[UPDATE:v1.7.1,Q8&1chanOTSM]bistro-HD, bistro your way. OTSM, eswitch(devel), Vcc reads, safe_presses, turbo timeout...
245 posts / 0 new
Flintrock
Last seen: 2 years 1 month ago
Super.  That should be a good solution for you.  I'll probably look into these dual switch cases more soon though.  They were the last afterthought in building HD actually.  Anyway, your post and some others had me wanting to first organize things even better for many configurations.  That's pretty much done.  Making new configurations is relatively easier.
Lexel
Lexel's picture
Last seen: 3 hours 18 min ago
If you document those changes in a text file people can change the code themself as they need or add mire comments in the .c file
Flintrock
There's a whole bunch of comments already, more comments than code really, but almost any time I look at a code I read them and add more.  I think the part of the code I pointed out to you is pretty well commented, especially being it's litterally the latest lines added to the code (that might not even remain the same), but suggestions for clarification are welcome.   There can never be an instruction manual for everything anyone might want to do to a code.  At some point you have to have look through the actual program lines and understand what they do.  If you're not sure exactly what wake_time_med does, you press cntrl-f, type wake_time_med, and find every place it's used and see.
Anyway, this is more along the lines of something that I'll likely end up just including soon as a config option and possibly in a predefined build configuration.  Most people will just use pre-configured builds or change a feature or two in the configuration.  A big part of what I've done in HD is actually to make this all more clear and make the options all play well together again. Having the automated build helps keep that in control too, since the developer now sees immediately if one configuration fails to build.
Flintrock
I have two bugs/typos.  That's good because it solves problems.  One in particular may explain a bunch, certainly should break OTC in the original post.  The error is
PORTB=~DDRB;
should be
PORTB|=~DDRB;
The difference is the first one disables OTC cap charging, which meant OTC builds probably didn't change modes at all, oops.  I was only testing with OTSM at the end.
The other bug is
#define OPT_firstboot (EEPSIZE-1)
should be
#define OPT_firstboot (EEPSIZE-8)
could cause interference between reset toggle and muggle mode toggle. I'll probably post a bug-fix only build shortly, but I'm working on a much overhauled version with all new bugs Wink .. and need to get some of those sorted out, the ones I know about at least.
The OTC bug, may well explain the OTSM problems, as it means the OTC pin was floating, which can drain power during sleep, in random ways.  It might explain it, or might not.
Flintrock
Well that did get the driver working properly in a normal OTC build, but it didn't solve the OTSM bug and in fact that code path wasn't relevant for OTSM.  This really seems to be a hardware issue and is a mystery still.
Flintrock
At lexel, I've been working on a manual to go with the next release.  This is a good process because it makes one think through things.  I realized that actually you should get the behaviour you want just by building an e-switch only build, no OTSM or OTC enabled, preferably no off-time cap on the board.   The clicking switch will obviously always "work" no matter what configuration you use.  In e-switch-only, with a standard small C2 cap, the click time will always default to a long press on a full power-off.
If you don't use memory mode this means it will reset to the first mode, so you'd just want to setup the first mode as your signaling brightness.  Or, you could turn on mode memory, and it will just always stay in the last mode, and you can signal in whatever brightness you want.
Normally many fast presses hit the menu, but that won't happen, because they will get interpretted as long presses.  Only the e-switch will be able to access the menu.
Big new release coming soon with lots of good stuff, but I hope it's a little better tested this time (still will have much that isn't too though).  I'll try to remember to include an e-switch only build for you.
Flintrock
Updated OP with new version.
Lots of new stuff including many build configurations (that you can pattern new ones off of) especially for all the bistro variants.  Especially, it has a  biscotti-HD build included with all the latest space savings and as a result some added features (specifically a more stable noinit method, and (untested) turbo timeout/bump-up, and room for you to configure in a couple more yet.  More especially, at least some of it works this time.  The TAv1-OTC hex and its battcheck are pretty well tested on attiny25 (everything except thermal calibration, haven't really tried to test that closely, but never messed with it much either).
I wanted to get the universal concept really flushed out and a bit more stable (many of the space savings techniques resulted in a bunch of changes to iron out) before pushing forward with advancing new features too much more, although there are some new ones.
