’t have access to a AC source of power.
Siftah
Yeah, I already have a couple of BLF A6’s with USB chargeable UltraFire 18650’s in them, so the BD06 doesn’t really give me anything additional over those – I was really hoping for much brighter light using a 26550 to keep the runtime higher.
Since my original comment, I also noticed the Acebeam EC60 which seems to tick more of my boxes. Much throwier light too, which is kind of what I was missing with the G20. “only” 2000 lumens, but the throw looks much better.
I guess I’ll probably end up with one of each, such is the way with these cheapish lights, you end up collecting them all Smile
klrman
klrman's picture
Last seen: 2 min 55 sec ago
Quick question, I have a pair of the 69.5mm protected keeppowers on the way, do you think they'll fit in this light? They aren't button top, but they aren't flat top either. The entire top protrudes slightly.
I had no electrical problems using this cell (5200 mAh version). But due to the length of the cell the tailcap makes only about one and a half turns when screwing down. It's solid nevertheless.
So do you these protected keeppowers from aliexpress would work in turbo mode?
https://www.aliexpress.com/item/2-pcs-Keeppower-26650-5200mah-3-7V-19-24...
Flashy Mike
Don’t know for sure. This seems to be an older batch (Version 2015) and at least the 2014 version was too long for this light. 2016 should fit but don’t know for 2015. And they don’t say anything about the trip current (when protection kicks in), this should be 10 A which is sufficient.
Edit:
found some older posts which said the 2015 version is already the shorter one.
klrman
klrman's picture
Don't know for sure. This seems to be an older batch (Version 2015) and at least the 2014 version was too long for this light. 2016 should fit but don't know for 2015. And they don't say anything about the trip current (when protection kicks in), this should be 10 A which is sufficient. Edit: found some older posts which said the 2015 version is already the shorter one.
Thanks!
ZoomieFan
ZoomieFan's picture
Last seen: 4 days 6 hours ago
What is the head diameter?
33mm on Banggood.
38mm in the OP.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88, LiitoKala: 3x100 4/5, 2x202 5/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: BLF Q8 4/5, DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5.
Waiting for: (DQG Tiny) 21700 EDCs. Xtar powerbank that (also) takes 20700, 21700, 26650
patmurris
patmurris's picture
ZoomieFan wrote:
What is the head diameter? 33mm on Banggood. 38mm in the OP.
I approximately measured one of mine with a tape ruler… 37/38mm
Agro
This explains why after extensive searches I failed to find an optic like that…
ZoomieFan
ZoomieFan's picture
Thanks patmurris.
I hope the weather is nice in Nice Smile
patmurris
patmurris's picture
37/38mm is the head OD. I haven’t measured the optic.
ZoomieFan wrote:
Thanks patmurris. I hope the weather is nice in Nice Smile
Rather cold – even for the season, but no snow on the coast so far… I hear the other parts of the country are freezing… Sad
Agro
I understand…it’s simply that a couple of months ago I spend a lot of time seeking a 7-led TIR optic that would have a diameter of 32 mm or less. I failed to find any. I guess the actual optic is like 34-36 mm. I may be able to find it….
Flashy Mike
The diameter of the optic is exactly 35 mm. I need one, mine is broken.
Agro
Agro
This one is 35.8, but you may be able to shave it to the size (height is different):
http://www.ledlink-optics.com/MockupDetail.aspx?ID=AAA01F3E9CD24B95A73CC...
Agro
Agro
Flashy Mike
Thanks for the links!
