Test/review of TrustFire IMR14500 700mAh (Red-gold)
Official specifications:
  • Battery Capacity (Mfg Rated): 700 mAh
  • Battery Chemistry: Li-Ion
  • Battery Feature: Rechargeable
  • Battery Form Factor: 14500
  • Battery Maximum Voltage: 4.2 V
  • Battery Minimum Voltage: 2.85 V
  • Battery Rated Voltage: 3.7 V
This is high current rated 14500 LiIon cells. Can TrustFire be trusted?
The two batteries in the pack has different capacity, but both handle up to 7A fairly well.
Conclusion
Very small capacity differences are usual acceptable, but here the difference more than 10%, not very impressive.
If both cells had performed as the best cell I would have called it good high current performance, but with this difference the final result is rather bad.
Notes and links
Unprotected cells with different capacity may exploded if used in series.
Comparison to other LiIon batteries
Mmm, too bad the consistency isn't up to par. I recently tested my pair in this regard via in series discharging, and I accidentally brought them down a hair low (below 4.5V). Disconnected the shebang and finally measured the final resting voltage: 2.59 and 2.57V, so guess my pair was more or less well matched.
Cell binning comes in handy for battery pack assembly.
Cheers ^:)
