[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
1609 posts / 0 new
adam7027
Last seen: 4 days 21 hours ago
SKV89 wrote:
VR38SP16 will be insane! Gonna get some of your new creations from you for sure.
Do you know, what host(s) and optics support that board? Smile
clemence
clemence's picture
Last seen: 2 hours 48 min ago
So far I found Jaxman X6 is decent host for it
[Clemence]
staticx57
Last seen: 1 day 11 hours ago
clemence wrote:
staticx57 wrote:
Clemence, since you have not made the triple e21a, can we wishlist individual addressable LEDs on it? Big Smile
Done! It’s seriiies/parallel/iindiividual addressable
[Clemence]
Awesome! Tint mixing+color is first thought but there has to be a ton more ideas this would bring.
iamlucky13
Last seen: 3 days 6 hours ago
clemence wrote:
UPDATE 190301: Store news
- A new batch of E21A order placed to Nichia two days ago. There will be full line-ups of E21A coming. ETA, mid March
Very nice! That is a really great range of options!
Ryzbor
Ryzbor's picture
Last seen: 4 days 23 hours ago
What’s the flux bin of the sm353 and sm403?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
clemence
clemence's picture
sm203 D160 R9080
sm223 D180 R9080
sm273 D200 R9080
sm303 D200 R9080
sm353 D220 R9080
sm403 D240 R9080 (old stock)
sm453 D220 R9080
sm503 D240 R9080
sm573 D240 R9080
sm653 D240 R9080
[Clemence]
adam7027
[Clemence]
I hope somebody will be able to produce a ‘soda can’ build with this Smile
(but maybe Jaxman X6 is more suitable to produce higher sustained output)
Pavlo
Last seen: 6 hours 31 min ago
adam7027 wrote:
[Clemence]
I have my eye on a specific light to be used as a host. Waiting patiently for this board to be for sale Smile
Ryzbor
Ryzbor's picture
Quote:
D240
no thanks, it may look natural and be slightly brighter but it’s too green in my opinion.
But mixing 2*sm353 with 2*sm453 should result in a nice 4000K with a rosy tint.
SKV89
Last seen: 4 hours 15 min ago
The E21A D220 definitely have a much nicer rosier tint than the D240 version. But the D240 measures 15% brighter in my lumen tube.
Ryzbor
Ryzbor's picture
If one wants lumens he shouldn’t buy a E21A custom in the first place. The D240 looks very natural in the higher modes but that’s it, in the lower and low-medium modes the tint is bad and unacceptable, 15% more output doesn’t make than any less of an issue. Even the 80CRI XPL-HI 5D with a slightly rosy duv of about -0,0020 makes the D240 E21A look green at about any level.
SKV89
I agree with you, I like my 4xE21A 4000k D220 Tiara Pro more than my 4xE21A 4000k D240 Tiara Pro. The D220 version looks nearly identical in tint to the 219B 4000k 9080 that Clemence was selling.
Ryzbor
Ryzbor's picture
Guess I’ll wait a while till Clemence restocks the D220 bin.
Is your D220 4000K (and 4500K?) Tiara below the BBL on all levels?
Interesting you have two identical lights with a different flux bin Smile
SKV89
I don’t have the equipment to measure but my Tiara with D220 4000k looks a bit below BBL at very low output and goes down to very nice rosy tint at high output much like the Cree 5A/5D tint. The D240 doesn’t look bad by any means. It is nowhere near as green as the 219C 4000k 90CRI, LH351D 4000k 90CRI, or SST-20-W 95CRI FB4 tint. Just not as nice as the E21A 4000k D220 or 219B 4000k 9080 tint that Clemence was selling.
clemence
clemence's picture
This apply not only to Nichia. Almost all LEDs with top bin at their particular category tend to be greener than their lower bin counterparts. Maukka also confirm this. Higher flux bin = more chance to land on green zone.
Light flux measuring devices adjusted to human eyes sensitivity. Our eyes sensitivity peaks approximately in the green zone.
Fortunately, E21A gets more rosy as the current goes up. D240K 4000K has mild greeness at very low current (< 50mA). Makes it unsuitable for pink tit snob who often use it at sublumen level.
With this findings, I will only place any order a step below max flux bin for green free measures.
