<5dollar-mini-zoom-USB-rechargable-flashlight
32 posts / 0 new
djozz
djozz's picture
Last seen: 2 min 17 sec ago
This little zoomie can be found everywhere on aliexpress for next to nothing, but still it has an inbuilt battery and USB connector sticking out under the tailcap, very convenient. So it caught my attention and I ordered one and it came in today. I had a quick glance at it (well, BLF-modder kind of quick Wink ) and decided that it deserves its own thread, because it has options and because a light this cheap just is very BLF Party
I have not found out everything about it, but it does work, it has a XP-E type of fake almost purple-white led, has a good spot when zoomed in, an ok but not-so-wide flood when zoomed out, it charges with a handsome red led behind the switch, and the build is quite ok for what you pay.
The options: if you just swap the led for a real Cree, or whatever XP-size real led, it already is a quite attractive flashlight! And I'm sure there's many more modding options, that have to be found out.
I have not checked low voltage handling and charging profile yet, will do that one of these days. Of course you want that to be correct and safe!
My copy came with this awesome lettering Cool but it looks like they do not all have that:
This is how it looks on the inside:
I will unsolder that battery and check capacity. A probable mod will be replacing it with a better one.
More info to follow. Any contributions from others more than welcome!
link to djozz tests
“I used to think that top environmental problems were biodiversity loss, ecosystem collapse and climate change. I thought that thirty years of good science could address these problems. I was wrong. The top environmental problems are selfishness, greed and apathy, and to deal with these we need a cultural and spiritual transformation. And we scientists don’t know how to do that.”   (Gus Speth)
Edited by: djozz on 03/17/2017 - 16:37
Tinderbox UK
Tinderbox UK's picture
I bought a couple of these flashlight, I gave one to my brother-in-law we both love them, you can zoom in and out with one hand, and i bought them for £3.28 each.
I have not watched the video yet, I hope i can replace the battery without destroying it.
John.
SkyRC MC3000 – Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
sb56637
sb56637's picture
Last seen: 5 hours 37 min ago
Indeed it doesn’t look half bad. Have a link perchance?
The Miller
The Miller's picture
Nice still not came to taking one apart to see what’s inside, Djozz did it yay!
djozz
djozz's picture
Sure, here is one that is cheap, many sold and with free shipping.
link to djozz tests
blueb8llz
Last seen: 1 hour 10 min ago
Wow doesn’t look half bad. It even has a side switch. Does it operate like the srk. Cycle all mode to turn off?
Tinderbox UK
OPPss i deleted the £3.28 link as the £3.33 eBay seller has better feedback, you can buy them all over the internet, I have seen them in black and gold.
http://www.ebay.co.uk/itm/132125797183?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
John.
djozz
djozz's picture
From the descriptions it seems there is no low voltage protection. “When light gets dim, recharge”. I wonder if you solder in a protected battery if that just would work, including resetting a tripped LVP when it is recharged.
Btw, the UI is a high-low-strobe-off cycle, with no detectable PWM Thumbs Up on the low setting.
link to djozz tests
Tinderbox UK
Only bad point so far, the worst looking o-ring i have ever seen, looks like it`s been punched out of some rubber/silicone and has excess still attached, and it looks like it will break just by looking at it, easy to replace though.
John.
djozz
djozz's picture
Trying to run down the battery, I’m at 2.72V now. When at this point I switch on the light it starts bright (-ish Wink ) and within seconds turns very dim. So the advice does work: the stock battery struggles to deliver any power under 3V and so you are notified to charge it at a still safe voltage Party
link to djozz tests
sb56637
sb56637's picture
John.
Cool thanks, I grabbed two of ‘em.
sac02
sac02's picture
One of the user pics in the reviews section of the aliexpress link shows both red and green button lighting, so maybe the button turns red at low voltage? Or maybe red when charging. I can’t read Cyrillic.
Tinderbox UK
The power button lights red while charging and turn green when full, I dont know if these is any low voltage warning.
It seems to draw around 450ma while charging, this drops as the battery charges.
John.
sb56637
sb56637's picture
I’d be interested in knowing the parasitic drain from that e-switch. (I suspect you won’t have to wait long djozz, as it’s probably rather high. Silly )
djozz
djozz's picture
Parasitic drain is something to check too, yes.
