Foursevens Mini MA Gen2 Ti - MT-G2
12 posts / 0 new
CRX
CRX's picture
Last seen: 2 hours 13 min ago
I bought this Foursevens Mini MA Gen2 titanium limited edition second hand. It's a nice light being very compact pocket friendly, AA format and made of my favorite material. The light in stock form is a normal a twisty with an XP-G emitter putting out a meagre 90lm or so on high. I decided to install a tail clicky switch and MT-G2 emitter Cool
MT-G2 P0 5000K on 16mm noctigon MCPCB
MTN 15mm driver with gupprydrv
Reverse clicky tail switch
Tritium vial in lanyard hole
2 x 14250 compatible
Length – 80mm
Width – 18mm
Weight – 51 grams (with cells)
Max – 1600 lm
Making a tail clicky switch module & reinforcing pill.
I heat anodized the body.
Edited by: CRX on 07/23/2018 - 08:34
sac02
sac02's picture
Last seen: 10 hours 31 min ago
I may be often am stupid, so bear with me. How did you get the pill out of the head? I’m trying to refurb an older AA mini (normal aluminum version) but can’t figure out how to get the pill out.
I can see from your pics that the pill is threaded, does it unscrew out the back of the head? I assume there is no threaded bezel to take the reflector out the front – or is there?
I currently have the driver board loose from the pill, but I can’t get to the notches in the pill to try and unscrew it with snapring pliers (the driver board is in the way). Do you use the driver board itself to unscrew the pill somehow?
Also, I love your mods. It’s impressive to see some of the mods people do to full size lights, but you do the same extent of mods to tiny lights and it’s just rad.
CRX
CRX's picture
Cheers mate. It was a bugger to get out as it was very well glued in there, I thought I had stripped it when it finally gave way after some heat, if you look at the first OP picture you will see some darkening on the head, that is what gave me the idea for the heat treatment. The driver was destroyed taking the pill out but I didn’t need it. There is no bezel on the head.
If you can get the driver out or are replacing it then use long nose pliars through the LED wire holes in the pill to unscrew it but be careful.
sac02
sac02's picture
OK, thanks. I’m thinking the driver is going to be trash so I’ll just snip those wires and yank it out.
CRX wrote:
… then use long nose pliars through the LED wire holes in the pill to unscrew it but be careful.
Be careful of what?
Is “CRX” in reference to the car? (not mine pictured)
CRX
CRX's picture
It’s an aluminium pill with a fairly thin shelf so it would be easy to mangle it with LNP through the holes.
Firelight2
Firelight2's picture
Last seen: 9 min 26 sec ago
Awesome mod!!!
Love the blue color and wow at the output from such a tiny light.
It must get hot pretty fast at full power. Cool
sac02
sac02's picture
10-4. Will use the fatter inserts, maybe some heat, and take it gentle. Thanks for the tip.
CRX
CRX's picture
Firelight2 wrote:
Awesome mod!!!
Thanks, yeah it was meant to go from dark purple at the front to a darker blue/ cyan at the back to match the cyan GITD around the switch and I am waiting on an ice blue trit for the lanyard hole but I let it get a bit too hot on the gas.
That’s one good thing about living here, not much overheats LOL
CRX
CRX's picture
Could be Wink
MRsDNF
MRsDNF's picture
Last seen: 2 hours 30 min ago
Another fine mod CRX.
Are you sure its not this one*? More fun. Smile
CRX
CRX's picture
Haha, too old for dirt bikes now, takes too long to heal.
ChibiM
ChibiM's picture
Last seen: 11 hours 14 min ago
CRX, that is pretty sick! You pulled that one off really well.
