DQG Tiny 26650 III Review - 7x XP-G2 2,500lm Pocket rocket!
90 posts / 0 new
cyropro
Last seen: 19 hours 47 min ago
Anyone having issues with parasitic drain while the DQG Tiny 26650 III is in standby? I now unscrew the tail cap when not using because it ruined a newer Basen 26650 after a couple weeks of not using the light. The battery dropped way down to around 1.6 volts and I wasn’t able to bring it back. I put in a different fully charged battery and did not use the light, just let it sit overnight. Next day I could measure the drop to be about .2 volts. Curious if this is just my light or others have the same issue.
Flashy Mike
Flashy Mike's picture
Last seen: 1 week 1 day ago
Measured 9 uA at mine which is pretty low.
cyropro
Ok, thanks. Probably just mine then. I’m trying to be careful to always unscrew the tail cap when not using it but I’m sure eventually I’ll forget and lose another 26650. Overall it’s a nice light, but agree with others about the button hard to locate the button at night the sharp edges on the lanyard area. This light has been out a while and I hadn’t seen anyone mention the parasitic drain before so I thought I’d mention it.
SKV89
Last seen: 4 hours 43 min ago
I notice something initeresting or disappointing. I did a ceiling bounce test when I got this light brand new and it registered 384 lx at startup. I used it once extensively and redid the test with fully charged cells of the same kind and got 351 lx at startup. Seems the LEDs degrade significantly with initial use.
BTW, my ceiling bounce test on other flashlights are 99+% consistent between tests when using same fully charged batteries even if I store the lights away for months without use.
StandardBattery
I finally got one of these, and i’m pretty happy with it. The price was too high at Banggood, but i got it anyway. the Neutral-White is nice, a little on the warm side though. The interface is very nice compared to the POS that was in their early 26650 Triple that uses long-press for on and for off. That was one of the worst ever, this one is a dream in comparison; even if they did copy a lot of Zebralight.
I really wish it was not a battery crusher design and they used springs. for a small savings in length over their previous dual-spring light it’s not worth it. Why they had to be so hung up on creating the shortest light by a few mm at the sacrifice of good design is beyond me. With a large protected cell, there are only like 1.5 threads to catch on the tail-cap. I need to test a few other cells, and see if I can find a protected one that’s a bit shorter. Having used DQG lights since their first lights, I don’t trust them enough to use a non-protected cell.
I’m happy to have another 26650 light that should be useful.
ssschen
ssschen's picture
Last seen: 1 month 1 week ago
If anyone is interested in the Gray NW version, GearBest is currently selling it at US$49.58 before shipping. Because it has not been categorised as a flash sale, you can use your GB points. After using 743 GB points (discount of US$14.86), the price drops down to a very cool price of US$34.72.
DB Custom
DB Custom's picture
Last seen: 10 hours 29 min ago
Dang near GIVING it away! Smile
Nice ssschen, good find. Wish I had the cash flow to pick up items like this, would love another one one I could leave stock…
patmurris
patmurris's picture
Last seen: 1 month 6 days ago
I have both the gray NW and black CW. Really nice lights IMO – if you like the flood.
The NW is on the warm side though – not so neutral to my taste.
It is one of my favorite UI too. Easy to catch right away. Mid is default when you just turn it on. Shortcuts to every three modes – is it four modes?. I think it can stay on mid at 500-600 lumen for 6-8h. With a high/turbo around 2500 lumen it is a small light that can do. Thumbs Up
…but, i’m not buying a third one!
I’d rather get a forth Q8… twice the output for about the same price (not including batteries though).
…or maybe another D4?
The DQG Tiny 26650 is somehow in between.
Pavlo
Last seen: 8 hours 45 min ago
Kusie wrote:
In MHANLEN´s review the ThorFire 26650 battery fits nicely. Those are good budget cells (unprotected!) that also work flawlessly in my L6 and S70…
Still waiting for a hi CRI version (Nichias?!?) of this light..
K.
I recently purchased a DQG Tiny 26650 3th and had it modded with 7 x Nichia 219C 90CRI 4000K leds.
The beam pattern is now smoother, with less drastic cutoff from the spot to spill. The overall output did drop a little, and so did the throw, but the output is still incredibly bright and tint, CCT, and CRI is absolutely wonderful.
So far, no issues with the LEDs in terms of compatibility with the driver. Mode spacing is still very good.
Really special light for its size. Can sustain much higher output for longer than your usual triple in a small compact body.
Thought I’d share for anybody else thinking about doing the same mod.
Smile
SKV89
Very nice. I wonder if the driver is replaceable too so you can put a higher output ramping driver on it so it will be like a D7 in spirit.
Pavlo
The driver of the DQG is actually one of the elements that really convinced me to get the light. It features a super efficient boost driver. A ramping UI would be nice, but I wouldn’t give up the efficiency of this driver for a PWM based ramping one.
As for output, I bet it can squeeze out alot more lumens with a higher output driver, but I actually really like that the high mode can be sustained without ramping down. Not many lights around these days that can sustain about 1000 lumens for over 1.5 hours of constant runtime.
Below is the chart that shows lumen output of XP-G2 vs 219C.
https://imgur.com/PjWdPML
And a beamshot comparison:
https://imgur.com/nA5fhW5
Flashy Mike
I had a closer look to the MCPCB and I think it is possible to modify it from serial to parallel connection by cutting and reconnecting traces. In this case you need a new driver which fits the special cell connector. I have this idea for quite a while and probably will design a FET+X driver when I find some time.
