Imalent HR20 Review
37 posts / 0 new
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 day 17 hours ago
Imalent HR20 Review
Imalent HR20 headlamp Review
!DSC_3486!
Hey folks today we have probably my favorite style of flashlight to review. The flashlight in question is highly unique. For a few different reasons it stands out in a good way of course. I love headlamps because they free up my hands when I am fishing and they make life so much easier. I will use a headlamp when I am fishing, hunting, hanging out the washing at night any excise will do. Headlamps also come in handy when I am working on other lights!
The flashlight in question is the Imalent HR20 I have seen heaps of people buy these but not to many reviews on them for some reason. The Imalent HR20 was sent to me by Gearbest for review. With the coupon it goes for $27.99 this is the group buy price. Sounds a bit rich to me NOT! I will leave the link and coupon here! Check it out if you are interested.
Imalent HR20
Coupon: UYS7
!DSC_3500!
Now moving on with the HR20 where to start? Like usual I will probably muddle every thing up and make it a pain to find the answers you want.
Seeing as I forgot this in my last review lets start here.
Whats in the package? You get every thing you need to run and use the HR20 out of the box. Which makes it hard to compare to other Headlamps or flashlights because none give you all of the gear at this price! But wait theirs more!!! (you will only get this if your Aussie)
  • Imalent HR20
  • Instructions
  • Headband
  • Imalent 18650
  • Micro USB cable
  • Spare O-rings
  • Clip
!DSC_3535!
The Imlanet HR20 is a headlamp as I have already said numerous times. In a sense a modern day headlamp is not limited to being used a headlamp only. A modern day headlamp of quality will be multipurpose in its tasks and usages. Also I guess vice versa a modern day flashlight will have more then one use. Back in the days you couldn’t really stick a 3 D maglite on your head. If you could you probably have a fat head! Lol! Headlamps now give you the option of being used in a multipurpose environment. The Imalent HR20 is no different it comes with the goods you need to use the HR20 as an EDC. I guess you can still buy headlamps that are only used as a headlamp I have a few that I bought late 2014.
The HR20 is now apart of a long line of headlamps in my collection. The HR20 closest competition would be the Nitecore HC30 my regular fishing choice for a headlamp. Also the skilhunt H03R the HR20 does offer more features then these flashlights.
!DSC_3511!
THE HR20 is on the smaller side for an 18650 flashlight not the smallest headlamp on the market seeing as it has a built in charger. It is still really small and lite weight. Well it looks like I have crank out the scale and calipers to measure the HR20 it has no measurements any where. The Imalent HR20 comes in at 10.6cm in length and the battery tube is 2.2cm in diameter and the head is 2.6cm in diameter. As you can see the Imalent HR20 is still a really small 18650 flashlight even with the inbuilt charger system. The HR20 is really lite weight as is to be expected of course you cant have a brick on your head. The HR20 weights 47 grams without the battery. HR20 is 126 grams with the battery and with the included headband. The 47 gram weight of the HR20 is lighter then some of the recent 16340 flashlight I have reviewed wowzer! If I compare the length of the HR20 to the HC30 the HR20 is a tad longer not by much just a little. Like maybe 1cm longer. That is a great effort by Imalnet to make then charger fit and work in such a small space.
!DSC_3546!
Build quality wise the HR20 is great I was surprised by the build quality that Imalent have delivered on the HR20. You get all the good specs with the HR20 like Aerospace aluminum alloy body and hard anodizing type 3. You even get AR coated glass. All the threads are very well cut and the switch feels good to press. The HR20 came perfect no anodizing missing no marks on the light itself every thing looks very prim and proper. That is more then I can say for when I bought my HC30. The knurling is awesome on the HR20 it feels very grippy which is funny because the HR20 is market as a headlamp. I have tested some tactical style flashlight lately and they don’t even feel this good in the hand. I would rate the build quality of the HR20 better then my Nitecore HC30.
!DSC_3506!
