Nichia 219B 4500k D220 9080 CRI Emitter output test by Texas_Ace; Amazing tint and CRI! Output is what you would expect.
114 posts / 0 new
jon_slider
jon_slider's picture
Last seen: 3 hours 49 min ago
doubleone44 wrote:
I have dedomed multiple 219Cs. It’s quite hard as most of the time some of the silicone gets stuck on the phopshor, but with a sharp blade you can just barely remove it.
Tint is very warm (about 3000K):
LTR: 5700K nichia 219B, 4000K 219C with dome, 4000K 219C dedomed. White balance set to daylight
CRI doesn’t seemed to be affected. (Maukka confirmed that CRI doesn’t shift a lot with dedoming).
Throw is about what you would expect: About the same as XP-L Hi but thighter beam. (this is by eye and judging from distance so might not be 100% correct)
Thanks for the great beam comparison. I like that you used daylight white balance and shot all 3 beams together, and that one of them gives a Cool White reference. That all works really well together!
Agro
Agro's picture
Last seen: 2 hours 59 min ago
kiriba-ru wrote:
Agro wrote:
On the lux-rc site I see the following comment:
Quote:
Nichia 219B MDC with T11 lens overperformed CREE XP-L HI with standard narrow lens almost twice in candelas
OK, they use a custom throw lens which is better than stock. But nevertheless they consider dedomed 219b a good option for throw. Does anyone here have experience with that?
As regular user I would not recommend you looking for lux-rc technologies. You dont compare family car with F1, right? First of all, lux used another leds. I have mensioned this several times – some 219bs have smaller dies (and it is almost unreal to get this leds if you are not able to order full 2500 leds reel). Secondly, he rarely use hi-cri nichias and prefer regular version (which have xp-g2 top bin performance). Third, mbc is not dedome, this is custom dome for better throw without lumens loss. Add custom silicone lens, and now you can compare it with $3 xpl-hi under $1.5 10507.
Interesting, thanks.
It seems there are several people who re-dome leds already:
  • Oveready
  • Lux-RC
  • Vinz
  • (never seen confirmed, but probably saabluster too)
Oveready buys Lux-RC light engines, so maybe one of them buys redomed LEDs from the other?
Also, do you have any info on the custom lens?
kiriba-ru
kiriba-ru's picture
Last seen: 1 hour 43 min ago
Dedome is not something you can be sure in finel result. You can find some old cree datasheet about chemical compatibility of leds with silicone dome – even regular leds require some limited conditions, otherwise output can decrease much faster than expected. Nobody knows how much output you will have after 100, 10 or even 1 hour of light with dedomed led.
Lux dont practice chemical dedome (only mechanical).
Lux applies custom dome to prevent fast led degrate.
Finally – his modules work inside sealed area without oxygen.
Again, I dont feel this information usefull for blf modders – since xpl-hi are available (black flat etc.)
I suppose you can find enough information about silicone optics pros and cons. Most optics manufactures started to use this material 3-5 years ago.
The_Driver
The_Driver's picture
Last seen: 5 hours 30 min ago
I have never seen Vinz re-dome LEDs. He has a method of removing th green tint after de-doming though (he calls it diamond treating).
There are some modders here who build hundreds of lights per year with dedomed LEDs. I have never read a single post in the last 5-6 years where somebody measured an actual loss of performance of time.
Evgeniy
Last seen: 1 week 3 days ago
nsl18 wrote:
I have oslon LCW CQAR.CC-MR-6L-L2, no any grinnich. Compared with 219B sw40, it is slightly yellowish. l
I also has Osram Oslon LCW CQAR.CC-MR-6L-L2 (from pargos-shop, 2 orders), and use it in 3 my flashlights with TIR-optics.
And I also can say : no any grinnich .
Perfect white color, slightly warm light, ~3900-4000K (color rendering slightly nicer, than in 2 my FC mkIV HiCRI Zebralight’s).
Flashlights : custom (Jaxman E2L with led4power LD-4 drivers and 3xOsram CQAR.CC), custom Skillhunt H03 with Osram 3К/4К, Zebralight {H600fc IV, Sc600fc IV, H600fc III}, Jaxman E2(N219b), Convoy UV.
