Test/review of Soshine 9V LiIon 650mAh (White)
33 posts / 0 new
HKJ
HKJ's picture
Last seen: 43 min 14 sec ago
DSC_7251
Official specifications:
  • Type: Rechargeable Li-Po
  • Dimension: (48.5+-0.5)*(26.1+-0.2)*(15.4+-0.3)mm (max)
  • C5mAh: 630(mini)
  • C5mA: 650mAh
  • Nominal Voltage: 7.4V
  • Capacity Nominal: 650mAh
  • Capacity Minimum: 630mAh
  • Service Life: 1000cycles(>=60% C5mAh,0.2C discharge)
  • Weight: 28g
  • Charging Voltage: 8.4+/-0.15V
  • Ambient Temperature Range: Charging: 0-45 centigrade, Discharging: -20 to +60 centigrade, Storage: -20 to +40 centigrade
Soshine%209V%20LiIon%20650mAh%20(White)-info
This is a two cell LiIon rechargeable battery.
It has over voltage protection at 8.63 and 8.64 volt.
It has over discharge protection at 5.08V and 5.57V.
DSC_7252DSC_7253
DSC_7254
DSC_7255
DSC_7256
DSC_7257
Soshine%209V%20LiIon%20650mAh%20(White)-Capacity
The two batteries are just about the same capacity.
The voltage is lower than NiMH and more like a nearly empty alkaline, but it will stay this way for a very long time.
Soshine%209V%20LiIon%20650mAh%20(White)-CapacityTime
Soshine%209V%20LiIon%20650mAh%20(White)-CapacityTimeHours
Soshine%209V%20LiIon%20650mAh%20(White)-Energy
Soshine%209V%20LiIon%20650mAh%20(White)-Charge
Conclusion
These batteries have more than double capacity compared to NiMH 9V batteries and are close to a alkaline battery at low load, except this battery will maintain high capacity and voltage at high load.
In moderate to high load situations this looks like a good replacement for alkaline.
Notes and links
Compare to other 9V batteries: Alkaline/NiMH/Lithium/other
light-wolff
Last seen: 1 week 3 days ago
Do they have overcurrent protection?
MRsDNF
MRsDNF's picture
Last seen: 1 hour 54 min ago
Taken from above.
Thanks for the review HKJ.
HKJ
HKJ's picture
I would expect it, but a fast test do not show any.
I need to charge the battery fully to do a correct test, but it looks like it may be at a rather high value for the cell size.
MRsDNF
MRsDNF's picture
Over current, over voltage , I’ll learn to read one day. Facepalm
Barkuti
Barkuti's picture
Last seen: 1 hour 20 min ago
Is it normal for those over-voltage protection figures to be so high? Heck, I was going to suggest these could be assembled with 4.3V cells or about, since there's also around a 10% less capacity than wrapper claimed. These product overstatements seem too common between rewrappers, and the higher the figures, the bigger the lie. Flat Stare
Cheers Party
HKJ
HKJ's picture
The over voltage protection is not that high, it would say it is a good value.
But the over current protection is way to high, I could draw above 2A from the cell (I will get more precise value when the cell is fully charged).
HKJ
HKJ's picture
With a fully charged battery I could draw 4A without any protection kicking in. I did not try higher current, because I need the batteries for some other tests.
Barkuti
Barkuti's picture
Maybe there's no over-current protection? With the internal resistance I observe in the graphs for this 2S setup, wouldn't the over-discharge protection trip between 2 to 4A if the state of charge is low enough? It seems to me so. Steve
Cheers Party
HKJ
HKJ's picture
Barkuti wrote:
Maybe there’s no over-current protection? With the internal resistance I observe in the graphs for this 2S setup, wouldn’t the over-discharge protection trip between 2 to 4A if the state of charge is low enough? It seems to me so. Steve
Cheers Party
If you draw the current for some time the over discharge will trip, but not for a short 4A burst (Few seconds).
Normal single cell protection chips have over current protection, this is done by measuring the voltage across the transistor. Using a very good transistor will increase the current trip point. But I do not know the type of chip used in this battery and if it supports that type of over current protection.
sandanbob
Last seen: 2 weeks 5 days ago
Do these need a special charger?
HKJ
HKJ's picture
It is best to use a LiIon charger, but a normal 9V charger can be used, then termination will be done by the over voltage protection.
sandanbob
Thanks! These sound nice.
DroneFisherMan
Last seen: 7 months 1 week ago
Can anyone help me understand the Voltage part of this battery?
I want 9V battery for my Bayangtoys X16 drone Tx.