Another awesome feature of the HR20 is the clip the clip is well built it appears to be stainless steel. Its a fairly deep clip I had no issues while using it. The best part about the clip is the fact that it can be used either on the top or the bottom of the HR20. So you can use the HR20 as a normal flashlight or reverse the clip and use it on your hat! Freaking awesome work here! Of course because the output is on the side the light will be pointing down if its on your hat. I like that because I will most likely be using my hand to need this.
!DSC_3524!
The HR20 uses an adjustable brightness rotary switch basically a ramping feature. So there is no modes on the HR20 you can chose your own modes all the way from 1-1000 lumens. The ramping is electronic and feels good there is no lag in changing modes as such. Well at least no more then in a normal mode selection flashlight. Its actually crazy right now the price the HR20 is going for considering the quality you get. Imalent even went as far as to use a direct thermal path copper MCPCB. This is not essential but it is an awesome addition considering how lite weight the HR20 is. The copper star MCPCB will help dissipate heat better. The HR20 also has some trendy inbuilt cooling fins on the head. These cooling fins help to dissipate heat some what. They also offer a little extra grip while holding the HR20 it looks like Imalents logo?.
!DSC_3542!
The HR20 is perfect for all sorts of outdoor use it has all the usual ratings you need to get by while using the HR20 outdoors. Headlamps probably are the most used flashlights for an outdoors enthusiasts. I know personally I will chose a headlamp first whether it be for fishing or hunting. Even with the included charging features with HR20 still offer an IPX8 rating to 2 meter submersible. That is an amazing effort once again by Imalent. Most headlamps probably wont be dunked in the water to much. Its good to have that piece of mind to know your gear is safe in the rain and even from ocean spray. The Imalent HR20 also comes with a drop resistance rating of 1.5 meters which is also good. The last bunch of light I have tested only had a drop resistance to 1 meter and the HR20 also uses a buck driver. The same as those other flashlights I just tested.
!DSC_3498!
The HR20 also has an inbuilt charger the charger uses a standard micro USB 2 cable and charger at a rate of 500ma as far as I could tell. The charge rate may vary depending on how many volts the battery is. My included Imalent cell was already at 4 volts when trying the charging module. The HR20 comes with an included 2600mah 18650 so this makes charging time some where around 5 hours which is actually good. The charge cut of rate very good at 4.19 volts. While charging the HR20 will show a red LED and once fully charged the LED will be displayed as green. Imalent also say you can only charge cells with protection but that is not true I am currently charging an LG HG2 to see how that does. The Inbuilt charger can only 18650 no other batteries. The LG cell cut of at 4.19 volts also.
!DSC_3518!
The headband that is included with the Imalent HR20 is good after using the headband from the H03 I know they can do better if they want. Don’t get me wrong there is nothing wrong with the HR20 headband. I would say the headband is the same quality as the headband that is included with the Nitecore HC30. The HR20 headband in good in that sense just don’t thrash it to much. The loops that hold the headband to the flashlight are same thickness as the HC30. The padding and thickness of the elastic parts is on par with the HC30 also. In this aspect the Skilhunt H03 is a bit better. The H03 headband offers a much thicker loop system to hold the flashlight to the headband and is thicker in the padding department and also uses has more elastic. Just to put it into perspective the Imalnet HR20 headband weight 35 grams and the Skilhunt headband weight in at 50 grams. Either way the headband is still comfortable and works well. My HC30 headband is still going strong almost a year and half later!. I am sure you will have no issues with this headband just treat it how you would want to be treated lol! Unless your into BDSM lol
!DSC_3567!
!DSC_3561!
The Imalent HR20 uses the Cree XPL-HI for a maximum output of 1000 lumens. The output itself is good for a headlamp and a flashlight of this size. Overall I do not expect the best output for a headlamp but 1000 lumens is a good mark to hit. If you have to much output then you will have to compromise run times and size.
Skilhunt headband works great
!DSC_3553!
