[GB ended,discussion only] CRI > 80+ NICHIA 2000K-6500K [E21A/219B/219C/319A/144A/757GT-F1(Optisolis)]
1609 posts / 0 new
adam7027
Last seen: 11 hours 48 min ago
clemence wrote:
Four adults with mixed personalities plus one trendy cheerful teenager
[Clemence]
Is the VR16SP4m (gaps optimized for E17A) board featured as the trendy cheerful teenager ? Party
clemence
clemence's picture
Last seen: 1 day 5 hours ago
No, I only used my first gapless VR16SP4.
[Clemence]
adam7027
I have seen JetU(solis|E21A) just ran out of stock. When do you plan to restock them?
virencelights
virencelights's picture
Last seen: 6 days 3 hours ago
anyone got any Beamshots of E21A 5k vs E21A 6500k please?.
thanks.
Virence ArmyTek Viking Pro Quadtrix 9080 E21A 6500k, Virence Skilhunt H04 RC Quadtrix 9080 E21A 5700k, Virence Jetbeam AAA 9080 E21A 5700k, Virence Jetbeam AAA Nichia HCRI Red Led.
https://www.instagram.com/p/B5szQO9jM2z/?fbclid=IwAR2iVysO9q_niBevQv35pH...
clemence
clemence's picture
Kit only, no finished mod.
[Clemence]
iamlucky13
Last seen: 4 hours 16 min ago
clemence wrote:
Ready to pack to Finland…
- Clemence
More reasons I wish I had time for some projects. I’m putting off an order, because I promised myself I would not start any more projects until I finish a couple lingering projects that work is delaying.
But when I do get around to it, now that I know the VR16SP4 is individually addressable, I’m pretty sure I will need one of those in the quad E17A color versions to stick behind a frosted lens in a Convoy.
Unfortunately, the version of the Convoy S2+ that such a colorful emitter board deserves does not actually exist.
Does anyone know of other 4-channel driver options besides the one Mountain sells?
contactcr
Last seen: 19 hours 29 min ago
Ryzbor wrote:
Any chance of sending a 2*3500K (d220) + 2*4500K (d220) = 4000K mix to Maukka? For replcing the green 4000K D240.
Osram has a desktop program that can take the individual measurements and calculate the resulting mix.
Osram ColorCalculator. Free too
clemence
clemence's picture
Guys, do you still miss sw45k 219B R9080? I just did a quick test on a mixed 2× 2000K E21A and 2× 6500K E21A quadtrix.
I don’t like it because….it’s exxtremely pink at any current! AFAIK, the Duv should be much lower than any 219B sw45k I’ve ever seen. The combined CCT looks very close to 4700K to my eyes.
This is the fixture I made for Maukka to ease his testing with varying CCTs. Made from scrap aluminum plate and PVC scraps.
Imperfect reflow, not going to fix it. It won’t cause any problem for spectrum testing. Simple reheating will correct the LED position (and all the wires will have to soldered back again Tired ….)
Never try to sand soft PVC board, unless you want to color it grey.
Relatively tight color mixing 35mm TIR optic. Less than 10°
Approximately a meter from the wall. Each markers are 5cm apart.
Diffused
[Clemence]
zak.wilson
Last seen: 6 hours 7 min ago
That’s quite nice. A bit of Lee 801 over it and it should be about right.
Ceilingbounce – flashlight testing and runtime graphs for Android
clemence
clemence's picture
Why Lee? You better use 3000K + 5700K rather than to put output robbing gel.
[Clemence]
zak.wilson
It’s a joke. I’m suggesting it’s not pink enough and it needs a minus-green filter.
clemence
clemence's picture
Unlucky you, I don’t memorize Lee filter number. I thought you meant to bring it back up closer to BBL
[Clemence]
Lightbringer
Lightbringer's picture
Last seen: 3 hours 50 min ago
Hey, people call me a heretic ‘cause I like the stock 4C in S2+es, and they’re above the BBL. Then again, so’s actual sunlight. Still, I do like rosy, and I loooooove those sw45ks.
virencelights
anyone have any user shots of E21A 5k 9080 ? thanks.
DrDevil
DrDevil's picture
Last seen: 3 hours 30 min ago
I´ve done some comparison between some High CRI Lamps
https://www.taschenlampen-forum.de/threads/clemence-aaa-high-cri-geplant.65953/#post-974287
1. Nitecore TIP CRI; (Nichia NVSL219B LED, 3500K ???? This is for sure not 3500K rather 5000K I guess)
2. Wuben E05 Special TLF – Edition (Samsung LH351D LED, 5000K)
3. JetuE21A (Nichia E21A (R9080) D220, 5000K)
Canon Power Shot SX150 IS; Blende 3,4, ISO100;
Hopefully it helps Smile
AEDe
AEDe's picture
Last seen: 31 min 59 sec ago
Is there any firmware supported CCT changing? Like planed in LT1?
clemence
clemence's picture
Dual output driver would be ideal. Simplest setup is to set the LED in 2s(n)p and a potentiometer. Then check whichever LED pairs has the lowest resistance and connect the resistance in series to the string.
Crude but works
[Clemence]
ma tumba
Last seen: 1 month 6 days ago
What is lt1?
clemence
clemence's picture
ma tumba wrote:
What is lt1?
What is it what?
ma tumba
My question referred to this post
Tally-ho
Tally-ho's picture
Last seen: 3 days 12 hours ago
AEDe
AEDe's picture
It seems not strange. The curves of equal tint have negative second derivative(in uv coordinate). The tint of mix located at the line betwin tints of separated LEDs of mix(as I understand procidure of calculating UV is linear). The more difference betwin CCT of LEDs in mix the more negative Duv.
800px-Planckian-locus
clemence
clemence's picture
Yup, correct. That’s why with full range of available, we can custom engineer by mixing those E21A. No longer dependent to 219B sw45k.
I’m taking another beamshots now, stay tuned….
clemence
clemence's picture
Created a dedicated thread especially for this E21A mix: http://budgetlightforum.com/node/66489
[Clemence]
iamlucky13
I don’t know of any suitable dual-channel driver yet for a flashlight. Something like 3 or 4 × 7135 on each channel would do it, and then it could be paired with a quadtrix in an S2+ or Skilhunt H03 behind a frosted optic, or perhaps as alternative, in a D4 body. I wouldn’t mind trading the D4’s high output for a tint-shifting option.
ma tumba
I would be more than happy to have nonmixing dual channel programmable driver. One channel for a daylight led the other one for night time led. But this can be achieved by using 2 regular drivers in one light
clemence
clemence's picture
30% OFF for all 219C, 319A, and 144AM LEDs
Can be combined with normal store discount coupon code
[Clemence]
adam7027
I was just thinking about order 144AM and E21A from you, but I’ve seen, that VR16S1 is now out of stock Crying
Could you please restock them?
clemence
clemence's picture
Yep later altogether will all those new boards
[Clemence]
WTF
Last seen: 4 days 8 hours ago
clemence wrote:
staticx57 wrote:
Clemence, since you have not made the triple e21a, can we wishlist individual addressable LEDs on it? Big Smile
Done! It’s seriiies/parallel/iindiividual addressable
[Clemence]
Hi Clemence, are you still planning on making this board?
If the E21a works nicely with a Carclo triple I might try putting it in the FW3A.
