Vernier Calipers ... ( Lets talk Calipers )
Ok this is going to take a while … So don’t expect me to cover everything in the first post …
I am no EXPERT !
I don’t claim to be an EXPERT
And I do not have the facilities to verify tools for ABSOLUTE accuracy … ( And I in no shape or form claim such )
What I do have is a few calipers , and I have owned them for a while ( 30 years give or take )
I have also worked in engineering environments , with lathes / mills and grinders .
I have also occasionally taken the odd measurement . ( With calipers and micrometers and even rulers ) The company that issued us with rulers ( Run by Rabbits ) …
Anyhow !
The most important rule about calipers , is that they produce repeatable results …
What I mean by that is , you measure something 20 times and every time the resulting measurement is the same ( That’s repeat ability )
This is not acceptable if you manufacture to blue prints , as you would require certified / tested measuring that may need to be conducted under certain conditions especially if manufacturing parts for say the space shuttle . Or possibly a satellite or missile of some sort .
But we joe six packs don’t require such accuracy . do we ? ( This is a flashlight forum after all and I would be amazed if anyone could maintain + or - one thou in a manufacturing environment or would need to ) .
Back to calipers …
There are 3 types of vernier caliper …
The old line type ( etched markings like on a ruler )
These can be surprisingly accurate , + or - one thou in experienced hands is not un heard off .
Then you have your dial calipers - These are a mechanical device so suffer from all related issues … And with a lot of use they will suffer from wear and tear .
Treat these poorly and they will screw you …
Digital calipers - I like these as they dont suffer from wear and tear like mechanical calipers do ( dial ) … Though you may run into other issues ( electrical etc )
I really like the digital calipers , they are so easy to use and more importantly , easy to read ! .
You can buy calipers from $5 to , how much do you want to spend ?
Now here is something to store on the old memory card .
Calipers are not the last word on measuring , they are a accurate / fast / simple way of getting a ball park measurement … ( Ball Park )
There are so many variables that can effect the result of measuring something …
The most simple and blatant being the skill of the operator … If you don’t know how ! then the induced variable could be large ( induced by the user )
Common mistakes are torquing the tool ( sideways pressure ) not correctly lining up the object to be measured …
Using too little or too much pressure …
Another variable being the cleanliness of the object being measured and the working surface of the caliper jaws .
Another variable is heat / or cold . Cold tends to shrink things and heat tends to expand them , same goes with the calipers ( Heat can induce variance )
Also the materials the calipers are made from , different steels expand and contract at different rates …
And lastly you could be buying calipers that are simply faulty to start with ( I have a set of those ) .
Accuracy of the calipers ? : ( Just how much do you need )
Here things get interesting .
Calipers generally come in an accuracy scale of one tenth or one hundredth off a mm … Metric … And one hundredth or one thousandth off an inch . ( imperial )
These days that has improved to half a thou …
With dial calipers , you have a visual reference you can work from … So if the needle points between two marks you can guesstimate 1/3 . 1/4 or 1/2 … ( Depending on just how much accuracy you need )
With digital calipers you have no such visual reference . What you have is rounding to the nearest whole number .
So if you have calipers that are accurate to one tenth of a mm , then the caliper will round to the nearest tenth .
Hence the accuracy is regarde as + or - 0.1mm because the measurement will fall to the nearest tenth . And so it goes with hundreds and thousands .
The digital calipers will round to the nearest measurement the caliper offers .
Again , calipers are not the be all super duper measuring tool … They are generally considered to be ball park measuring tools in engineering circles … ( Depending on the tolerances you are working too )
Continued :
Problems to watch out for …
Lets start with dial calipers …
My first pair were Mitutoyo , I got them through a Engineering company that got the trade rate for its employees …
At the time I was a storeman , the guy that handed out the tools to the guys on the shop floor .
I remember talking to one of the foremen about calipers and he gave me the speel on looking after them …
Your calipers come in a case , keep them in the case . ( Don’t leave them lying about on dirty surfaces )
Before you use your calipers , clean your hands , clean the work , and clean the jaws .