Flintrock
OTSM is fixed.   (OP updated)  and is working perfectly on a TAv1 17mm light.  I don't see any reason this shouldn't become the default setup for these lights.  It's just so much better than OTC.  As this TAv1-OTSM build is now really (was always meant to be) the flagship HD build, maybe I need a new name for it.
Below are some details about how to build it, also found in the Manual and the OP.  In the end this worked so well that it's likely possible to cut some corners, like use cheaper ceramic caps.  Personally I probably just wouldn't, but it may work fine.
 VIII.1 Parts and build for tested TAv1 board
OTSM is working better and better, but getting it there required a combination
of software work and the best parts.  It may be possible now to use cheaper or
lesser parts since OTSM performs a little better than needed with these, but
these are tested and work.
MCU:
It's required to have BODS support for the mcu (see theory below). From page 36
of the manual this requires:
• ATtiny25, revision E, and newer
• ATtiny45, revision D, and newer
• ATtiny85, revision C, and newer
[This note not in manual yet: Revision letter is lower left most letter on bottom of Attiny 25.  I forgot on attiny 45 where it is, might be on top.]
The spec for OTSM also requires V version (10Mhz, low voltage version) chips.
You might get by without it, but it won't work as well and may cause
corruption.
Unfortunately most ATtiny 85s reported off the shelf have been revion B, for
the past many years even.  They don't work.  So far Attiny25, attiny25V,
attiny45 and attiny45 v's where reports exist on this, have been of recent
enough version.  Of course attiny25V is available in the smaller footprint and
fits 17mm TAv1 boards. At the time of this writing all HD features including
OTSM can fit on an attiny25.
Diode part number: RB751V40T1G
http://www.onsemi.com/pub/Collateral/RB751V40T1-D.PDF
This is the MCU protection diode.  It isolates voltage from the C2 cap that
powers the MCU while input power is down.  It was chosen for its low leakage
even at high temperatures.  Leakage below 1 or 2 uA is probably fine.
C2 cap (powers MCU during off time, quality counts here)
Cap part number: 298D476X0010P2T
http://www.vishay.com/docs/40065/298d298w.pdf
This cap was chosen to get the most capacitance in an 0805 possible and because
Tantalum does not suffer from DC bias de-rating or temperature fluctuation.
Capacitance this high (47uF) in an 0805 are all low voltage.  For Ceramic if
the DC offset is more than about 1/3 of the rated voltage the capacitance
starts to drop, some times a bunch.  This cap does have a large tolerance
though unfortunately.
Voltage divider:
Tested with R1 of 1K and R2 of 3.3K  R1 should be no more than about 1/3 of R2,
but this ratio should be ideal for OTSM performance in a 1S light (but only in
a 1S light).  Lower values can improve OTSM performance, at the expense of
higher mood mode drain.  If you use lower quality caps or diode, you can try to
add a bleeder of about 500ohm to gain a little advantage on off time, not much.
OTC:
None, unpopulated.
C1:  1uF (see TA instructions for part numbers)
For all other parts, see the Texas Avenger instructions.
ImA4Wheelr
Last seen: 2 weeks 10 hours ago
I haven't had a chance to read in detail yet, but this sure seems like some really exciting stuff you're doing here Flintrock.
Flintrock
Click click, whoo.. lol.  Fun at least. Don't forget Mice C and flashy mike who took the early talk is cheap attitude to get this all going.
Flintrock
Version 1.1 posted (see OP)
Includes firmware for an LDO OTSM TA build.  Latest Build instructions will be maintained in the Manual, and the OP, but the excerpt is below.
Also split the dual switch build into a noinit version and an OTSM version.  The OTSM version is specifically targeted at lexel's "option 3", but an option 1 configuration should arrive soon.
These are not tested builds/firmwares, but the differences from the regular OTSM versions are fairly straightforward and those differences have each been independently tested.  The LDO build should work.  Dual switch, enh, probably.  No guarantee or implied anything.
VIII.1b Parts and build for TAv1 board for LDO (2S, 3S etc)
Quick version:
See section VIII.1a for mcu, cap and diode selection.
Place the diode on the R7 resistor pad with the anode (+ side) pointing away
from C2. No OTC cap is needed. Use the following divider resistors, in ohms.
        R1      R2
2S: 1780   2210
3S: 2250   1500
4S: 2870   1100
Should be 1% or better.  Dropping R2 by  1% or 2% might help get full range of voltage read on the very top end and the risk of pushing the specs slightly at the low end. Not a big deal either way.  The default calibration is centered around the values above though.
