Keeppower IMR18650 NH1826 plus 2600mAh (Black) 2016
Official specifications:
Nominal capacity: 2600mAh
Minimum capacity: 2500mAh
Nominal voltage: 3.70V
Charge voltage: 4.20V 0/-0.05V
Standard discharge cut-off: 2.50V
Standard charge current: 1000mA
Charge current cut-off: 50mA
Max. Constant discharge current: 35A
Max. Pulse discharge current: 60A
Very high current batteries from Keeppower with good capacity.
The discharge curves tracks perfectly and capacity is nearly independent of current.
At 30A the batteries get rather warm, my logfile says peak temperature was 84°C after I stopped.
Conclusion
These cells are designed for very high current draw, but when going near 30A a temperature cutout may be needed.
It is very good batteries.
Notes and links
The batteries was supplied by Keeppower for review.
Compare to 18650 and other batteries
