BLF A6 lost parts. is this important?
15 posts / 0 new
doggymoon
Last seen: 10 months 6 days ago
Hi, every flashlight lovers.
I'm flashlight lover too, and newbie. I got BLF A6 a few weeks ago.
When I was cleaning for maintenance,
I lost "white ring" which is between reflector and led (maybe it's a kind of spacer).
!http://imgur.com/a/KYFUl!
Someone knows this part is important or not? Can I use light continuing?
Thank you.
mattjk
mattjk's picture
yeah you need the spacer or the reflector may short the LED terminals
doggymoon
oh…. Facepalm
I’ll search or order it. But, I have no idea whether it can order or not…
Thank you, mattjk!
g_sintornillos
g_sintornillos's picture
Last seen: 4 hours 16 min ago
Can you measure the diameter of reflector hole?
Sorry for my bad English (gogole translator)
2 DOGS
Last seen: 3 hours 36 min ago
Search “centering rings”
I’m not sure which size you need.
Parts and rings
mrheosuper
Last seen: 6 hours 21 min ago
Well, you can use another way, like a thick paper, or kapton tape
Forgot my pen
djburkes
djburkes's picture
Last seen: 1 month 5 days ago
These may fit as the BLF A6 uses pretty much the same size reflector as a Convoy S2+. I’ll measure mine for you when I get home.
doggymoon
Yes, I measured hole sizes, they are below.
inside : 7mm
outside : 10.5mm
g_sintornillos
inside : 7mm
outside : 10.5mm
Yes, but “Sorry, this item is no longer available!”
These: http://www.kaidomain.com/p/S024677.8_4mm-D-x-0_9mm-T-White-Plastic-Insul...
ChibiM
ChibiM's picture
Last seen: 1 day 40 min ago
Uhmm.. Welcome to BLF!
caramba
caramba's picture
Last seen: 1 week 6 days ago
You can use electrical tape at least until you get a replacement Wink
doggymoon
“Parts and rings”:http://www.kaidomain.com/c/363.DIY-Flashlight-Misc-Parts
2 DOGS, thank you for your info.
After your advise I found them out “centering rings” , “gasket” , “insulation” and so on.
…Yes, I didn’t know how to say it. Finally, adding wings to doggymoon.
You made me remember one item.
I have some silicone rings for cherry keyboard to reduce typing sound.
It’s like an kind of insulation gasket.
And then, I tried it on. It looks like a good, for a moment until getting new parts.
Thank you mrheosuper, caramba!
Thank you guys djburkes, g_sintornillos.
I’ll order gaskets.
I need them for my “light” future and I’ll be careful not to be lost parts anymore.
Thank you ChibiM. Smile
Rufusbduck
Rufusbduck's picture
If you plan on modding order a few different types. Xml’s work with xhp50’s and xpg’s work with XPL and Nichia 219. Also might want xpg to XML for using xp’s in larger hole reflectors.
Scott
doggymoon
Hi Rufusbduck. It’s sounds like fun.
In the future, I’d like to custom, mod, or something tweak my lights. LOL
mrheosuper
Careful with the heat, that’s why i recommend kaptop tape
Forgot my pen