Previous: Zebralight {H501, H600W, H600W II, H602W}, NiteCore TIPCRI, A A01, Fenix L2D CE/CEQ5.
Evgeniy
maukka wrote:
A high CRI emitter can have a significantly off white tint, like this green Oslon which is one of the worst (duv 0.0093) I’ve tested regardless of CRI.
However, as the tint was quite consistent throughout the beam in the test light (Thrunite TC12 V2), it can be corrected with a simple filter (unlike an XP-G3 for example).
Dear maukka, pls. wrote full name and color group of this measured sample Osram Square LED.
It’s CQAR.CC or CSSRM1 ?
maukka
maukka's picture
Last seen: 4 hours 7 min ago
Evgeniy wrote:
Dear maukka, pls. wrote full name and color group of this measured sample Osram Square LED. It’s CQAR.CC or CSSRM1 ?
It was sold to the member Chouster as a GW CSSRM1.BM-MPMR-XX55-1.
nsl18
Last seen: 3 days 14 hours ago
I shut out osram for myself- low lm/w and power dissipation. Samsung is best as budget hi-cri
Evgeniy
thanks.
Evgeniy
Yes, all hiCri led has lower low lm/w efficiency, that ordinary led’s, and these Osram Square series isn’t a “lumen champions”, but has excellent color rendering and (imho) tint (CQAR.CC 4000K 6L group).
If you prefer samsung 351D tint – it’s your choice.
SKV89
Last seen: 28 min 12 sec ago
Are you talking about the same Oram in the Maukka test above? If so that thing has a whopping DUV of 0.0093, which is great for making horror films.
Evgeniy
SKV89 wrote:
Evgeniy wrote:
Yes, all hiCri led has lower low lm/w efficiency, that ordinary led’s, and these Osram Square series isn’t a “lumen champions”, but has excellent color rendering and (imho) tint (CQAR.CC 4000K 6L group). If you prefer samsung 351D tint – it’s your choice.
both are Osram Square family, both 4000K hiCRI, but Maukka tested CSSRM1 with different color group
vestureofblood
vestureofblood's picture
Last seen: 1 week 4 days ago
Where can I get some of these LEDs?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
Texas_Ace
Texas_Ace's picture
Last seen: 5 hours 26 min ago
That is the question many of us are asking as well.
Clemence has not been able to get anymore of them and no one else has been able to as well.
I have a back channel hunt going to look for some but nothing so far.
At this point I am thinking about seeing how large of an order would be needed to get a batch made.
severide
Dooooo it! Silly
clemence
clemence's picture
Last seen: 9 hours 25 min ago
Which one? The Osram or the 219B?
If its the 219B, then I still have few hundreds left from the last GB (both the sw45k and sw40).
- Clemence
Texas_Ace
Texas_Ace's picture
- Clemence
You have some of the 9080 219B? I thought you were not able to get them anymore? Sorry, have not ventured out of my own threads basically all year.
clemence
clemence's picture
- Clemence
Check this: http://budgetlightforum.com/node/60638
Texas_Ace
Texas_Ace's picture
Nice, I was not aware you managed to get anymore.
Although it looks like they have discontinued them entirely? No way to have another batch made?
I guess the only real option is the E21A or similar LED moving forward for very high CRI? That sucks since it is so much harder to use.
Actually had a light I am working on now that would of been perfect with the 219B 9080.
clemence
clemence's picture
There’s a minimum order to meet, hence the last group buy. But I really don’t know how much 219Bs left in the warehouse. I have to check back to Nichia. I personally don’t want to stock them anymore. If you really have to use it then PM me.
Single E21A is the way to go, it’s very similar to 219B in performance and output. Rosy tint is another thing though…
EDIT: Yes, officially discontinued. We got the last batch from last year stock, you can see it from the bin labelling.
- Clemence
trailhunter
Last seen: 1 week 5 days ago
Hi all, I reflowed a m43 from 219c to 219b sw45k. should i be okay with 30Qs?
Texas_Ace
Texas_Ace's picture
Yes, with that many LED’s to split the load you should be ok with 30Q’s. They also have a pretty high Vf so they don’t pull a lot of current.
That said, I would try to get a current reading on them so that you can know for sure since those LED’s are so rare.
trailhunter
Thanks Texas!