No bleeder. That's it.
For all other parts, stick with the original Texas Avenger instructions.
Long version:
For 2S or more build, the attiny must be fed power by some form of voltage
regulation such an LDO.  This means that Vcc (input voltage) cannot be used to
measure the battery voltage.  The divider must be used.  Furthermore because
the divider pin must stay logic high to indicate power on, the 1.1V reference
cannot be used.  The REFERENCE_DIVIDER_READS_TO_VCC option must be used (It's
compiled into the LDO firmware)  This reads pin voltage as a fraction of Vcc
with Vcc being the max, allowing the highest possible divider voltages.
There's some difficulty here because a low battery, 2.5V/cell is 0.6 the
voltage of a full battery: 4.2V/cell.  0.6Vcc is also the maximum trigger level
for a pin change interrupt, which indicates a click and puts the light into
sleep. In reality the trigger level should be below this, but by spec it can be
this high.  So we need the divider voltage to really stay as high as possible.
Furhtermore Vcc is reduced from the LDO voltage by the diode voltage. This
fluctuates slightly with temperature and current, so we need to estimate this
max voltage as well as possible. From the diode spec sheet a maximum diode
voltage of about 0.4V at 2 to 4mA is seen, but more typical is 0.35V and this
should be correct within 0.1V even when hot.
Parts:
Using a TA generation 1 (v1) LDO board, a diode must be added, the same one as
for the 1S configuration above.  The diode can be added in place of the R7
0-ohm resistor.   The same caps are used as for the 1S OTSM version.
The only other difference is the correct resistor values should be chosen. We
want a total resistance R2+R1= about 4kOhms. We need the voltage on pin 7 to be
equal to the LDO voltage minus the diode voltage, ie Vcc, when the batteries
are at max voltage, Vbm.
So the divider  should be R2/(R1+R2) = Vcc/Vbm.
Following the TA build specs and the diode used here, Vcc is 5.0-0.35 = 4.65V
This gives R2 = Vcc/Vbm *4kOhm.
And R1 = 4kOhm-R2
here is the calculated table for various voltage levels:
        R1          R2           Vcc/Vbm ideal:
2S:     1786        2214           0.5536
3S:     2524     1476           0.3690
4s:     2892     1107           0.2768
Of course these resistors don't exist, so we need to look for something close,
with the ratio being the most important thing.
       R1          R2            Divider Error %
2S:    1780        2210          0.06
3S:    2250        1500          0.36
4S:    2870        1100          0.1
These should be in 1% tolerance or better.  Any inaccuracy here pushes the
measureable voltage range up against the spec limits.
MRsDNF
MRsDNF's picture
Last seen: 19 hours 34 min ago
Thumbs Up
mattlward
mattlward's picture
Last seen: 9 hours 13 min ago
So, please humor me… It looks to me like a normal AT25 driver such as the X6 driver could be converted to OTSM if the OTC was removed? Or am I making this way to simple?
EDC rotation:
FW1A, LH351D 4000k (second favorite)
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Nichia 4000k sw40 r9080 (favorite light!)
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
S2+, XM-L2 T6 4C
Flintrock
You mean attiny25? I'd have to consider case by case, (lots of the details are explained in the manual).  But generally it should be possible to convert one, so long as there's a place to put a diode between the voltage divider and the mcu input bypass cap and so long as the input bypass cap is at least an 0603 footprint (there may always be ways to squeeze past these rules with enough hacking/squeezing).
No, just removing OTC isn't enough.  You need to follow the full parts selection above for diode, mcu bypass cap ("C2"), and divider resistors. I should make it more clear but the diode and cap for the LDO lights are the same as for the 1S.  I also forgot to point out that the anode of the diode (+) should point away from C2, but I guess that's obvious.  I'll add a picture shortly.  You can surely find other components than the ones I found that will work.  I've gotten tests working with very different resistor combinations too (for 1S, LDO has pretty strict requirements there), but not just anything will work, and you can be pretty sure the original parts won't work. The ones I list are what I know works.  They probably aren't the cheapest, but figuring out how best to cut corners wasn't my goal.
I still need to stop and remember the issues with lighted tailcaps, if there are any issues.
Flintrock
Oh at the moment I don't know any way to make this work on a zener driver, not without replacing the zener with an ldo at least. The LDO is  needed for the LVP voltage reference.
