Manker E14 18500 Battery Tube Mod
12 posts / 0 new
CRX
CRX's picture
Last seen: 55 min 45 sec ago
I really like this lights form factor with the short battery tube but there is just not enough capacity with the 18340 cell.
I had ordered the 18650 tube along with the light but do not like the added length although the extra juice is great so i decided on a compromise…
I have used the 18650 tube with the threads on one end cut off, a large clicky switch, flat rubber switch boot, some JB weld, 1mm copper wire and oven cleaner to remove a required amount of the anodizing from inside the tube for the switch contact
To make this 18500 cell version of the E14.
It is only around 5mm longer than the 18340 version with much greater runtime and increased output.
This has four XP-L HI emitters with a 17mm MTN driver, GITD tape inside the bezel and the other stuff is in the other mod thread i did
The copper wire is soldered and epoxied in place.
Max – 2000lm
cd – 7200
Throw – 170m
Edited by: CRX on 03/09/2017 - 05:39
Firelight2
Firelight2's picture
Last seen: 11 min 8 sec ago
Beautiful job!
Can you show us how you did the tailcap and shortened the battery tube?
CRX
CRX's picture
Could you not have asked before i put it all together!? LOL
I’ll see what i can do Wink
Edness
Edness's picture
Last seen: 3 days 18 hours ago
do you have a picture of the GITD tape in the head?
CRX
CRX's picture
No, it is a thin strip of this type of sticky back sheet cut to maybe 3mm stuck to the inside of the head at the top.
Jerommel
Jerommel's picture
Last seen: 2 weeks 1 day ago
a strip of sticky back sheet on a roll = tape.
2Q19
CRX
CRX's picture
It was a strip cut from a sheet, call it tape if you want Silly
Jerommel
Jerommel's picture
It probably came from a roll at one point… Steve
2Q19
CRX
CRX's picture
Ok but did you like the mod…? LOL
HorizontalHunter
HorizontalHunter's picture
Last seen: 2 days 23 hours ago
Very nice mod.
Mine tends to stay in the long battery tube configuration so I can run 18650’s. I love the light. The tint of the 219’s is perfect for my use.
Bob
Vegetarian: vejiˈte(ə)rēən/noun: old Indian word for lousy hunter.
SeniorXJ
Last seen: 1 month 4 days ago
I would love to know more about this build as I’d like to duplicate it! How did you do the copper work on the bottom and how did you change the shape of it all?
Thanks
scrumpypaul
scrumpypaul's picture
Last seen: 2 weeks 22 hours ago
I would love to have a fingernails worth of your talent Stevi.