But there is still a problem if you want high output: the MCPCB is made from aluminium, not copper.
ssschen
ssschen's picture
Received my DQG Tiny 26650 III today. Love how tiny it is.
Went out for a walk tonight with my son, and he noticed the buzzing sound coming from my DQG Tiny when I put it on Turbo. I put the flashlight closer to my ear, and sure enough the buzzing sound seems to be constantly there when on Turbo, but not when it was on High. Is this a defect?
clemence
clemence's picture
Last seen: 21 min 21 sec ago
Flashy Mike wrote:
I had a closer look to the MCPCB and I think it is possible to modify it from serial to parallel connection by cutting and reconnecting traces. In this case you need a new driver which fits the special cell connector. I have this idea for quite a while and probably will design a FET+X driver when I find some time. But there is still a problem if you want high output: the MCPCB is made from aluminium, not copper.
Copper or aluminum base substrate don’t really make any significant difference up to 3A per LED. Being DTP or not that’s another thing. You can place a small order quantity for either aluminum or copper DTP 7-up board to Kerui. If I remember correctly the minimum order was something like USD 500, very affordable. Less than that then there’s a certain amount of tooling cost.
- Clemence
Agro
Last seen: 1 min ago
Will this work:
https://www.senslite.com.tw/Home/2011/09/29/%C3%B835mm-multi-led-9-cree-...
Even if yes, it would probably need to be converted to DTP….
clemence
clemence's picture
Agro wrote:
Will this work: https://www.senslite.com.tw/Home/2011/09/29/%C3%B835mm-multi-led-9-cree-... ? Even if yes, it would probably need to be converted to DTP….
I bet the performance is not differ much compared to OEM board, and I don’t know if the driver still has a headroom to boost another 2 LEDs.
- Clemence
clemence
clemence's picture
The specs says 9-up LED but the picture shows 7-up. Which one is correct?
Agro
Specs say “MR11/MR16/LED Bulb MCPCB for 7 LEDs (SiLED, CREE XP, Nichia 219)”
DB Custom
DB Custom's picture
The driver in this light is pretty special, boosting from a single cell to supply 20V at 1A to the 7S emitter layout. Very little room in this light for modification, as per the norm in DQG lights.
Still very happy with my switch to a high CRI Cree COB, use it for lighting Macro shots regularly. Big Smile
clemence
clemence's picture
Yup, I modded one and didn’t see a DTP would boost the output to any appreciable value. Each XPG2 takes only 1A. Perhaps removing the thermal glue, bolting down the MCPCB, and use thinner TIM paste would give more outcome.
I rather worrying the switch button and it’s waterproofness. The rubber switch held down only by loose collar. Removing the switch was unexpectedly super easy.
- Clemence
ZoomieFan
ZoomieFan's picture
Last seen: 18 hours 31 min ago
This looks like a very nice light!
The only thing I’m not completely happy about is the mode spacing.
I would love to have a 1200LM setting.
Measured and spec, differ quite a bit. Do you have any idea the same values should be expected from every light from this series? Or can the measured outputs vary between two lights?
The specced high of 800LM isn’t bad, but the measured 946LM is a welcome surprise.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88, LiitoKala: 3x100 4/5, 2x202 5/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: BLF Q8 4/5, DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5.
Waiting for: (DQG Tiny) 21700 EDCs. Xtar powerbank that (also) takes 20700, 21700, 26650
clemence
clemence's picture
- Clemence
ZoomieFan
ZoomieFan's picture
I’ve seen lengths of 92, 97 and 99mm stated in the specs. Head diameters of 33 and 38mm.
What are the real dimensions?
ssschen
ssschen's picture
ZoomieFan wrote:
I’ve seen lengths of 92, 97 and 99mm stated in the specs. Head diameters of 33 and 38mm. What are the real dimensions?
I have a digital caliper, and I have just measured mine. Length is 91.2 mm, and head diameter of 37.8 mm.
ZoomieFan
ZoomieFan's picture
Thanks!
Another mystery solved Smile
goshdogit
goshdogit's picture
Last seen: 6 hours 33 min ago
Mine made a very high-pitched whine/hiss on turbo, but I could only hear it in a very quiet environment.
I asked about it in another DQG thread and George replied that it could be the inductor on the driver. I didn’t attempt a fix.
goshdogit wrote:
Is it normal for the light to make noise in turbo mode? I understand this could be “inductor whine.”
yishenger wrote:
yes, there does have a little drivers will make noise due to inductor, if you can do, dis-assemble it, find the inductor, resoldering it for a try (but it is not so easy to do), although the inductor is solid one, but maybe a little displacement will lead it verbration due to high franquancy.
I really liked the light and added a pocket clip and tailcap magnet. The noise didn’t bother me, but I sold it because it didn’t fit well in my pockets and didn’t get much use.
BTW, I fully disclosed the whine in my for sale post. Smile
LessDark
LessDark's picture
Last seen: 1 week 6 days ago
Anyone know if the new fat 6000mah protected keeppower cell will fit in this guy? Or what the inner diameter of the tube is?
Thanks
Chatika vas Paus
Last seen: 1 hour 28 min ago
Bad news. I ordered this flashlight June 3 on GB. Today is no longer available.
DQG Tiny 26650
ZoomieFan
ZoomieFan's picture
“DQG Tiny 26650”:https://www.gearbest.com/led-flashlights/pp_598992.html?wid=1433363#good...
Black 6500K is still for sale on Gearbest.
https://www.banggood.com/search/dqg-tiny-3.html
Banggood NW discount code: 34E23C -> e46
Banggood CW discount code: 47BDDE -> e46
