new Maxtoch Mission 12 / Shooter 2X deal is ALIVE
Hey my friends!
banggood listed some new Maxtoch flashlights:
  • deals can be browsed at my blog or PM me
  • the pictures are the links to the shop for more information
MAXTOCH MISSION M12 XHP70
3200LM 525M Searching LED Flashlight 2x26650
Features:
XHP70LED output,up to 5000hours service time
Maximum output 3200lumens
Mirco orange-peel reflector
Maximum beam distance 525meters
Powered by 2pcs of 26650 li-ion rechargeable battery
Reverse polarity protection
Memory function
Anti-slip and sweat wicking knurling
Dual switch controls brightness levels and flashing modes separately
Made from aircaft-grade aluminum
Mil-Spec Type III hard-anodized finish
Toughtened ultra clear glass lens with blue coating on both sides
Waterproof to IPX-8 standard,underwater 2meters
Package included:
1 x MAXTOCH MISSION M12 XHP70 3200LM LED Flashlight
MAXTOCH Mission M12 XP-L HD
1200LM 720Meters Searching LED Flashlight 1x/2x 26650
Features:
Package included:
1 x MAXTOCH Mission M12 XP-L HD 1000LM LED Flashlight
1 x Extension tube
MAXTOCH Mission M12 XP-L HI
1000LM 850Meters Searching LED Flashlight 1x/2x 26650
Features:
Package included:
1 x MAXTOCH Mission M12 XP-L HI 1000LM LED Flashlight
1 x Extension tube
MAXTOCH SHOOTER 2X XPH70
3000LM 3Modes Wide Range Searching LED Flashlight 2x 18650
Features:
Adopts XHP70 LED
Max output 3000lm
Max beam distance 570meters
Powered by 2pcs 18650 rechargeable battery or 4pcs CR123A
Reverse polarity protection,to protect from improper battery installation
Memory function
Anti-slide and wicking design
Reverse rear switch,three brightness
Made from solid aluminum stick
Mil-spec Type III hard-anodized finish
AR lens with blue coating
Spare tactical grip ring
IPX-8 waterproof up to 2meters
Package included:
1 x MAXTOCH SHOOTER 2X XPH70 3000LM Searching LED Flashlight
please use this form if you want to know the deal (a lot less work for me ;))
https://goo.gl/forms/LbqBXb8s8B8DSiDK2
or post it below and i paste it in the list ...
Yes please
That anti vandal type switch is sexy as hell.
No XHP35 Hi ?
or change XPL Hi to XHP35 Hi.
I think that XHP50.2 would be a good led for a new Maxtoch light :slight_smile:
i like the extender idea on the XP-L LEDs...
more runtime and 10% higher power
how big are the chances the driver is the same in all M12?
(maybe different sense resistors)
since it works 1 or 2S for the 3V LEDs and 2S for 6V
swapping to XHP50.2 ina DTP could be easy
Well….looks good yet i have a feeling for downgrade especialy about the Shooter…kinda wierd Maxtouch solution
If only M12 had a tail switch too…
Could you post the lumens for each mode on the lights above and the run times for each. Thank you. And great new line up. I had to miss the 2x group buy last time I was in it but lost my job days before the code went active. Maybe I can request one of these for my birthday in a few months coming up
Yes Please … :beer:
I`m interested.
Greets
Carsten
if you go to the shop (links arein the pictures) or to the manufacturer you will find that data.
Maxtoch does not tell a runtime in Turbo - maybe due to a stepdown?
could mean they are serious about runtime in the other Levels...
XHP70
XP-L HD (1S)
XP-L HI (1S)
Shooter 2X
Like the look of the XP-L HI, still looking for a really throwy light and this could be a possibility
Okay, I’ll ask the dumb question. How does adding a 2nd 26650 and the extension tube to the Mission M12 XP-L HD only increase the battery life by 50? It should double it (ie: increase by 100). Of course the runtime data in the chart shows it shortens the life. :person_facepalming:
Will any of these by offered in Neutral?
M12 XP-L HI looks like quite an impressive compact thrower!
Increased output with a second cell
Codes please
very strange the XPL ones with 2x26650 and the XHP 70 only 2x18650
Mission M12 is 2*26650 Xhp70.
That first flashlight
Where is the XHP35 HI version of Shooter? :frowning:
Codes please
