I’ve read several posts about using small USB chargers with Solar Panels, i.e. Miller ML102, etc. My concern is how the charger behaves with the unstable voltages from Solar Panels. How the charger resets itself on cloudy days, etc. can damage the batteries in some instances from what I have read.
For this you’ll need dumb chargers that simply act as a step down converter and immediately starts the charge when both input and output are detected. The miller ML102 works great for solar panels. I tried the Xtar MC1+ too and sometimes it would get stuck at 0.7A after the voltage drops and has to be reconnected to charge at 1A again, but it’s not really a big deal.
I recommend getting a panel with automatic restart instead, this way it will work with all your devices.
[quote=will34]
For this you’ll need dumb chargers that simply act as a step down converter and immediately starts the charge when both input and output are detected. The miller ML102 works great for solar panels.\/quote]
Which version?
Bill
The TP4056 module had no problems restarting after cloud passing over pv panels. The termination of CV mode can be kind of excruciating depending on the circumstances and charge current chosen.
Hooked up a Lito-Kala 100 to the TP4056 + 3W solar setup and could not seem to kickoff the charging mode. Did not troubleshoot at the time. Could be an undervoltage lockout condition? as there just would not much overhead with the 6V mini panels.
The ML-102 is a dumb charger, as long as the input voltage is in the parameters of the step down chip it will charge, essentially it is just a CC/CV buck converter and can take well above 5V input.
I suggest the V9 that comes with the charge level indicator, very useful when you don’t have anything else to measure.