Never open the jaws too quickly , this induces stress and can cause the gears to strip or jump and increases wear and tear …
( You see people ripping open calipers like it was a speed test and then closing them like they were trying to crush a beer can = Completely unnecessary )
Get dirt in your calipers and they will suffer for it , wear faster and that all important repeat ability can be affected .
Once dirt gets in , there is no getting it out .
I remember starting at one place and being issued a new set of calipers ( Mitutoyo ) … And the guys in the shop trying to steal them from me and replacing them with their worn out crap …
I always got them back and after a while just kept them on me all the time … ( You were issued a caliper and if you stuffed it you replaced it out of your own pocket )
It never ceases to amaze me how poorly people treated their calipers .
Problems :
Dirt , can cause increased wear and tear … Cause the dial to jump affecting repeat ability .
Make the calipers rough ( not smooth ) …
The dial cover can get dirty from the inside making reading the caliper hard if not near impossible …
Leave the calipers in sunlight can cause yellowing of the cover ( lens if you will )
And as mentioned , mechanical devices wear out with use …
I have seen people use calipers that are so worn , they are easily 10 thou out …
Or calipers where the needle jumps when opened at anything more than crawling speed
And calipers the feel like they have half a beach inside them .
Look after your dial calipers , treat them with care , keep them clean , and they may last a life time .
Treat them like crap and they may give you the same in return .
Digital Calipers …
I never encountered these in the work place …
But for personal use , I have had a few .
And quite a few of them have been NQR ( Not quite right )
Here are some issues I have encountered …
Battery - It works it does not work …
Turns on and off on its own , while you are measuring something
The measurement jumps , ( much like a dial indicator can jump ) … and the caliper is out say half an inch for arguments sake ( I had a pair like this = went in the rubbish bin )
Or my current ( cheap calipers ) where they simply lie to me … Yep … the measurement is a lie , a repeatable lie , but a lie never the less …
It took me a while to catch onto this , Im just glad I never measured anything important with that caliper … As I had another digital caliper that I verified against my Mitutoyo calipers .
So one day I had both calipers out measuring something , and the cheap calipers were giving me completely different results … ( Repeatable results - but way out )
So after a quick check against the Mitutoyo calipers the cheap nasty ones had the battery removed and actually hit the inside of a rubbish bag … But then I thought - What if I ever write about calipers , I might need an example of something that’s NQR … ( So I still have them )
Something that effects all calipers is build quality …
There are so many things that can be NQR that I can’t possibly cover them all …
Some of the more common issues
  1. How flat / true are the working surfaces of the jaws
  2. Inside measuring jaws - How true are they ?
  3. Depth measuring - again how true ?
  4. slop / tolerance of the working parts … Too much slop can introduce variance
  5. Do the calipers LIE … ( Not give a reasonably true reading )
Cheap VS more expensive …
This is Budgetlightforums of course , we do love cheap right !
And one thing is for sure ( almost a given ) , when you buy cheap you are increasing the odds of getting something NQR
I have thrown away my share of cheap things , be they Dash cameras , micro cameras ( spy cams to some ) , and calipers .
But I have never been dissuaded from buying cheap ( Because I find cheap to be fun - Ok - disappointing at times - but often a barrel full of fun )
If it wasn’t fun , i would not do it … ( Fun is important - never discount the fun factor )
But here is the interesting thing , most if not all my calipers ( except the Mitutoyo ) are cheap calipers … ( In comparison )
And they do a sterling job ( they meet my needs ) …
I currently have two grades of calipers …
Those that measure 0.1mm and those that measure 0.01mm ( 0.01 inch or 0.0005 inch )
When I need a quick and dirty measurement I reach for a $5 digital caliper ( 0.1 mm / 0.01 inch )
And I have verified the accuracy to its resolution ( accuracy scale ) … Measuring OD … I have not tested ID as yet ( these are about a week old )
Before these I used an old imperial MTI caliper accurate to 10 thousands ( OD ) but ID was some what out …
The old MTI calipers are almost as old as my Mitutoyo , and I got them for ball park measurements when I used to turn stuff at home …
( I used the MTI till I got within 20 thou , then switched to the Mitutoyo till I got within 2 thou and then switched to the digital ( Mitutoyo ) Micrometer for getting where I needed to be .
