Test/review of USB battery box Blitzwolf QC3 power bank 15600mAh BW-P5
5 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 37 min ago
DSC_8128
The box has six 2600mAh 18650 cells and with two usb output, one can do quick charge.
The specifications are:
  • Capacity: 15600mAh/57.75Wh
  • Power: 18W
  • Battery Type: 3.7V 2600mAh 18650 Battery Cell *6
  • Input: 5V/2A (max)
  • QC Output: 3.6-6.5V/3A,6.5-9V/2A,9-12V/1.5A (QC3.0)
  • Power3S Output: 2.4A(max)
  • Size168 X 61.5 X 21.3 mm
  • Weight: 420g
I got this battery box from Banggood.
How does it look
DSC_8105
The power bank is delivered in brown cardboard box.
DSC_8125
It contains the power bank, a usb cable and a instruction sheet.
DSC_8129
Connectors and switch is placed at one end:
  • On and status button.
  • Micro usb for charge input.
  • A 2.4A usb output.
  • A Quick Charge 3.0 usb output.
DSC_8133
Leds for charge status is placed on the top of the power bank beneath some small holes.
DSC_8131
On the back of the box is the specifications and approval marks.
DSC_8134
Measurements
  • Both outputs used automatic coding with Apple 2.4A as maximum.
  • When charging the leds shows charge state.
  • Lowest voltage for QC3 is 4.17V
  • A short press on the button will turn on output and show the charge state.
  • Output turns off after some time without load
  • Power bank can be used as UPS, this works best on QC output.
  • Weight: 398g without accessories
  • Size: 168.5 × 61.6 × 21.4mm
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20load%20sweep
The normal usb output is rated for 2.4A and can deliver 2.7A before it shuts down, this looks good.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC5V%20load%20sweep
The QC output is rated for 3A, but the current limit is above 4A, this is rather high for usb connectors.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC9V%20load%20sweep
At 9V the output is rated for 2A and can deliver 2.6A, before it drops to 5V
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC12V%20load%20sweep
On 12V it is rated for 1.5A and can deliver 1.8A before it drops to 5V.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20charge%20load%20sweep
The normal usb output has a lower voltage when the power banks is being charged.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC5V%20charge%20load%20sweep
On the QC output the boost converter will keep the output voltage up to the selected QC voltage.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20usb%20out%2010ohm
The power bank can deliver 0.5A for about 22 hours on the normal usb output. This is about 55Wh and matches fine with the rated 57.7Wh.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC5V%20usb%20out%2010ohm
And the same on the QC output, i.e. the converters has about the same efficiency.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20usb%20out%205ohm
At 1A load the time is down to 10 hours.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20usb%20out%202ohm
And at 2.5A load the time is nearly 4 hours.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC9V%20usb%20out%2010ohm
Drawing 0.9A at 9V is about 6½ hour.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20QC12V%20usb%20out%2010ohm
Drawing 1.2A at 12V is about 3½ hour.
All outputs maintain voltage nicely until the power bank is empty at these loads.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%202x1.5A%20load%20test
Loading both normal usb and quick charge usb output at the same time with 1.5A, i.e. a total of 25 watt did not work for long.
It could only maintain the output for a bit over a minute before it shut down.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%202x1A%20load%20test
Reducing the load top 1A (total 17 watt) works much better, here I could maintain the output for about 3 hours.
I.e. the power bank cannot charge two power hungry smart phones at once, but anything a bit more moderate will work.
10ohm
The noise is 11mV rms and 358mVpp, at this low load there is a little bit of noise.
5ohm
The noise is 9mV rms and 100mVpp
2ohm
The noise is 17mV rms and 99mVpp
10ohmQC5V
The noise is 10mV rms and 88mVpp
2ohmQC5V
The noise is 38mV rms and 241mVpp
10ohmQC9V
The noise is 52mV rms and 260mVpp
10ohmQC12V
The noise is 108mV rms and 565mVpp, boosting the voltage increases the noise.
The power bank is specified to use 2A while charging and the current draw is close to that, this means 8 hours charge time. It looks like it uses a nice CC/CV charge algorithm.
Blitzwolf%20QC3%20power%20bank%2015600mAh%20BW-P5%20charge%200.5ohm
Using a charger with less current, low output voltage or a long charge lead requires a lot of patience because the charger turns the current way down. With 0.5ohm in series with the 5V power supply it took 40 hours to charge.
Conclusion
The power bank have two high power outputs, one with quick charge, it can charge one high power device or two moderate devices at a time. Noise levels are low in most situations.
With 15600mAh is has a lot of energy, but with more modern batteries it could have contained more energy without being any heavier.
I will call it a good power bank.
Notes
The power bank was supplied by Banggood for review.
Read more about how I test USB power supplies and chargers
patmurris
patmurris's picture
Last seen: 6 hours 30 min ago
Thanks for the in-depth review as usual.
I’m not too familiar with those power box but just bought an empty TOMO 4×18650 into which i dropped my choice of cells.
Do i understand correctly that you cannot change the cells in the one you just reviewed?
HKJ
HKJ's picture
Correct.
MRsDNF
MRsDNF's picture
Last seen: 1 hour 57 min ago
Thanks HKJ. Its a shame the batteries cannot be changed out but I guess they do that for a reason.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
dodge_911
dodge_911's picture
Last seen: 15 hours 31 min ago
So it does support pass-through charging?
I have completely missed that in my tests, I guess  :/
:: youtube ::
http://bit.ly/dodgereviewsyt
    :: powerbank capacity tests ::
http://bit.ly/drpbcc
:: μusb cable tests ::
http://bit.ly/drmicrousb
:: lightning cable tests ::
http://bit.ly/drlightning
 :: type-C cable tests ::
http://bit.ly/drtypec
