Test/review of Vapcell IMR18650 3100mAh (Red)
Official specifications:
  • Nominal voltage: 3.6V
  • Charge voltage: 4.2V
  • Max. charge voltage: 4.25V
  • Typical Capacity: 3100mAh (0.2C discharge)
  • Min capacity: 3000mAh (0.2C discharge)
  • top: Flat top
  • color: red
  • weight: 48g max
  • Internal Resistance: <20mOhm
  • Standard Charge: 1A, 4.20 ± 0.05 V, CCCV 100mA cut-off
  • Continuous maximum charge current: 4A
  • discharge cut-off voltage: 2.5v
  • maximum discharge current: 40A
  • Operating environment: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
This is a high current cell with good capacity.
There is a fairly good tracking between the discharge curves and the cell can deliver about 20A.
It could nearly deliver a full 20A discharge.
At 30A the cell gets rather hot and I stop the discharge.
Conclusion
The cell is a good performing high current cell, but as usual the rating is on the optimistic side.
Notes and links
I got this cell from a reader, he checked under the wrapper on one of the cells. This cell is not on the Vapcell website, but can easily be found on alibaba.
Compare to 18650 and other batteries
