Nitecore P30 review
9 posts / 0 new
Narmattaru
Narmattaru's picture
Last seen: 18 hours 3 min ago
Nitecore P30 review
Review example was provided by fasttech. Here product page at store.
The reason I chose P30 for review, is that Fasttech offers very attractive price + there is site-wide discount coupon “REDPACKET “ (25-27 january -20%, 28.01 -3.02 -10% ), so final price is little bit over 38$.
STATED CHARACTERISTICS
Max Output
1000 lumens
Max Beam Distance
618 m
Max Beam Intensity
95500 cd
Max Run time
680 h 0 m / 28.33 d
LED
CREE XP-L HI V3
Reflector
SMO
Battery
1 × 18650, 2 × CR123
Special Modes
Location Beacon, SOS, Strobe
Beam color
White light
Length
141.5 mm / 5.57 in
Head Size
50 mm / 1.97 in
Weight
165 g / 5.82 oz
Activity
Hunting, Law Enforcement, Military
PACKAGE and APPEARANCE*
P30 is packed into regular Nitecore black-yellow paper box.
Package includes:
1*LED Flashlight, 1*O-ring, 1*Holster, 1*Pocket Clip, 1*Lanyard, 1*Tactical Ring, 1*Silicone Cap, 1*CR123A Battery Sleeve
Size of P30 is small:
head\reflector diameter 50\47mm, length 141.5mm, diameter of body 25.4mm.
Modestly standing side by side with Convoy L2 and Utorch UT02
P30 looks nice and feels nice in had.
Head is qiute big, with crown-shaped bezel.
But comparing with senior flashlights, like the same L2 (which is choosen because i suppose almost everyone knows it) or UT02 this head seems to look more medium-size.
And here is a detail, which i want to point at. PLease take a look at reflector, it is not really smooth. Do you see this concentrical furrows?
I`ll try to reach Nitecore representative here and figure out if this is a defect of something optical improvement. BTW, this furrrows are clearly seen at promo photos. May be you have an idea?
There is Cree XP-L HI V3, why don`t they used dedomed one or XPL-hi?
Cooling ribs are quite big.
there is no spring at head, so that make using P30 with gun mount veeery disputable. At least Nitecore let us to use flat-to batteries. sides of body tube are quite thick, about 3mm.
Knurling is regular, rhombical.
Tail button doesn`t have u-shaped border. With spare tail rings it gives us something more tactical rather regular longthrower.
I don`t like side button of P30 at all. Be prepared not to find it in darknew in most of cases. And when your fingers manage to recognise it, you have pick certain pressing force to switch modes. Side button needs to be upgraded, this is my strong opinion.
It also has indicator feature, so button slowly blinks when there is less then 50%charge left and quickly when less than 10%.
My cat also like P30`s appearance.
*UI
*that is simple.
But there is a feature that i meet 1st time. Tail button can give a signal with half-click. What is unusual – brightness will be that same, which was used last time. That can be even strobe! I think that may be reasonable for certain military\police needs.
P30 in work.
P30 has regular cool white light with light istribution, that we get with most of throwers.
Pen test hasn`t revealed PWM-Shimmering at any mode.
What about runtume and stabilisation. I used my fave 3500 mah NCR18650GA. With it i got about 3.5 minutes of turbo, then 1.5 hours of high (but with brightness slowly falling) and then 1.5 hours constant stepdown to dim light, then off.
After turning off, voltage at battery was 2.98v. I was able to turn it on one more time, but only with lower-mid2 modes.
As for me i`d prefer to see better stabilisation.
Checking P30 performance outdoor, i was surprised that such small (comparing to rivals) flashlight emits such a good beam.
I notice, that i had to increased ISO in lower mode to show it, or it will be invisible at the pic, while eyes could see it clearly.
Btw, trees which you can see at the end of path are in 230m distance from me.
the same with zoom
175 meters to wall.
you may not see this well, so i point that mid2 mode, inspite of small brightness, still makes a noticeble light at this wall (in pic of original size it clearly seen)
The same with video, human eye see this differenly, as it catches more light.
OVERALL impression.
Though i didn`t like such sides of P30 as:
inconvenient side button
not good stalisation
no head spring
I have to point at pluses:
impressive throwing light
good variety of modes
compact size
no PWM shimmering.
And the main andvantage here is, i remember again – price. With “REDPACKET “ coupon it can be as small as 38$, thought even without coupon price is still very attractive.
"How to choose flashlight, Main things in simple words":http://budgetlightforum.com/node/68418
Edited by: Narmattaru on 01/26/2017 - 07:28
Narmattaru
UPD
i`ve just checked some throwers from the same distance (about 5 meters)
here are numbers that i got, maximum for every flashlight.
utorch ut02 – 136
nitecore p30 – 158
convoy l2 – 206
YLP ballista 3.0 – 301
Dirt
Last seen: 1 day 6 hours ago
Thx for the review. $38 is a hella good price. If they had a nw option I’d be on it like a fat kid to a piece of chocolate cake! Mmm cake!
Enderman
Enderman's picture
Last seen: 9 hours 38 min ago
The lines in the reflector are due to the manufacturing process and are normal, I already asked them about it.
Idk how they make their reflectors, but it works amazing.
Another user polished his reflector to remove those lines and ended up losing like 10kcd.
Theodore41
Last seen: 1 hour 48 min ago
Narmattaru wrote:
UPD
utorch ut02 – 136
nitecore p30 – 158
convoy l2 – 206
What are these numbers please?
And how is it possible for the P30 to throw more than the Manker,which has 121Kcd according to my measures,while P30 has only 95?
Nicolaas
Last seen: 1 month 6 days ago
See here: Utorch UT02 review
He did not compare the manker, but to the Utorch “version” which performs 90Kcd with NW and 100Kcd with CW emitter.
He did not state whether his UT02 has NW or CW emitter.
But even if it has NW, the P30 still did a lot better then 90Kcd. Which is good news!
Grtz
Nico
Theodore41
Grtz
Nico
You are wright Nico, it was my fault.I thought it was the Manker U21 which I have.
Nicolaas
No problem mate! Wink
Narmattaru
thanks for pointing at this.
i was too busy and forgotten to mention that you shouldnt consider these numbers as exact
they are just relevant numbers i got at my luxmeter from the distance i picked randomly, which in my case was about 5 meters.
non of them shows exact brightness of any flashlight. i measured them just to give idea of how hotspot of one flashlight is brigther ( or vice versa) than other.
my UT02 is CW.