For example: max flux bin for 5000K – 6500K is D260, I ordered D240 for these CCTs.
[Clemence]
Ryzbor
Ryzbor's picture
Tu put it straight, according to the owners the light sucks below the main3 mode (~300lm). And they are certainly not tint-snobs, just OEM and Emisar users.
However my 3500K mix is magical and the 3000K rocks as well. Overall I think your Wizard/Tiara PRO (with mixed or D220 CCT’s) are the best multi-purpose headlamps ever made.
Thumbs Up
adam7027
I also mention E21A 4500K D220. It is (probably) the most crispy neutral white tint I have ever seen. Under 500mA per LED it gets a very slight hint of brownish yellow (which is fully acceptable for me anyway). The sweet spot for tint is around 800-1400mA per LED, above that it gets into a bit of too rosy tint for me.
clemence
clemence's picture
UPDATE 190312:
Store restocked with complete selection of R9050/9080 E21A as follows: 2000K, 2200K(new), 2700K(new), 3000K, 3500K(new), 4000K, 4500K, 5000K, 5700K(new), 6500K. Same 3 steps MacAdam as usual.
[Clemence]
djozz
djozz's picture
Last seen: 12 hours 34 min ago
Hi Clemence, I think you would like to see a test of a SunLike led: http://budgetlightforum.com/node/66275
clemence
clemence's picture
Thanks Djozz!. I’m on it now
[Clemence]
adam7027
Hello Clemence,
Will you consider making an alternate version of VR16SP4?
I mean, with same sized gaps between the LEDs, but with other LED orientation, so it could be physically pre-configured for 3V?
Other:
How are these E21A LEDs different to each other?
sm203-D160-R9050 and sm203-D160-L2-R9050
sm503-D220-L2-R9080 and sm503-D240-M1-R9080
sm653-D240-R9080 and sm653-D240-L2-R9080
Also, I cannot select sm223 and sm273 from E21A bare LEDs – is that on purpose?
clemence
clemence's picture
adam7027 wrote:
Hello Clemence,
Other:
Adam,
Fixed
sm203-D160-R9050 [old stock without voltage bin] and sm203-D160-L2-R9050
sm503-D220-L2-R9080 [old stock, lower voltage, less bright, pink tint] and sm503-D240-M1-R9080
sm653-D240-R9080 [old stock without voltage bin] and sm653-D240-L2-R9080
[Clemence]
adam7027
clemence wrote:
Also, I cannot select sm223 and sm273 from E21A bare LEDs – is that on purpose? Fixed
Thank you.
clemence wrote:
sm203-D160-R9050 [old stock without voltage bin] and sm203-D160-L2-R9050 — sm503-D220-L2-R9080 [old stock, lower voltage, less bright, pink tint] and sm503-D240-M1-R9080 — sm653-D240-R9080 [old stock without voltage bin] and sm653-D240-L2-R9080
So, tint difference is expected/apparent only with the sm503 – ‘without voltage bin’ stocks technically give the same tint as their newer counterparts (just not specific about voltage bin, which may be same or different as well).
Anyway, do you plan to ask maukka to measure a few more of these newly available bins (and the sm453 as well)? Smile
clemence
clemence's picture
adam7027 wrote:
Thank you.
Ready to pack to Finland…
- Clemence
SKV89
Clemence, can you also send him some individual (non mixed CCT) emitters to Maukka? Would love to know how the emitters in this new batch perform on their own.
clemence
clemence's picture
those LEDs can be individually addressed
[Clemence]
ma tumba
Last seen: 2 weeks 3 days ago
I remember the times when I was hunting for the only available “perfect” led- the nichia 083a. Which I had to sell eventually for it was too green, in person.
Now with this broad selection of great leds I one would guess that the perfect one is just a matter of quick choice, right?
Nope, still pros and cons everywhere, and that grail led is again around the corner.
Glad I havent sold my favorite incands Smile
clemence
clemence's picture
Four adults with mixed personalities plus one trendy cheerful teenager
[Clemence]
Ryzbor
Ryzbor's picture
Any chance of sending a 2*3500K (d220) + 2*4500K (d220) = 4000K mix to Maukka? For replcing the green 4000K D240.
clemence
clemence's picture
Done already, check the picture in above post. Made it especially to your earlier request Wink
[Clemence]