Next I will talk about the calipers I own , and compare them to the Mitutoyo …
As well as do some accuracy testing …
Remembering - these will be ball park figures as
I am no expert
and I dont have the facilities or equipment to verify ABSOLUTE accuracy
So its a comparison ….
Put that on your HDD … Comparison !
continued :
Some interesting results :
I measured 3 items
A steel security bolt
A hex driver ( shaft )
And a piston cylinder assembly ( K&B Conquest - 2.5cc )
6) Mitutoyo .3135 for the bolt - .1375 for the hex driver - and .591 for the piston ( OD ) and .5905 for the cyl ( ID ) imperial
8) Sontax .3135 for the bolt - .1375 for the hex driver - and .591 for the piston ( OD ) and .5905 for the cyl ( ID ) imperial
Shahe Calipers ( Not Pictured ) .3135 for the bolt - .1375 for the hex driver - and .591 to .5915 for the piston ( OD ) and .5905 for the cyl ( ID ) Kept switching on the piston from .591 to .5915 imperial
7) SWT Dial metric 7.97mm for the bolt - 3.50mm for the hex driver - 15.02mm for the piston ( OD ) and 14.99mm for the cyl ( ID )
For comparison I used the No8 Sontax in metric mode … 7.97mm for the bolt - 3.50mm for the hex driver - 15.01/15.02mm for the piston ( OD ) and 15.00 for the cyl ( ID )
3) MTI Dial imperial .32 for the bolt - .14 for the hex driver - .59 for the piston ( OD ) and .597 for the cyl ( ID )
2) Ebay plastic Dial 8mm for the bolt - 3.5mm for the hex driver - 15mm for the piston ( OD ) and 14.85mm for the cyl ( ID )
5) Ebay plastic Digital 7.9mm ( .31inch ) for the bolt - 3.4mm ( .13inch ) for the hex driver - 15mm ( .59inch ) for the piston ( OD ) and 14.6mm ( .57inch ) for the cyl ( ID )
1) Plastic Sontax 7.8mm ( .3inch ) for the bolt - 3.4mm ( .13inch ) for the hex driver - 14.9mm ( .58inch ) for the piston ( OD ) and 14.8mm ( .58inch ) for the cyl ( ID )
4) Bad Calipers 8.3mm ( .327inch ) for the bolt - 3.79mm ( .1495inch ) for the hex driver - 15mm ( .591inch ) for the piston and 14.97mm ( .5895inch ) for the cyl ( ID )
To be continued ( 1.25 AM ) time for bed …
9.23 AM ….
I consider myself rather lucky in the regard that my first calipers were the Mitutoyo …
As it gave me the opportunity to check any and all other calipers against it .
I can’t remember how many calipers I have thrown in the rubbish bin over the last two decades .
It could be 3 or 4 , I just don’t remember .
The first digital calipers not to be binned were the Sontax Steel Calipers (8) …
And I was very surprised to find that they gave me the exact same reading as the Mitutoyo calipers across a very broad measuring range …
Well I was hooked on cheap calipers … I don’t remember what I paid for them , but it was not more than $15 Ozzi Bananas . I may have paid a lot less ( Just don’t remember )
Anyhow ! This allowed me to put the Mitutoyo out to pasture so to speak and the Sontax became my go to caliper for when I needed that one thou reading . ( 0.0005 inch resolution )
I am not sure how long I have had the Sontax , could be around 10 years … I would buy another , but there is no Sontax out there on Ebay land …
There are the generic stainless steel calipers with the same body as the Sontax from about $18 …
I might see about playing with the cheap plastic Dial caliper (2) and see If I can’t get it tuned a little , especially measuring ID …
For $7 Ozzi bananas its a Cheese Burger with fries … But I like the potential it has for being decently ( Ball Park ) accurate …
So for you guys with only one caliper , ?
Again as long as its consistent - Repeatable measurements , Much like my (4) calipers that lie … As long as its the same lie …
Then its not the end of the world . ( For home use )
The results I posted are an eye opener …
Batteries , go online … Buy a Card of batteries for like $3 shipped to your door and make sure to check the USE BYE DATE !