I just removed the battery and put it in the Opus for capacity check, in the meantime I soldered another battery in Smile
It almost fits (had to cut away a tiny bit of plastic)
I did not check before, but the light does 130 lumen flood now. That can only be better with another led. (and thicker wires, tweaking the driver, etc.)
link to djozz tests
Boaz
Boaz's picture
Last seen: 5 days 16 hours ago
 also looks like  ...
FIX  U UP   DIE  !
djozz
djozz's picture
You do not even have to read it loud backwards, creepy!
link to djozz tests
Tinderbox UK
Mine does not have any logo on it.
Tinderbox UK
I have seen a smaller non zoomable version for sale, but I prefer the zoom myself.
I wish the high and low had a bigger spacing.
John
sb56637
sb56637's picture
Double-click or single click into strobe mode? Long or short press for on/off?
So let’s say 100 lumens with the original battery… that’s actually incredible for the price. Imagine that when I started this hobby I was thrilled with the maybe 15 lumens put out by this light, which actually cost more than this zoomie, and didn’t come with a battery or an integrated charger. Cash
djozz
djozz's picture
No, just clicking forward: off-high-low-strobe-off-high-low-strobe-off-high etc.
The next iteration: dedomed ‘Mitko’ XP-E2 R3 0D on a Noctigon, glued in with AA-Adhesive (because I can…)
Surprisingly, the output in flood has not increased, still 130lm. But for the rest:
-infinitely better tint (0D’s dedome pretty nice)
-infinitely better beam (took care of most beam artifacts, and the XP-E2 die just looks better)
-better throw (I measure 24kcd, which is about half of the max that you can get with this size lens)
Slowly this is becoming pretty decent Smile
link to djozz tests
djozz
djozz's picture
…and the results are in:
310 mAh, not great, as expected, but not really bad either, HKJ has tested lower capacity 16340 cells.
link to djozz tests
Boaz
Boaz's picture
How many amps is it pulling on hi and low ?
djozz
djozz's picture
I can’t tell without unsoldering wires, next time I have it apart I will measure current.
I can have a guess of course for a ballpark number: 130 OTF lm in a zoomie may be 180 ledlumen, roughly times three gives current, so 550 mA ?
Low gives 25% the output of high, so maybe 130 mA ?
link to djozz tests
djozz
djozz's picture
As requested, the current measured over the ledwire:
Next little step:
I beefed up and shortened some wires here and there and it did not help the output much.
But what are those 1.2 Ohm resistors doing in the led- path?, that is not very BLF!
Ah, that is better, how’s the current now?
That helped, just doubled the current, 1.4 A is quite right for a XP-E2 on a Noctigon, with average heat path.
I guess I will have new output and throw numbers, re-charging the little light now….
I’m having a lot of fun with this light sofar! Budget lights rule once again!
link to djozz tests
sb56637
sb56637's picture
That’s the BLF spirit, djozz! Thumbs Up
djozz
djozz's picture
Thanks Smile
And I’m sure if you seriously go into minimising all resistances, and solder in an Efest IMR battery, you get 2+ amps to the XP-E2 and more to lower voltage leds.
link to djozz tests
hank
hank's picture
Last seen: 2 days 18 hours ago
So this is called a “WOOZ” as read from the picture?
The Miller
Thanks for these tests Jos
Dang so short of a time I am sucked in, amazing how far it has come.
djozz
djozz's picture
New numbers.
<5dollar-mini-zoom-USB-rechargable-flashlight, dedomed XP-E2 R3 0D on 16mm Noctigon, focusshift from thicker Noctigon repaired with extra o-ring between the two pill-parts, Keeppower protected li-ion, some wires shortened, some a tiny bit thicker, current limiting resistors bypassed:
Output in flood at 30 seconds with fully charged battery: 190 lumen
Throw at 30 seconds with fully charged battery: 38 kcd.
The throw is pretty close to the maximum that I have got for this lens (43 kcd in an Ultrafire AT-007, same type lens).
link to djozz tests
hank
hank's picture
djozz, do you have a picture of the board after you removed the resistors?
