Olight S1 Baton polished titanium rose gold trim.
New in box, although the lighthas been removed from box and tested. It has a very nice beam and UI, but I like my S15 better.
FEATURES:
Cree XM-L2 LED. Maximum light output up to 500 lumens
PMMA TIR lens with a 90% light transmittance rate
3 standard modes: 8 lumens, 80 lumens and 500 lumens.
2 special modes: 0.5 lumen moonlight mode and a 10Hz strobe mode
Flat tail cap design contains a strong magnet providing the ability to place it upside down and use it as a hands-freework light
Turbo mode has a limit of 1.5 minutes for constant on, after that the light output will ramp down by 50% within 1 minute
due to over heat protection built-in thermal management safety program
Reverse polarity protection to prevent improper battery installation
Low standby current below 10uA
INCLUDED ACCESSORIES:
Lanyard
User Manual
White traffic wand
$55…includes PayPal fees and shipping via USPS Mail CONUS.
I bought a standard S1 Baton (aluminum) just last week and am already in love with it. I’m on the hunt for an S-mini, so I can’t bring myself to buy this one.
But if anyone else is on the fence about it, you SHOULD buy this light, you will not regret it.
At the risk of derailing this FS thread, (OP, just consider this free Bumps) how did you get the LED out? I assume through the front by removing the bezel? How did you get a grip on such a tiny side profile of that bezel to (I assume) unscrew it? I gave a half-hearted try and it seemed pretty tight.
Well I just Google Image Searched and found this, so obviously it is possible…
Yes it is press fit. I used a cheap knife I don’t care about the blade, lightly tapped the blade into the joint while rolling it and you’ll start to see it separate, then use a small screwdriver to pop it off.
After swapping LEDs and pressing back in I tested it in water and it’s still 100% waterproof. It really isn’t that difficult to do and well worth it if you like the warmer colors.