The Imalent HR20 can be used with either the included 18650 or 2 CR123s. I can not find any thing to say that 16340 will work so just be careful if you want to use them. Some times working voltage may only account for the use of CR123s and not 16340s. It would appear the HR20 is using a constant current buck driver. There appears to be no PWM on the HR20 which is always a good sign of a well made driver. The HR20 has an inbuilt thermal control like most good headlamps do. The thermal control is just that. It is a thermal step down and not a timed step down. So it will stay at 1000 lumens as long as you can keep the HR20 cool. Maybe its a good time to go and play in the snow!. The Imlanet HR20 also has reverse polarity protection which is essential when using CR123s in case one goes in the wrong that can be bad lol. The included cell is on the longer side so you should be able to fit most bigger 18650 batteries in the HR20.
!DSC_3516!
As of yet you don’t see to many headlamps using a XPLHI considering most headlamps are made for flood and not overall throw. The HR20 is more so in between it throws good for a stock headlamp that doesn’t have a hug reflector. The HR20 has a rating of 11200cd which equals a throw measurement of 225 meters which isn’t to bad. As much I love my optics on my headlamps some time i need a little more throw to see stuff out a tad further. If we compare the HR20 VS the HC30 the HR20 throws 225 and the HC30 throws 162 meters. This is mainly down to the use of the XPLHI in the HR20. The reflector in both flashlights are about the same size.
!DSC_3536!
Output and modes on the HR20 are completely up to you. The Imalnet HR20 doesn’t have any mode sets at all. The HR20 uses a ramping mode selection so you can chose any mode between 1-1000 lumens as your mode. By simply turning the rotary adjuster switch on the side. Now this feature may not be for every one but I feel its awesome it lets you chose the exact mode you want when you want it! I often just fling the rotary switch up and down to chose a random level. I am goof and do not do this at home for all you playing along I am not sure how good it is for the light lol.
Imalent does write the following modes this is the highest and lowest setting you can chose. The choice is yours any thing in between these outputs. These are ANSI rated numbers using an 18650 battery.
  • Lowest mode: 1 lumen at 360 hours
  • Highest mode: 1000 lumens at 1 hour and 45 min
The choice is yours!
The Imalent HR20 does actually have a few special modes.
  • Strobe 1-1000 lumens
  • Beacon 1-1000 lumens
  • SOS 1-1000 lumens
Once again you can chose any setting between 1-1000 lumens even for these special modes. To access the special modes simply push and hold the power switch for 3 seconds to access the strobe from there you push and hold again to move onto the nest modes. I like this I some times use a beacon while rock fishing in a dangerous spot and being able to control the output of beacon mode is awesome!
!DSC_3505!
This is the first headlamp I have seen with no set modes. Not the first flashlight I have seen with no set modes. I have had a few flashlight with ramping features that remember the output I love it. At first I thought it was gimmick but now I know its good for a reason. I would rather this UI then the UI on the H03 I hate having to change mode groups and cycle through 100 modes to get the perfect mode. Then I will add you can probably get the perfect output on the HR20 easier because it is completly up to you!
!DSC_3552!
Overall the Imlanet HR20 is one of the best headlamps on the market. Price to performance it can not be beaten. You get every thing you need to use this flashlight straight from the box. Plus extras in case you want to EDC the HR20. The build quality on the HR20 is better then on my HC30 and it cost less and offers more. The only thing for some people is the ramping mode selection for me this is no issues. I love it! So I can highly recommend the HR20 to any one looking for a good quality headlamp. Or even some one looking for a small sized 18650 EDC the Imalent HR20 is hard to go past.
All these photo where taken at ISO800 but it was raining and really windy! Also the HR20 has no modes so i chose a few outputs in between!
Lowest mode! Its still fairly bright its seem about 3 lumens.
!DSC_3591!
This is about a 1/4 turn of the adjusting rotary switch.
!DSC_3593!
Ahhh maybe like above the last setting but below half way lol
!DSC_3596!
This is 1/2 turn of the rotary switch. 5-600 lumens.
!DSC_3597!
Highest setting 1000 lumens in heavy rain.
!DSC_3599!
100 meters to the tree on turbo mode. The HR20 hits the tree easy. (It reaches easy but the rain makes it hard to see!)
!DSC_3601!
About 60 meters to this tree.
!DSC_3602!
The tint isn’t to bad
!DSC_3605!
Imalent HR20 left and Nitecore HC50 right
!Hc30!
Imalent HR20 left and Convoy S2+ right
!S2+!