LightRider
LightRider's picture
I’ve been trying to plow through all this information. It’s been a struggle but I know that if I keep at it I’ll eventually get it:)
It would be great if someone could write do a write up of the process. Kind of like comfrchair did here. That’s the thread that really got me going. Basically go through an example build and take photos/screen shots along the way. This is asking a lot though. And most who are capable of this have already done so much. It would be helpful though…
Thanks for all your efforts!!!
Flintrock
 Hi lightbringer.  Let me know what  you're trying to do and I'll walk you through it.  I will try to add picture of TA's boards to explain which things to change.  Using a specific example, it's very simple.  the instructions above are such examples, and apply directly to his boards.  Just change C2, R1, R2, and the diode (and the OTC, well the lack of it) exactly according to what's said there.  That's it. And flash the 1S hex for 1S or the LDO hex for regulated mcu input.
If you're trying to get a different driver board working or there's something you don't get there, just let me know. I added a bunch of background to the instructions so that people can extrapolate to new scenarios, but if you just  follow the component list for the basic TA boards, you should be fine.
I'm pretty interested in getting something working on your dual switch Supfire A2, but that stuff is much more experimental right now.
Flintrock
@mattlward, I almost forgot, it's also highly recommended to change out the mcu to a V version, either attiny25 or attiny45.  See post 69 above.
LightRider
Flintrock wrote:
 Hi lightbringer.  Let me know what  you’re trying to do and I’ll walk you through it.  I will try to add picture of TA’s boards to explain which things to change.  Using a specific example, it’s very simple.  the instructions above are such examples, and apply directly to his boards.  Just change C2, R1, R2, and the diode (and the OTC, well the lack of it) exactly according to what’s said there.  That’s it. And flash the 1S hex for 1S or the LDO hex for regulated mcu input.
If you’re trying to get a different driver board working or there’s something you don’t get there, just let me know. I added a bunch of background to the instructions so that people can extrapolate to new scenarios, but if you just  follow the component list for the basic TA boards, you should be fine.
I’m pretty interested in getting something working on your dual switch Supfire A2, but that stuff is much more experimental right now.
Ok. I haven’t actually started something yet as I’ve not been confident enough. It’s good to know there will be help available for when I jump in:)
Supfire A2 dual switch? The a2 is single e-switch…
Flintrock
Oh I guess I got confused on the supfire.  Well I like it anyway, and eswitch bistro still looks good for it to me.
yeah.  I can't promise tons of  time, but what you're asking is easy.  Really there's nothing harder about this than building the normal TA setup.  It's just a different component list.  That's all, and while maybe I didn't write list clearly, those components are known now, so just  have to buy the right ones and solder them on the right place.  That's it.  So sure, I can help with that, and any bugs that show up I hope, although in the basic OTSM build, I'm not seeing any.
Flintrock
I updated the LDO post (post 72) with a short version, hopefully it makes it a little more clear.
RotorHead64
RotorHead64's picture
Last seen: 6 months 1 week ago
Awesome, awesome, awesome!
In VIII OTSM of the manual you say,
"The spec for OTSM also requires V version (10Mhz, low voltage version) chips. You might get by without it, but it won't work as well and may cause corruption."
I guess I need new chips undecided. All the 25's I have from MTN are the 20SSU "high voltage" variations.
Flintrock
RH you can try it.  I'd recommend reducing the divider resistors to 500ohm total or adding a 500ohm bleeder, and don't cut corners on the cap.  To be  honest, I suspect you'll get by with it.  At worst, you might have trouble getting medium presses when your battery is at 2.9V.
There is the potential corruption issue.  Mike C says with the chips running extended times at low voltage he can verify EEPROM corruption.  For awhile this bothered me, and I've seen some comments of lights misbehaving that do smell like corruption, but I can't actually see how eeprom corruption breaks the light. That's just configuration values, things like is memory enabled or not.  The main menu should  operate regardless of what the eeprom state is, and you should be able to get to reset, but I'm not 100% sure that some corner case can't break something.  And is it possible to corrupt program memory?  Again, I'm not sure.    I have seen the non-V chips just occasionally do strange things when in very low voltage, with improper BOD setting, like lock up in a high current state, and so you may just  get that the clicks occasionally don't work.
The specs documented are safe, but I'm sure over time people will figure out what they can get by with.
