WTS: Genuine 365nm Nichia NCSU033B UV leds
41 posts / 0 new
Valor
Last seen: 2 months 22 hours ago
For sale some original NCSU033BT, flux bin P9 UV leds. New-old-stock leftovers from a science project.
These are still selling for $50-75 a piece.
Asking $30 $20 per LED, plus shipping.
Economy Inernational shipping without tracking or insurance: $5
Inernational Shipping with tracking (preferred): $15
Some techdata:
Vf=3.6-4.0V
If=700mA
If(pulsed)=1000mA
Ir=85mA
PD=3.08D
Tj=130
λp=365
λd=9nm
Flux=350-390mW
cheers,
Val
update: now with techdata
Edited by: Valor on 02/27/2017 - 10:57
The Miller
The Miller's picture
How do they compare to this LED?
http://www.gearbest.com/led-flashlights/pp_277704.html
for now $20 one gets a nice flashlight with it.
Jerommel
Jerommel's picture
Last seen: 1 month 5 days ago
Some specs would be nice.
Wavelength, Vf and maximum current.
..waiting for parts..
Still looking for 5” parabolic reflector (for recoil light)
Valor
I don’t know how they compare as I don’t have that light. The linked Convoy S2+ is apparently using a NCSU276A (I might be wrong) but that led costs less than half of what 033b are still selling for.
Could there be a spectral difference after all? I was told that the Nichias in those golden-ceramic packages with glass lens (i can’t find what the package is called) are made for prolonged life under industrial use.
Maybe some UV-savvy flashaholic fella could enlighten us.
I’m waiting for several hosts to arrive so I can test them outdoors.
RobertB
RobertB's picture
Last seen: 13 hours 37 min ago
There’s also the Nichia UV Jaxman with the filter for $47
Jerommel
Jerommel's picture
They look big.
Is it 5050 size?
Valor
Sorry, forgot to list them. I’ll update the listing
NCSU033B(T) P9
Vf=3.6-4.0V
If=700mA
If(pulsed)=1000mA
Ir=85mA
PD=3.08W
Tj=130
λp=365
λd=9nm
Flux=350-390mW
Valor
The package is big, the die I think is 1×1mm
They should fit on XHP70 or MK-R boards
zak.wilson
Last seen: 2 hours 49 min ago
I’m not seeing P9 listed as a flux bin for the 033B. The highest flux bin listed is P34d22, which is 590-640mW at 500mA forward current. The lowest flux bin in the 276A is P35d21, which is 640-700mW at 500mA.
I know fairly little about UV LEDs, so I could easily be missing something obvious, but I don’t see an advantage to the 033B over the 276A.
Ceilingbounce – flashlight testing and runtime graphs for Android
Valor
There seems to be multiple different editions of the NCSU033B(T) which I cant find a documentation for.
Googling after NCSU033B P9 350 ends up with few links to a datasheet with earlier binning nomenclature.
As for the objective differences between the NCSU033B and NCSU276A these are what I could find is:
  • NCSU033B has a slighly narrower beam profile 115° vs 130°
  • NCSU033B has a better thermal resistance 4.4°C/W vs 11°C/W
  • on the other hand NCSU276A has more raw output
I think these models are not a replacement to each other but rather a compliment.
It’s true that, there could be many applications where the 033B (or it’s bigger brothers sharing the same package size such as: NVSU333A, NC4U133B) would NOT fit the bill due to larger size and higher cost.
Nonetheless, consindering the constructive feedback I’ve received, I’ve readjusted the price.
The_Driver
The_Driver's picture
Last seen: 5 hours 27 min ago
Thanks for offering these!
I’ll take one. Sent you a pm.
There is one very big difference between these and the newer Nichias:
These older ones have a central solder pad for heatsinking. This is important because UV LEDs are much more heat sensitive than white LEDs. They start to die at much lower temperatures.
The newer ones in turn are much more efficient and thus brighter (but only when they are kept cool).
Please check out this thread here (it’s in German). It shows what happens to the Nichia 276 when it gets too hot inside a Convoy S2+. My light also now has this problem :(.
Valor
Sorry to hear about your problem.
Thanks for the link. You have a good point there: in addition to a better thermal resistance, the older package can obviously endure a noticeably higher junction temperature
NCSU033B NCSU0276A
Tj=130°C Tj=90°C
prisma
Last seen: 2 days 12 hours ago
I will take one also.