I purchased a lot of button cells for my calipers like 10 years ago … Only to discover that from the 3 different sources they were all past there use bye date …
My latest purchase has a 2021 use by date … So hopefully the batteries will have a little juice …
Lots of cheap batteries on Ebay past there use bye date . ( Just something else to check )
reserved !
So glad to see that you added the human factor in there. That goes for many hand tools.
I will be keeping up with this thread...
Thanks
I have an inexpensive digital caliper like your #4. Been using it for years with no problems. I think I paid around $15us. Plenty accurate for what I use them for.
I’ve got these 3. The top one is a 20 year old Mitutoyo 700-113. Still works great. The other 2 are inexpensive Chinese made calipers.
I'd get vernier first, because you can trust it and it never needs batteries. Then get a digital and use it all the time instead.
hi, i am finding the digital capliers, my budget is around 50$( maybe more, maybe less)
i dont like the cheap made chinese digital caplier
That's why you get a cheap chines vernier first. Then you can use it to check your cheap chinese digital and not wonder.
i dont get it
i used to have one cheap chinnese, sometime when i measured, it display negative number, which mean i need to reset it again, really annoying
Good points made. I have had several including verniers and Mitutoyo dial. Saw this nice online review and ordered the iGaging he recommends. It is excellent, but goes through batteries pretty quickly. Smae guy has a nice video on basics of calipers, too.
Thanks for starting this thread.
Some time ago, I put this VINCA one in my Amazon shopping cart, but never actually pulled the trigger:
Can anyone comment if it’s decent for the $25 price? It claims resolution to 0.01mm, although accuracy is only within 0.03mm. It displays mm, inch, and fractions.
I suppose there are a bunch of similar ones available in this price range…
That's pretty much digitals in my experience cheap or not. You have to re-zero them. Not a big deal, just close and press the button. I was half joking, but only half. A vernier seems pretty trustable although I suppose even that is possible to mess up. I was just saying I'd be more comfrotable with a cheap digitial if I had a cheap vernier to occasionally check it against. At least if they agree at first, or close, then if something changes you know. The Vernier could be off I guess, but it won't change.
Nice write up. Thanks for taking the time. One thing about digitals, do not store with battery installed for long periods of time.
If this was mentioned, I apologise. I hate to see someone to lose a decent pair of mutitoyo or whatever brand they might own like I did.
Steve
Great write up. I worked in QC in an engineering company for some time. Part of my job included gauge repeatability studies, calibration and training staff to use them as well as micrometers, height gauges etc. We used digital verniers quite extensively, Mitutoyo of course. It was second nature to clean, close and check it was at zero every time.
We had a Cmm machine for checking stuff accurately.
Steel gauge blocks were used for checking accuracy.
Eaton took over and moved it overseas.
Ill just drop this right here. All of them are genuine Mitutoyo.
And the sad thing is that this is only one part of the story, if i start searching i’ll find at least 10 more broken ones.
Battery victims?
The battery covers are probably salvaged for some other ones that work, i don’t know how it happened but these don’t work at all. The only one that shows something on the display was not accurate at all.
A big variable you left off is burrs. Some parts must be filed or stoned before a caliper can give a good measurement. On the lowers I made at my old shop, it was actually faster to use a micrometer because I didn’t have to remove burrs before taking a measurement.
Personally, I won’t waste my money on a Mitutoyo caliper. In an environment with coolant, they’re going to get too squishy in a few years anyway. I’d rather get a $40 chinese caliper, and put the savings towards better micrometers and other tools.
I like the mitutoyo digimatic or absolute. They’re super consistent and have tight tolerances.
I think for most people cheap Chinese $5 ones are fine, however I notice that they drain batteries much faster than the mitutoyos. I don’t even change the batteries anymore I just use my eye. A bit troublesome.
I have searched for good digital calipers for quite some time and I have still not pulled a triger, because I own a nice set of ‘analog’ calipers. I have no actual need and no budget for authentic Mitutoyo, but I do like quality tools. I don’t want to buy multiple dirt cheap digital calipers and still be disappointed in the end. So I really hope someone could point out some desent budget calipers to go for.
