Not saying it’s a common issue, but you may want to verify that your M43 does in fact have heatsink compound under the MCPCB…
Also fixed the negative terminal plate, which had two cross threaded & stripped screws due to the holes in the battery tube being drilled slightly off center… Still need to remove the positive terminal plate in order to see why the driver PCB isn’t sitting flat, which is causing the battery tube to only make contact on one tiny small area of the driver… I 1st thought it was the battery tube not being cut perfectly perpendicular to the threads, but it’s actually due to the driver not sitting flat…
Welcome to BLF!
I think you are correct posting these issues here, not so much to press the manufacturer to get their stuff in order (even though you are presenting the issues in a thoughtful way, you do not give the manufacturer the opportunity to defend himself), but more to warn the flashlight community that something is going on with this flashlight, that from what I have read sofar was an example of perfect workmanship.
I noticed before companies like banggood don’t really pay much attention to getting a good thermal path between the mcpcb and heatsink (have had to file the edge of one to get it to fit before/lack of thermal compound) would have expected better from a premium light though.
@OP,
That made up for some pretty sad reading.
Waiting for the very same light to arrive.
But a noob question, with no thermal compound should it not drop quicker from turbo as a result?
Not to keen to open it as it arrives as first task, so what is the normal drop from turbo time?
My thought is if that time is about right it should be reasonable OK and if it “pass” a visual inspection.
-lyse99
I guess no.
No thermal compound means worse heat conduction from MCPCB to pill/driver where I believe thermo sensor placed. So when MCPCB is already hot driver still thinks that temp is OK.
That is the case if the thermal sensor is placed on the led board, for example Thrunite does this. This is not the case with the Noctigon; the thermal sensor is (most likely) on the driver, which is physically separated from the the led board (heat source).
Where did you get the light from?
@strango, hIKARInoob
Thanks for the explanations, makes sense.
But that means that if step down time do exceed with let’s say 30℅ that could indicate bad cooling compound. I guess the stepdown time can be found so I will look a bit for it and maybe a disasamble video as well
Well time will tell how it turns out
-lyse99
Is anyone aware that the M43 uses a special japanese thermal compound that dries totally when first hot and barely noticable even after the 1st hot session but it is THERE. Can be that OP has a real trouble case but keep this in mind.
That really do sound like one should change it anyhow or?
Strange they use such subpar product in a relatively expensive flashlight, also I thought I did read up in a decent way and got the feel that it was a pretty solid product before ordering, now I am not so sure of my investigational skills any more
Would like regular Arctic Silver that I use for my pc builds do the trick or is there better stuff to use in this case?
-lyse99
Not trying to “fanboi” over here, but I trust Hank at Noctigon to design and spec a proper product, and the number of happy Noctigon customers on this and other forums would indicate the same. The M43, as designed, is a fantastic product. That’s not to say that something unusual couldn’t have happened during the construction of this one light - any factory-made item is subject to a certain (hopefully small) number of defective items. But I hope nobody reading this jumps to the conclusion that something is wrong with most/all M43s. That’s simply not the case.
On the thermal compound issue, there really should be very little of the stuff in any light. Even the best thermal compound is inferior to a perfect metal-to-metal connection. Unfortunately perfect metal surfaces are really hard to achieve, so thermal compounds are used to “fill in the gaps” so to speak, but there should be only the minimum required to achieve that goal, not gobs of the stuff running out of the edges, like the cream in the middle of an oreo cookie.
Just not Double Stuf.
@lyse99: no, it should be fine just the way it is. This kind of thermal conductor is like a glue. It’s there, makes the connection and bonds the surfaces, period. Once you open it the bonds crack and will not work as it should anymore. Clean surfaces with IPA and arctic silver will do the job, but as said before only in limited amount.
If the OP is a troll post at least it is a clever one, the poster knows his flashlight stuff to compose a post like this.
The evolution from Rickrolling to Meteorrolling.
The LED PCB is held in by screws, so no, that is not thermal adhesive it is just thermal paste.
Not said it’s thermal adhesive but it’s like a some kind of glue or something transparent totally dries and Hank applies it very carefully in a really small amount. watch my wording
Anyhow I have gone thru all the fonarevka forum topics of the Meteor (the M43’s original place of birth) read thousands of lines seen some issues and defects but not a single tint shift case. So either the OP got a real monday lemon or confused the M43 with any random Manker light…
In English adhesive is another word for glue, they mean the same thing.
You said “is like a glue. It’s there, makes the connection and bonds the surfaces”
No it is not, it is just thermal paste.
Good thermal paste like MX-4 does not have curing time and does not dry out.
Only thermal epoxies/adhesives or cheap thermal pastes dry out.
Hey, thanks for educating me :partying_face: It’s too late here in the east to go and look up the corresponding topic where it was described by Hank or Richard what that special thermal conductive stuff is, but will do later and send you. Best word I got for it is LIKE glue: once you open the light and separate the mcpcb from the shelf the thermal stuff will not work any more so it’s definetly not a thermal paste.
That’s exactly how thermal paste works…
When you separate the two surfaces you need to reapply it because otherwise air bubbles will get trapped and affect performance…
