Lumintop SD26, EDC25; Nitecore NU30 - really nice price (CLOSED)
Edit: April 2 - This activity is Closed.
Video review of the EDC25 by vestureofblood: An Everyday Carry You Need
Review by zeremifico: Lumintop SD26 photo review - Discount coupon available - disassembly & mod to follow
EDIT: Mar 14: Code for NU30 available via request by posting here
EDIT: FEB. 17: Code for both lights now available, Guaranteed, lowest price, just post here and ask
EDIT: FEB. 16: SD26 code is available; EDC25 to sent when available (due to system glitch)
BOTH CODES WILL BE SENT TO ALL POSTERS IN THIS THREAD THAT ASK FOR CODE AS IT BECOMES AVAILABLE
SD26: http://www.lumintop.com/sd26.html
Main Features:
● Utilizes CREE XP-L HD LED, boasts max 1000Lm output, 10600cd peak beam intensity and 205m far throw distance
● Intelligent Li-ion battery charging circuit, integrated micro USB charging port is water, dust and impact resistant
● Advanced temperature regulation system allows for adjusting output performance according to body temperature
● Lock-out: at Moonlight mode, long press for 8s, the light turns off and flashes indicating lock-out, cut off the power to unlock
● Waterproof in accordance with IPX-8 ( submersible to 2 meters )
● Runs on 1 x 26650 battery or 1 x 18650 with adaptor ( NOT included )
● High strength aerospace aluminum alloy construction with anti-scratching type HAIII military grade hard-anodized finish
● Double-side AR coated tempered lens resists impact and thermal shock, maximizes light transmission up to 99pct
● Reverse polarity protection / memory function / anti-rolling design / dual spring-loaded impact absorption mechanism / tail stand
Output and Runtime:
Turbo: 1000 - 600Lm, 1.66 - 3.33h
High: 530Lm, 4.5h
Mid: 170Lm, 18h
Low: 45Lm, 60h
Moonlight: 1Lm, 45 days
Strobe / SOS / Aviation Signal: 1000Lm
EDC25: http://www.lumintop.com/lumintop-edc25.html
Main Features:
● Uses Cree XP-L V5 LED with a lifespan of 50000 hours, max 1000 Lumens
● Hidden Micro USB charging port, red and green indicators display charging process
● Easily change between Tactical and Outdoor settings
● 6 variable modes: Low - Mid - High - Turbo - Strobe - Moonlight
● Tactical tail switch with momentary-on function
● Side switch to select outputs under Outdoor mode, only capable of mode changing under Tactical mode
● Low-voltage indicator is built into side switch, it flicker faster with lower power
● Automatically changes to LOW mode when remaining battery is too low, and gear cannot be changed
● Digitally regulated output maintains non-flickering constant brightness
● Optimized ultra-precise reflector offers 205m far reaching beam
● Double-side AR coated tempered window resists impact and thermal shock, maximizes light transmission up to 99pct
● Powered by 1 x 18650 or 2 x CR123A battery ( not included )
● Memory function / reverse polarity protection / stainless steel clip / anti-rolling and anti-skidding design
Note: flashlight can not be charged when using CR123A batteries
Interested in the SD26
Put me on the “interested” list, please.
Interested…
interested in both.
Interested in both.
Interested SD26 :slight_smile:
interested in both, thanks
Interested in both. :slight_smile:
are there NW or XPL HI versions availiable or is it easy to modify?
Hopefully later today l will receive the codes. :beer:
I would like to see your price for the sd26:)
Interested in both, price depending, thanks!
I would also like to see the price for the SD26 please.
:email: s will be sent most probably today…
details when available please
Sd26 please!
Code for the SD26 to be sent out first….
EDC25 code cannot be generated at the moment due to system glitch.
Interested in both, price depending.
Thanks!