By the way, there's presently a known bug where turbo tap up doesn't work in the biscotti-HD build.  Will be fixed in next version.  Those features will move out of the untested category.
Flintrock
I have a draft of options for all 2-switch combinations including LEXEL's dumb click switch (his option 2).  Some testing to do. Nothing posted yet, plans for next release are in OP.
Flintrock
Posted version 1.3.
Version 1.3 (there was no 1.2)  adds new thermal control, dual switch operational modes, and latest TA modegroups.
http://s000.tinyupload.com/?file_id=42489563655022665614 (link is external)
Detailed changes:
-TURBO_TIMEOUT tap-up didn't work, probably fixed (not 100% tested).
-ESWITCH menu lockout didn't work, maybe fixed it, took a stab at it anyway, but no testing.   Never was sure I liked it anyway.
-New TA v1.3 modegroups are  included.  I've also added 1 old mode from original and one hybrid of my own.  The modegroup file for details, the extra modes are not well documented yet.
-OTSM_powersave which is not only for OTSM, is now available to save power on attiny13's too now (4mA to 2mA for on-current if similar to attiny25).
-New temperature step-down option, like BLFA6 turbo timeout and tap up, except the drop down is temperature-triggered. A minimum (not max) time in turbo is set to 10s by default.
-Both the minimum time and the level to step down to are configurable.  All levels above that will get thermal protection (except strobes, in bistro way, reading temp is too slow to work with strobes).
More space savings, about 50 bytes, but this was mostly re-used by the new thermal stepdown and added modes.
-Trying to clean up cap-timing section and comments, adding clear preprocessor sections for every possible switch and timing combination.
  1-switch:  no_init, OTC, OTSM
  2-switch:  Eswitch +  nothing, no_init, OTC, OTSM, or lexel mode.
 -Dual switch noinit has a better chance of working correctly now (no eswitch or dual switch lights have been fully tested).
 -Dual switch OTSM is discontinued for now.
 -Dual switch dumbclick option/build is added.  by request of Lexel, the power switch does nothing.  It comes back on in the same mode it went off.
- Dual switch turboclick option/build is added.  Variation of lexel request (that I like), power switch always comes on in first hidden mode (typically turbo).
Ideas for farther ahead:
Try shortening medium click in OTSM, may require adding finer timing resolution for all times, or possibly just early times. (has a cap performance cost, but it's performing better than needed now).
 Maybe rework dual switch stuff so every click type can be given assigned an action type in the configs.  Hard to keep the programming tight, and clean, but avoids endless options, I don't have a full vision for how to implement it yet, many details.
 In particular considering reverse click order for power switch, maybe separately from above plan.
Here are the present build sizes, not updated in the manual:
text    data     bss     dec     hex filename
      704       0      41     745     2e9 .\bin\battcheck-4channel-dual-switch-HD-attiny25.elf
      712       0      41     753     2f1 .\bin\battcheck-4channel-dual-switch-HD-attiny45.elf
      712       0      41     753     2f1 .\bin\battcheck-4channel-dual-switch-HD-attiny85.elf
      356       0      29     385     181 .\bin\battcheck-biscotti-HD-attiny13.elf
      372       0      29     401     191 .\bin\battcheck-biscotti-HD-attiny25.elf
      376       0      29     405     195 .\bin\battcheck-biscotti-HD-attiny45.elf
      376       0      29     405     195 .\bin\battcheck-biscotti-HD-attiny85.elf
      396       0      33     429     1ad .\bin\battcheck-BLFA6_EMU-HD-attiny13.elf
      410       0      33     443     1bb .\bin\battcheck-BLFA6_EMU-HD-attiny25.elf
      414       0      33     447     1bf .\bin\battcheck-BLFA6_EMU-HD-attiny45.elf
      414       0      33     447     1bf .\bin\battcheck-BLFA6_EMU-HD-attiny85.elf
