AccuPower IQ338LX charging unequally on 2 of 4 slots
3 posts / 0 new
Zebretta
Last seen: 21 hours 50 min ago
AccuPower IQ338LX
Received this charger from ebay seller rDana Around the first of the year.
Since them I’ve discovered that the charger has a few problems.
Of the 4 slots, several seem to be substantially off in the capacity readings from the others.
For example, I can put a battery in Slot 1 and the capacity comes out at 5330 mAh.
Same battery in slot 2 will show 5100mAh.
Same battery in Slot 3 and 4 comes out 5082mAh. The error is repeatable.
Slot 1 consistently shows about 300mAh too much capacity
Slot 2 consistently shows about 100mAh too much capacity
Slots 3 and 4 seem to be pretty accurate
Anyway to correct this? Resistor change? The warranty probably ended about 2 weeks after I got it.
Thanks
Tinderbox UK
Tinderbox UK's picture
Last seen: 4 days 20 hours ago
A owner on CPF was having a similar problem, the Germans don't make chargers like they use too, I have had two Tronic charger blow-up and others with faulty slots.
http://www.candlepowerforums.com/vb/showthread.php?427454-AccuPower-IQ338LX-Slight-Problem
John
SkyRC MC3000 – Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
Zebretta
It looks like just Slot #1 is about 175mAh too optomistic.
I have a feeling a resistor change might resolve that.