Imalent HR20 left and Nitecore HC30 Right
!Hc50!
Imalent HR20 Left and Skilhunt H03R Right
!Ho3!
Okay folks thanks for reading i will update more pictures tomorrow but right now its bed time!
Regards Chris
Edited by: everydaysurvivalgear on 02/13/2017 - 02:07
kramer5150
kramer5150's picture
Last seen: 8 months 3 weeks ago
Nice review thanks!! Curious, how stable is it without the center head strap? I frequently wear a HL loosely around my neck, so those center straps get in the way.
My thrunite TH20 also uses infinite ramping… its a GREAT ui for a headlamp.
Jerommel
Jerommel's picture
Last seen: 5 months 5 days ago
That HC30 looks sweet.
The Imalent will probably not be bought for its looks (i.m.h.o.)…
The Burgh
The Burgh's picture
Last seen: 3 days 11 hours ago
Terrific and thorough review! Thanks for it!
From the pictures, it appears that the tint is on the cool side of neutral. I understand that we all have different tint perceptions.
What is your judgment of the comparative tint?
There will always be more darkness than I have lights.
ISO
Last seen: 9 months 4 weeks ago
I like this light, have 2 of them and no problem so far. This light is good for its low price.
But I use battery chagers for battery so dont know how good internal charger is. And a decent barrery is included
Have other headlamp also( Nitecore H60, H50, 3 of Skilhunt H03, and alot of AA and aaa headlamp but this was really great for price/performance.
scdaf
Last seen: 1 day 15 hours ago
I’ve had this headlamp for about 6 months and it’s my go-to light for nearly any outdoor activity. Used the built-in charging once, just to affirm that it worked, which it did. I concur with all your review points, I don’t think there’s another headlamp near the coupon price which can lay a finger on it. Thanks for the review!
Thank you all for the kind words!
Its okay with out the top strap but id rather have it on for safety. It is a pain to get the top strap of its really made to used with it. As long as you tighten the straps enough it will work okay.
Quote:
That HC30 looks sweet. The Imalent will probably not be bought for its looks…
Lol its not really bad looking it just looks different. My HC30 has TIR optics. I think the HC30 looks a bit to plain. The H03 is a good in between. I do own 2 HC30s.
Yea it is still a cool tint but not way to bad in a sense. Doesn’t really answer your question lol. Its maybe around a 6000k tint. I have seen worse XPLHI tints. The S2+ in the pics is 4000-4500k tint and the H03 is a NW tint around 4500k also maybe? The NW tint in the H03 is different to the NW tint in my BLF X6 the H03 and S2+ are much warmer. If you want a more NW tint go for the H03 its about the same price with the discount but you lose the charger and battery plus the H03 uses optics so not much throw.
Jerommel
Jerommel's picture
Your review made me order a HC30 actually. Smile
Must say though, that stepless dimmer function and some more features of the Imalent are very nice, and the price is attractive too.
Yea the HC30 is a solid choice i would have a hard time choosing between these 3. They are both similiar but worlds apart. I think the Imalent and Skilhunt are a tad cheaper but the Nitecore should drop in price its about a year and half old almost. Heaps of option for optics for the Nitecore if you want to go that route.
ChibiM
ChibiM's picture
Last seen: 1 day 1 hour ago
I was waiting for a review on this one. Thanks. Do you have any measurements? Does it have any parasitic drain? What’s the real runtime?
Never mind, I see more reviews of this light. Thanks.
Thanks mate!
Yea the length and weight is in the review i will dig it out. I weighted the HR20 at 47 grams without the battery. Altogether with the included 18650 cell and headband i should add lol. It is 126 grams
Okay i found the calipers it is 10.6cm in overall length
Tail cap diameter is 2.3cm
Head diameter is 2.6cm at its biggest point
I can do run time test for you i am just sitting on the computer any ways. They say 1 hour and 45 min but that is with step down from 1000 lumens. I cant really measure when it step down.
The standby drain is super low 12.3 Microamps. I have never seen a reading this low lol.
Serp
Serp's picture
Last seen: 6 months 3 weeks ago
I have this but with a black cover. Very flimsy connector microUSB. I’m afraid one day it will fall off along with the wire.