      542       0      35     577     241 .\bin\battcheck-classic-HD-attiny25.elf
      546       0      35     581     245 .\bin\battcheck-classic-HD-attiny45.elf
      546       0      35     581     245 .\bin\battcheck-classic-HD-attiny85.elf
      526       0      39     565     235 .\bin\battcheck-custom-HD-attiny25.elf
      530       0      39     569     239 .\bin\battcheck-custom-HD-attiny45.elf
      530       0      39     569     239 .\bin\battcheck-custom-HD-attiny85.elf
      530       0      41     571     23b .\bin\battcheck-default-HD-attiny25.elf
      534       0      41     575     23f .\bin\battcheck-default-HD-attiny45.elf
      534       0      41     575     23f .\bin\battcheck-default-HD-attiny85.elf
      688       0      41     729     2d9 .\bin\battcheck-dual-switch-dumbclick-TA-HD-attiny25.elf
      696       0      41     737     2e1 .\bin\battcheck-dual-switch-dumbclick-TA-HD-attiny45.elf
      696       0      41     737     2e1 .\bin\battcheck-dual-switch-dumbclick-TA-HD-attiny85.elf
      640       0      34     674     2a2 .\bin\battcheck-dual-switch-noinit-TA-HD-attiny25.elf
      648       0      34     682     2aa .\bin\battcheck-dual-switch-noinit-TA-HD-attiny45.elf
      648       0      34     682     2aa .\bin\battcheck-dual-switch-noinit-TA-HD-attiny85.elf
      660       0      41     701     2bd .\bin\battcheck-dual-switch-turboclick-TA-HD-attiny25.elf
      668       0      41     709     2c5 .\bin\battcheck-dual-switch-turboclick-TA-HD-attiny45.elf
      668       0      41     709     2c5 .\bin\battcheck-dual-switch-turboclick-TA-HD-attiny85.elf
      512       0      40     552     228 .\bin\battcheck-TAv1-OTC-HD-attiny25.elf
      516       0      40     556     22c .\bin\battcheck-TAv1-OTC-HD-attiny45.elf
      516       0      40     556     22c .\bin\battcheck-TAv1-OTC-HD-attiny85.elf
      588       0      41     629     275 .\bin\battcheck-TAv1-OTSM-HD-attiny25.elf
      596       0      41     637     27d .\bin\battcheck-TAv1-OTSM-HD-attiny45.elf
      596       0      41     637     27d .\bin\battcheck-TAv1-OTSM-HD-attiny85.elf
      576       0      40     616     268 .\bin\battcheck-TAv1-OTSM-LDO-HD-attiny25.elf
      584       0      40     624     270 .\bin\battcheck-TAv1-OTSM-LDO-HD-attiny45.elf
      584       0      40     624     270 .\bin\battcheck-TAv1-OTSM-LDO-HD-attiny85.elf
      568       0      34     602     25a .\bin\battcheck-trippledown-HD-attiny25.elf
      572       0      34     606     25e .\bin\battcheck-trippledown-HD-attiny45.elf
      572       0      34     606     25e .\bin\battcheck-trippledown-HD-attiny85.elf
     1926       0      42    1968     7b0 .\bin\bistro-4channel-dual-switch-HD-attiny25.elf
     1934       0      42    1976     7b8 .\bin\bistro-4channel-dual-switch-HD-attiny45.elf
     1934       0      42    1976     7b8 .\bin\bistro-4channel-dual-switch-HD-attiny85.elf
     1022       0      29    1051     41b .\bin\bistro-biscotti-HD-attiny13.elf
     1112       0      32    1144     478 .\bin\bistro-biscotti-HD-attiny25.elf
     1116       0      32    1148     47c .\bin\bistro-biscotti-HD-attiny45.elf
     1116       0      32    1148     47c .\bin\bistro-biscotti-HD-attiny85.elf
     1078       0      33    1111     457 .\bin\bistro-BLFA6_EMU-HD-attiny13.elf
     1216       0      34    1250     4e2 .\bin\bistro-BLFA6_EMU-HD-attiny25.elf
     1220       0      34    1254     4e6 .\bin\bistro-BLFA6_EMU-HD-attiny45.elf
     1220       0      34    1254     4e6 .\bin\bistro-BLFA6_EMU-HD-attiny85.elf
     1670       0      36    1706     6aa .\bin\bistro-classic-HD-attiny25.elf
     1674       0      36    1710     6ae .\bin\bistro-classic-HD-attiny45.elf
     1674       0      36    1710     6ae .\bin\bistro-classic-HD-attiny85.elf
     1744       0      40    1784     6f8 .\bin\bistro-custom-HD-attiny25.elf