The Miller
Nice thanks all for this educational thread
Scouring a high drain cell for NY S2+ Nichia now, if it fails I want one too!
Valor
The Miller wrote:
… Scouring a high drain cell for NY S2+ Nichia now, if it fails I want one too!
I trully hope your S2+ UV Nichia does *NOT *fail. But I will reserve one NCSU033B for you in any case Wink
Lexel
Lexel's picture
Last seen: 7 hours 30 min ago
in the 40$ new price range you got a 233A
Tj is also 130°C
http://www.nichia.co.jp/specification/products/led/NVSU233A-E.pdf
lowest flux bin 800-870mW
for the 233 and 276A I can only recommend to get djozz custom board
http://budgetlightforum.com/node/48934
or if you are sick to get 5W 365nm get the 333A
http://www.nichia.co.jp/specification/products/led/NVSU333A-E.pdf
lowest flux bin 3160mW
has the same 7×7mm footprint with thermal pad
Valor
Lexel wrote:
…or if you are sick to get 5W 365nm get the 333A
I’ll try to get one for the fun of it Smile
Valor
Received some copper and alu. boards for testing how these UV leds fit…
The universal base boards made for both XHP70 & MK-R seem to be a better match than the ones suitable for XHP50 & XHP70. Both are perfectly usable, nonetheless Thumbs Up
Serp
Serp's picture
Last seen: 3 days 22 hours ago
I think there will be a short circuit. The center pad is too wide on the star
Valor
I thought so too, but considering that the solder bulges slightly up it worked without a problem. The led got pulled into it’s place once the solder started to flow.
I’ve had (the start) running yesterday without any issues. Then I decided to test the limits..
Valor
The_Driver wrote:
Thanks for offering these! Please check out this thread here (it’s in German). It shows what happens to the Nichia 276 when it gets too hot inside a Convoy S2+. My light also now has this problem :(.
Hi again, your LED should be on it’s way to Germany as we speak.
I’ve run a test to see if these leds have the same issue..
After pushing the test-unit (the one on the DTP star) to 1.7A i had to stop the test, as I did not have proper isolation of the rest of the lab from UV bombardment.
The die seems unaffected. The star temperature reached around 56°C
djozz
djozz's picture
Last seen: 9 hours 59 min ago
Those are pretty cool, and the combination with a readily available DTP board makes them interesting.
Tempted to buy one but $20 for one led, however good the price, still makes me think twice Wink !
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Valor
Djozz, cant you send me some translucent S2+ thingies, and i will send you one of these Smile
djozz
djozz's picture
That is too good a deal because I got those for free from Simon. But send me your address and you will get some anyway. (and that reminds me that someone else asked for a few of those as well, so I will have some shipping to do Smile )
link to djozz tests
The_Driver
I just got mine today. Very fast shipping! Thanks!
Valor
djozz, PM sent. I’ve ordered some S2+ hosts from GB for modding. Feel free to ship away any S2+ parts you don’t want to keep Big Smile
The_Driver, wow that was indeed fast. Any plans on how you are going to mount the LED into your host? I’ve modded a 348 with one of these where I just soldered the LED to a rectangular copper bar 2×3×6mm and then glued to the pill…
I’ve got some more playing to do with these today. Any wishes what one should do to a de-domed or, should I say “de-windowed” UV led? Evil
Valor
Forgot to annotate the photo.
The small die on the anode side is apparently the ESD/TVS protection diode. That fella ensures that this expensive diode does not get zapped by the static. Ain’t that sweet…
djozz
djozz's picture
Thanks Valor, I will get you a few nice emitters for your S2+ Smile
link to djozz tests
Valor
This will soon need it’s own separate thread Smile
I’ve had some time to prepare a test of the same led at 1700mA and leave it running overnight. The thermal performance looks very promising.
I’ve then had the led running at 2000mA for an hour and it stabilized at 79°C. That’s at 285% of datasheet figures.
The power usage seemed to remain uniform despite running warmer.
Voltage and current has been logged via an Agilent 34970A data acquisition unit. I’ve ordered a set of Omega K-type thermocouple to cover temerature in the logged data…
No visual deterioration either
prisma
Mine arrived yesterday, thanks for yor fast shipping!
djozz
djozz's picture
That graph screems for added output data. I will see if I can add that (but no promises because it is hobby Wink ).
link to djozz tests
