JETBeam Jet-1 MK Video Review
15 posts / 0 new
cmflippen
cmflippen's picture
Thank you to everyone who recommended this light to me. It’s fantastic!
Lexel
Lexel's picture
Last seen: 5 days 12 hours ago
I replaced the ugly green tint LED with a Nichia 219B now its a great light
cmflippen
cmflippen's picture
Thinking about doing the same. Has the brightness or beam changed significantly? Also, did you re-flow the new LED to the stock board, or did you replace the whole assembly?
Lightbringer
Lightbringer's picture
Last seen: 8 hours 45 min ago
Hey, where do you get 219s (either nekkid or already on stars)?
The ones FT sells are quite warm. Absolutely beautiful for a nightlight, but not for a flashlight. More like 2500K or less (candlelight), not 4500K-5000K.
Lexel
Lexel's picture
I had to use the stock aluminium board to reflow, no chance to make a 8mm sinkpad fit as the star has 4 gaps for wires and gasket
To make it fit you need another gasket and thermal glue the star as it needs to be fixed against rotation
The light output dropped by about 30% but the tint and color rendering is far better
Here is a good source for 219C 4000K tint
http://www.kaidomain.com/p/S026302.Triple-Nichia-219C-Neutral-White-4000...LED-Emitter-with-20mm-x-1mm-DTP-Copper-MCPCB-w-optics
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 22 min 58 sec ago
Why not just De-dome the original LED?
Lexel
Lexel's picture
its not about throw
the original Jetbeam LED has a really ugly green tint
you can put a rocksolid XP-G2 S4-2B, S4 5D2 or S3-3D or Nichia 219C in there, depending if you want high CRI
http://intl-outdoor.com/cree-xpg2-s3-3d-bare-led-p-884.html
The tint will shift once you dedome? It will be about a NW tint .
Lexel
Lexel's picture
yeah dedome an already green emitter, will get even worse green neutral white
Mines not that green stock. Most XPG2 do go a little green once Dedomed. Its still cheaper and easier then replacing the LED.
Lightbringer
Lexel wrote:
Here is a good source for 219C 4000K tint http://www.kaidomain.com/p/S026302.Triple-Nichia-219C-Neutral-White-4000...LED-Emitter-with-20mm-x-1mm-DTP-Copper-MCPCB-w-optics
Kewl, tnx!
Splinter
Last seen: 3 years 2 months ago
Good review, i liked it, only thing i did not like was the music at the start, was not expecting that.
Nel1982
Nel1982's picture
Last seen: 2 years 3 weeks ago
Hola buenas me gustaría que me ayudarais, acabo de recibir la linterna jetbeam1mk y tengo una duda con el funcionamiento,no sé si será normal en este modelo pero note que dentro del haz de luz se ve un pequeño círculo como si fuera la sombra del led o circunferencia del led,esto no me había ocurrido en otras linternas led que tengo,tengo la wuben g339 con el mismo led y esto no ocurre.y quería saber si es normal en este modelo,o es defecto de fábrica,ya que estoy en tiempo de poderla devolver,gracias de antemano
Nev
Me not understand, me speak English.
ggf31416
Last seen: 5 hours 37 min ago
Si se usa a muy corta distancia, hasta unos 8 cm, se nota un agujero en el centro, que es donde no está el reflector, eso es normal con todos los reflectores lisos.
Necesitarías subir algunas imágenes para explicar mejor el problema.
At very short distances, up to about 8cm, there is a donut hole. That’s normal for smooth reflectors.
You would need to upload some pictures to better describe the issue.
