Utorch 1x AA 500+ Lumen Review
73 posts / 0 new
kzb
Last seen: 1 year 3 months ago
I didn’t buy it for a bodgit job though. I’m disappointed, but then I thought it was too good to be true at the price.
If they’d made the tube just 0.5mm longer it would probably work with Xtars.
If it works with the paperclip bodge, I might try for a better bodge by obtaining a copper washer of the appropriate dimensions.
Streamer
Streamer's picture
Last seen: 1 hour 10 min ago
I never use protected in a single AA/14500 setup. And I really don’t see a need to. So, problem solved. I knew I’d use non-protected before I even ordered UT01. Simple.
YMMV Wink
kzb
I cut a length of cable long enough to make a ring within the tailcap. Stripped off the insulation, twisted it a bit to keep the fibres in place and put it in the tailcap so that it makes contact with the battery tube end.
Result ! The flashlight does indeed function with Xtar 14500 cell with this bodge in place. The copper stays wedged in place also.
Anyhow I hope this is useful information for others considering buying this.
It seems all protected cells, including those purporting to be “AA-sized” are too long and won’t work in this flashlight. Unless anyone knows of a shorter cell than the Xtar of course.
joechina
Last seen: 7 hours 3 min ago
It is verry hard to find a PROTECTED LiIon 14500. They are normaly longer than the nominal 50mm.
Xstar are short with arround 51mm others more on the 52mm side.
aslpg
Last seen: 16 hours 18 min ago
joechina wrote:
It is verry hard to find a PROTECTED LiIon 14500. They are normaly longer than the nominal 50mm. Xstar are short with arround 51mm others more on the 52mm side.
Sanyo UR14500P 14500 840mAh from FastTech. HEIGHT: 49.3 mm.
kzb
Are these definitely Protected? It’s not clear from the FastTech site. In fact there is another Sanyo cell advertised, “Sold Out”, that is 50mm. Maybe that is the protected version, and how do we know the 50mm is not “nominal”?
SIGShooter
Last seen: 3 hours 25 min ago
I don’t think those are protected.
joechina
Reading the comments on the FastTech, I also think they are not protected.
Nominal:
14500 = are the dimension of a cell in milimeter 14 = 14mm diameter, 50 = 50mm long, End Zero = indicate its a round cell.
Same logic with a coin cell CR3230 : Round cell 32mm diameter, 3mm hight.
Jerommel
Jerommel's picture
Last seen: 1 month 1 week ago
Here’s what i did to make it fit protected 14500:
http://budgetlightforum.com/node/52332
…but it’s a lot of work i guess…
2Q19
kzb
Copper sealing washers available on ebay; 18mm OD, 14mm ID, 1.5mm thick. Would this be a good idea?
I am concerned about contact resistance, especially since there is quite a high current.
I am also wondering if the added resistance is limiting the performance. It does not seem any brighter than my Lumintop ED11 560 lumens.
http://www.ebay.co.uk/itm/Metric-Copper-Sealing-Washers-Sizes-M5-to-M24-...
Streamer
Streamer's picture
You MAY find that the protected variety of cells are not completely capable of putting out max amps that the driver needs for DD turbo. That’s why they call them protected. It’s possible for their circuitry to prevent max amp flow.
I use the 14500 unprotected IMR WindyFire’s. Man, the UT01 is really scorching bright with that.
Again, YMMV with protected cells.
mrheosuper
Last seen: 3 hours 6 min ago
Replace the faulty switch( yes, i lost the lotery, poor me Sad )
Nearly 10$ include shipping just for 5 switches
Forgot my pen
