Review : Qualilite D81 Cree Xp-l hi V3 (Kaidomain's C8)
7 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 1 month 1 week ago
Due to a photobucket’s policy change , pictures can not be shared freely anymore …
To be able to view all the pictures of this review please install this Chrome Extension :
https://chrome.google.com/webstore/detail/photobucket-hotlink-fix/kegnjb...
Qualilite D81 6500k Review
Some words for the flashlight : The D81 of the QUALILITE D-Series (Dynamic) is the tactical flashlight with powerful output. Flexible mode arrangement can let user to choose according to their preference. D-series is standing for Dynamic Series means users can install various LED modules, QUALILITE accessories, even other D-series products depending on your needs. The diversity of D81 flashlight must have once that meets for your needs.
Overview :
First Look / Unboxing :
Flashlights comes in a nice , black box with the Qualilite branding and some basic info (lumen performance , throw distance , max run time and safe dropping height) :
Back side , we see some more info .
Package Contains :
- Flashlight
- Lanyard
- Soft cleaning cloth
Extended View :
The flashlight itself :
Flashlight’s length is 14,7cm
Flashlight in hand :
It has a little “Warning” logo on the head too , if you see closely the previous picture .
The “D81” logo on the head :
Tube & tailcap , front side . Very smooth knurling . :
Back side :
Tailcap , with a kind of “crenelated look” , for easy access with the thumb :
Reflector :
And the threads . Not anodized , but excellent quality . Very smooth , well machined :
A quick teardown :
Head , tube and tailswitch :
Switch , it is forward clicky switch :
Switch assembly :
And some close photos of the switch pcb & spring :
Head , from the side that the tube screws in (head , with pill inside) :
Led drop-in module (one piece reflector and pill system) :
Driver side :
Pill with reflector removed . Notice the centering ring too . :
Led board close-up . It is a square , copper DTP board . It uses xp-l hi v3 . Driver wires seems thin :
Lens , good quality AR coated lens :
Thickness , 2mm :
Modes and driver info :
Flashlight has 2 mode groups :
  • Lo > Med > Hi
  • Lo > Med > Hi > Strobe > S.O.S
To change between the 2 groups , you simply cycle through the same group for 3 times (continuously) and it changes to the other group automatically .
Pic by KD
Driver accepts 1× 18650 (li-ion) battery or 2x CR123A (3V) batteries , i will test if i can use 2× 18350 too .
Measurements :
Battery used in all measurements : Samsung INR18650-30Q 3000mAh
Lumens measurements :
Hi : 938.8 lumens
Med : 117.3 lumens
Lo : 19.3 lumens
Intensity on highest setting : 72,7 kcd
Amperage Draw :
Hi : 2,84 A
Med : 0,29 A
Lo : 0,05 A
Measured with Uni-T UT210E
Beamshots section :
  • Second tree on the left is 180 meters away :
  • House is 160 meters away :
Control Shot :
Beamshot :
  • The other side is 130 meters away :
Control shot :
Beamshot :
A few words :
A well built C8 , with a smart reflector – pill module , and quality components : thick AR coated lens , high quality SMO reflector designed for xp-l hi (produces a nice beam) and xp-l hi v3 on copper DTP board .
Flashlight was provided by Kaidomain for review purposes . You can find this flashlight here .
Edited by: giorgoskok on 09/26/2017 - 08:53
MRsDNF
MRsDNF's picture
Last seen: 1 day 10 hours ago
Thanks for the review giorgoskok. Good to see you got the reflector removed from the pill. Was it hard?
giorgoskok
Thanks !
It didn’t have any glue , i used a wrench to get some grip on the pill , and it was done in seconds .
Edit: i don’t know the exact name of the tool i used (lol), closest i could find is Monkey wrench
BanL
Last seen: 2 hours 4 min ago
Thank you for your reviewing.
Hope you guys will enjoy it.
Thank you Thumbs Up
kaidomain.com KD - LED Flashlights, DIY Parts and Accessories
Inquiry for KD, please feel free to contact me.
Henk4U2
Henk4U2's picture
Last seen: 8 hours 22 min ago
Seems you have covered all the bases with this review. Well done. Considering other C8’s have loose interchangeable reflectors AFAIK, and this one has a drop-in, is it possible to share some more (comparable white wall) beamshots?
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
giorgoskok
Thank you Thumbs Up
Thanks again for your support Ban !
Thanks !
Unfortunately white wall beamshots are hard to get right , but i will give it a try . Anyway , i can ensure you it has a perfect beam pattern .
BanL
Hi friend
To celebrate an internet big event (Double 11 Sales Promotion), Qualilite D81 and D21 has launched the first big discount to all of our friends.
All the products will be shipped by US Amazon (US only).
Qualilite D81
https://www.amazon.com/dp/B06XCL56QQ
White 6500K US$18.58/ Neutral White US$18.39
Qualilite D21
https://www.amazon.com/dp/B06XRVKT3Z
White 6500K US$18.39/ Neutral White US$18.39
Catch up the chance and Enjoy the price Big Smile