     1748       0      40    1788     6fc .\bin\bistro-custom-HD-attiny45.elf
     1748       0      40    1788     6fc .\bin\bistro-custom-HD-attiny85.elf
     1750       0      41    1791     6ff .\bin\bistro-default-HD-attiny25.elf
     1754       0      41    1795     703 .\bin\bistro-default-HD-attiny45.elf
     1754       0      41    1795     703 .\bin\bistro-default-HD-attiny85.elf
     1940       0      41    1981     7bd .\bin\bistro-dual-switch-dumbclick-TA-HD-attiny25.elf
     1948       0      41    1989     7c5 .\bin\bistro-dual-switch-dumbclick-TA-HD-attiny45.elf
     1948       0      41    1989     7c5 .\bin\bistro-dual-switch-dumbclick-TA-HD-attiny85.elf
     1688       0      35    1723     6bb .\bin\bistro-dual-switch-noinit-TA-HD-attiny25.elf
     1696       0      35    1731     6c3 .\bin\bistro-dual-switch-noinit-TA-HD-attiny45.elf
     1696       0      35    1731     6c3 .\bin\bistro-dual-switch-noinit-TA-HD-attiny85.elf
     1912       0      41    1953     7a1 .\bin\bistro-dual-switch-turboclick-TA-HD-attiny25.elf
     1920       0      41    1961     7a9 .\bin\bistro-dual-switch-turboclick-TA-HD-attiny45.elf
     1920       0      41    1961     7a9 .\bin\bistro-dual-switch-turboclick-TA-HD-attiny85.elf
     1724       0      40    1764     6e4 .\bin\bistro-TAv1-OTC-HD-attiny25.elf
     1728       0      40    1768     6e8 .\bin\bistro-TAv1-OTC-HD-attiny45.elf
     1728       0      40    1768     6e8 .\bin\bistro-TAv1-OTC-HD-attiny85.elf
     1812       0      41    1853     73d .\bin\bistro-TAv1-OTSM-HD-attiny25.elf
     1820       0      41    1861     745 .\bin\bistro-TAv1-OTSM-HD-attiny45.elf
     1820       0      41    1861     745 .\bin\bistro-TAv1-OTSM-HD-attiny85.elf
     1792       0      40    1832     728 .\bin\bistro-TAv1-OTSM-LDO-HD-attiny25.elf
     1800       0      40    1840     730 .\bin\bistro-TAv1-OTSM-LDO-HD-attiny45.elf
     1800       0      40    1840     730 .\bin\bistro-TAv1-OTSM-LDO-HD-attiny85.elf
     1658       0      35    1693     69d .\bin\bistro-trippledown-HD-attiny25.elf
     1662       0      35    1697     6a1 .\bin\bistro-trippledown-HD-attiny45.elf
     1662       0      35    1697     6a1 .\bin\bistro-trippledown-HD-attiny85.elf
I still forgot to remove BLFA6_EMU-attin13.  It is too big for an attiny13 and should not be used.
Flintrock
Minor updated posted (see OP) to 1.3-r2.  The code is not changed.  Just added a one-click bat file buildall-AS.bat.  If Atmel Studio 7.0 is installed in the default directory then double clicking that file from the windows file explorer will re-compile all hex files, which can then be found in the hex/ subdirectory.  Editing the file :  Makefile in any text editor you can find the ONEBUILD option, remove the # comment sign and define a single configuration to compile instead of making them all.
This is intended to allow compiling with the Atemel Studio 7.0 "toolchain" but without needing to actually import the project into Atmel Studio.  You can still edit files with Atmel Studio, or with any other editor (Notepad, Notepad++, or whatever).
The one downside is build errors are not presently parsed.  You'll be able to see them in the output window though, possibly requiring scrolling up.
KFulton
Last seen: 7 months 4 weeks ago
When I compile this in Atmel Studio, I get a different (slightly larger) filesize from the pre-compiled .hex. Compiling in WinAVR gives yet another (even larger) filesize. Any idea what I might be doing wrong? Or does it even make a difference?
DavidEF
DavidEF's picture
Last seen: 1 day 26 min ago
Short answer – Windows sucks. Texas_Ace was the first one I saw mention this, but someone else may have noticed it earlier. Compiling in Linux results in smaller file sizes.
- The YKK Philosophy
Lexel
Lexel's picture
in the solution properties you have to set compile to minimal file size
LightRider
I haven’t kept up lately. Was fet duty cycle compensation ever implemented for low vf emitters?