Another annoying me flicker on low mode. Not really weak but so.
Also, my not sealed. When unscrewing the cap and blowing inside the air easily exits through the opposite side.
My rating 3/5.
oto
oto's picture
Last seen: 21 hours 5 min ago
Does HR20 accept flat top batteries?
Serp wrote:
I have this but with a black cover. Very flimsy connector microUSB. I’m afraid one day it will fall off along with the wire. Another annoying me flicker on low mode. Not really weak but so. Also, my not sealed. When unscrewing the cap and blowing inside the air easily exits through the opposite side. My rating 3/5.
Weird mine is fine. I even had in the rain when i was taking these pics as you can see no problem! I have no PWM either. Maybe its your battery connection?
ChibiM
ChibiM's picture
I love infinite variable output, but dont think ill jump on this one. Ive read about the flicker in another thread.
Hey mate i just tried and it does! My LG HG2 are a tad short so it rattle a little nothing major. Only when you shake the light really hard.Same with my Samsung 25r they work but if you where to hit the light to hard it may turn of because the connection would be broken. I wouldn’t suggest hitting the light hard lol.
The head has a tint button on driver board that is maybe 1mm long.
Serp
Serp's picture
No. The battery is not being.
Do not PWM. Trembling brightness. Approximately 10-20% brightness its happening.
This is a problem in the driver may not be correctly matched inductance or capacitance.
I just tried mine again but this time on a white wall through my camera and its completely fine. Maybe it was just the first ones? i would have noticed when i was taking pics. I will have a video up soonish i hope you will be able to see in that.
Serp wrote:
No. The battery is not being. Do not PWM. Trembling brightness. Approximately 10-20% brightness its happening. This is a problem in the driver may not be correctly matched inductance or capacitance.
You mean its a frequency problem? I honestly can not see it.
Serp
Serp's picture
I’m afraid to open it. I saw pictures of what’s inside and it does not inspire optimism me Smile
There is a problem. What exactly is due, I do not know. If a newer version to fix it, it’s good.
strango
strango's picture
Last seen: 6 months 1 week ago
I have both variants: with black and blue covers, the second one is significantly better: more solid built, no flickering.
Black one came DOA but I managed to fix it.
And yes, it looks terrible inside Sad
strango
strango's picture
It does not look like frequency issue.
Just random blinks with significant output drop. Usually happens in low mode. Not so often to stop using flashlight but still…
Buzzing Bulb
Last seen: 9 months 2 weeks ago
Can you quide me in the right direction about optic options for the hc30?
Do you mean ready to buy click on little adjustment optics or get the heat gun ready and fire up your soldering iron optics?
I have a HC30 and want to venture into maybe doing something with a flip up/down diffuser like the skilhunt H03F has got.
Thanks
I kinda like the H03F but refrain from buying one, due to people saying it may flicker and Skilhunt’s customer service/guarantee sucks.
My optics fit straight in the HC30 I had to sand Down the sides a little but nothing major. I got mine from fasttech. I’ll find the size for you. I think my optics may be a little floody for most people.
Grieflar
Grieflar's picture
Last seen: 11 months 1 week ago
Very positive review.
Just keep this below in mind and what it may cause:
http://budgetlightforum.com/comment/1014957#comment-1014957
Gotta love the Swedish postal service – $9 added to every package from China…
Thanks
This is the optics that fit on the HC30 i use this exact one. It maybe better to get a different angle how floody do you want the beam to be? these optics have like no throw at all. You could use a diffuser if you want like half/half? Get a tiny hinge and piece of metal that fits over?
15 degree optics
15 degree optics
30 degree optics
30 degree optics
Buzzing Bulb
Holy Sh*t!
That is another brand off of my list.
Buzzing Bulb
Thanks
15 degree optics
15 degree optics
30 degree optics
30 degree optics
Thank dude!
Just how do you get the HC30 lens open?
Is it friction fit or glued?
It is screwed in. Its easy to open. I just used my palm.
Buzzing Bulb
Awesome dude thanks so much!
Also great review!!
