Convoy S2+ switch
Quick question for anyone. Can the lighted tail switch from Banggood be used in the Convoy S2+?
Quick answer, yes. But you need to add a bleeder resistor to the driver to allow a small leakage current to provide the voltage for the switch LEDs. Basically just a resistor from led+ pad to ground ring or stacked on C1. Anywhere from 400 Ohm’s on up depending on how bright or dim you want it.