The remote controller says it needs 6AA 1.5 V batteries, so total is 9V
If I read the instructions on this battery it says : “Rated Voltage: 7.4V”
Then how come this is 9v ? If anyone can recommend me a good battery which can maintain 9v then I would appreciate the help
HKJ
HKJ's picture
Alkaline batteries are 1.5V when full and below 1V when empty, this means a 9V battery is first supposed to be empty below 6V.
A 9V LiIon battery is 8.4V when fully charged and will be empty when at 6V, this matches fairly well with the 6 Alkaline.
Most equipment will work fine with a LiIon 9V battery, but there are probably a few exceptions.
I have a collection of discharge curves for 9V batteries with different chemistry here:
https://lygte-info.dk/review/batteries9V/Common9Vcomparator.php
DroneFisherMan
WoW @ that comparison sheet.
May i know your opinion on which battery to buy for my Tx which requires 6 1.5V AA batteries?
HKJ
HKJ's picture
I would not replace AA batteries with a 9V battery, I doubt it can deliver power enough (A LiIon 9V probably can for some time).
My favorite AA replacement is eneloop either original or rebranded, as long as they are charged correctly and not run totally empty they may well last 10 years (That is the 1900-2000mAh type)
Drecandlere
Drecandlere's picture
Good post!
DroneFisherMan
When you say “(A LiIon 9V probably can for some time)” Which LiIon 9V battery are you referring to ?
A:) I saw those eneloop rechargeable batteries but they have 1.2 V instead of recommended 1.5 V, so I use 6 1.2V , it would be 7.2V
B:) Can I get 9v LiPo battery ?
HKJ
HKJ's picture
It is the same story, NiMH (Eneloop) starts at about 1.4V when full and are empty at about 1.0V, this matches Alkaline fairly well (Except a few devices)
I do also have a lot of AA/AAA curves: https://lygte-info.dk/review/batteries2012/CommonAAcomparator.php
Top part is rechargeable batteries (NiMH), bottom part is primary batteries (Alkaline)
9V blocks is two LiPo cells.
A good place to check for larger LiPo batteries is Hobby King:
https://hobbyking.com/en_us/batteries-chargers/batteries/lipo.html?confi...
Look for two cell type.
To charge these cells you need a “Hobby Charger”, they can also be found at there, but notice that many of them is 12V powered, not mains powered.
DroneFisherMan
I thought 2 cell is 2s which means 3.7 × 2 = 7.4 V
Am I right?
HKJ
HKJ's picture
Am I right?
As I wrote above that matches Alkaline fine enough.
DroneFisherMan
Am I right?
Oki doki bro. Thanks
DroneFisherMan
will this battery be able to deliver the 9v performance?
9.6 V 2400mAh
HKJ
HKJ's picture
“9.6 V 2400mAh”:https://www.aliexpress.com/store/product/9-6-V-2400mAh-Remote-Control-To...
When charged it will start a bit above 11V and then drop to 8 volt during use.
It is eight AA sized NiMH cells.
I doubt they are low self discharge types, i.e. they will self discharge in less than a couple of months
DroneFisherMan
If its rechargeable then volt should be 1.2V and 8 AA means 9.6V? Right?
My concern is will it burn my circuit board if i supply more than 9 V?
Thanks for taking time to help me out
HKJ
HKJ's picture
If its rechargeable then volt should be 1.2V and 8 AA means 9.6V.
No, for rechargeable batteries the voltage is some sort of average voltage, that means when charged the voltage will be higher and when empty the voltage will be lower.
At higher load a NiMH battery will have higher voltage than a Alkaline cell, even though it is only rated 1.2V and Alkaline is rated 1.5V. I wrote a bit about it here: https://lygte-info.dk/info/ComparisonOfAABatteryChemistry%20UK.html
DroneFisherMan
thanks man
so last question then I am done eating your brain
If i use that 9.6V battery will it burn the electronics inside compared to 9 V LiIon rechargeable battery you said could give me some performance
DroneFisherMan
Conclusion
The voltage printed on the cells, do not have much relation to actual voltage when using the cell.
Alkaline marked with 1.5 volt has lower voltage than NiMH marked with 1.2 volt at higher loads (Like a flashlight on high). At very low loads alkaline will be better than NiMH.
Lithium is the top performing chemistry for high voltage, high capacity and fairly high current at the same time (It is also the best at low temperature).
NiZn has too high voltage and with the short lifetime it is not really interesting.
LiIon may be interesting for devices that requires more voltage than NiMH can provide, but watch out for the self discharge.
+1 for this info man!
HKJ
HKJ's picture
Probably not, but there is no guarantee.
DroneFisherMan
After reading that article on actual voltage and voltage under load, I have decided to buy eneloop AA 1.2 rechargeable batteries. I hope i get desired voltage to run the Tx
Even though it needs 9V
