Hi, I lost today my meco mini xpl, I dropped that above 3m from a ceiling and it stopped to works, I cant remove the ring of the driver because it dont have cavitys and now I think it trashed :person_facepalming:
So, the driver broke for sure, I can hear some loose in the light headā¦ā¦
About impact, I always read ā1~1,5m impact resistantā and think about it, the edc must have a better resistance and some light has robust driver can survive in high impacts? :innocent:
Any impact can cause damage if hit just right even on the rugged lights. For best impact resistance cover ends of light in rubber tubing.
This should be enough cushioning to dampen the impact from drops.
Its finished, I cant believe which I had a lot of patience to solder all thing :weary: :laughing: :innocent:
I drilled the holes with 1mm bit and it works perfectly to unscrew the ring and the pill. The body of the light its decent and the pill have a good heat conduct.
The light becomes flicker ad I dropped it again, but now from 40cm and it stopped again. I disasembed the light and see some trails in the driver loose (in the integrated circuit more especific) I tried to solder again, but no dealā¦ā¦
Thanks, I will try that, but the problem is the almost the price of the light. I paid 9.9
This driver is strong?
I need some help with those, The x8 is more powerfull, right? It will heats the light alot?
I seem the modes and it jumps to 35% to 100% without anoter level, so, in lumens with a xpl hd, how many lumens it will produce and amount of heat (at touch)? It will heats very fast?
Well if cooling is an issue, Iād rather have long runtimes then higher lumens.
Your light looks like something I would put a 3 or 4 x 7138 driver in so it will not become too hot
