Planning an aspheric scratch build
142 posts / 0 new
Enderman
Enderman's picture
Last seen: 5 hours 59 min ago
sedstar wrote:
okay.
let me try a different approach approach to this.
is anyone saying that the f-number equation… is not a valid equation?
yes or no.
Valid for what?
A 10mm lens with 10mm focal length has the same f number as a 1000mm lens with 1000mm focal length, however the 1000mm lens will throw further because the delta of incidence angles is smaller.
I think you guys are forgetting that an LED is not a point source of light, and therefore it is also important to have the optic as far away as possible from the LED (in order to minimize the delta).
tekwyzrd
tekwyzrd's picture
Last seen: 1 month 1 day ago
@sedstar Not me. I just want to check the accuracy of claimed focal length and show for a given lens size the effect of focal length (and related f number) on the beam projected. As a former calibration tech (metrology) quantifiable data and related testing have a special significance for me.
If you know the significance of the 4:1 ratio in metrology you get a cookie.
The relationship between lens diameter and focal length are in a way (to me anyway) similar to resistance and capacitance in an rc circuit.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
tekwyzrd
tekwyzrd's picture
FWIW, the first stage of my plan is to use a set diameter lens and a range of focal lengths with the same emitter. The second stage is to use a set focal length and a variety of diameters with the same emitter. Third stage is lenses with the same (or as close as possible ‘f number’. To minimize cost the head tubes will be rolled aluminum flashing sprayed flat black inside. I’m not wealthy so it will take a while to accumulate lenses to illustrate the relationship between lens diameter and focal length and the resulting beam.
Enderman
Enderman's picture
You can also download a free ray tracing tool like http://arachnoid.com/OpticalRayTracer/ to get a pretty accurate guess as to how the lenses will perform.
tekwyzrd
tekwyzrd's picture
That’s assuming the lenses are sold with accurate characteristics in the description. Often these lenses are offered via sites that also offer 5000 mAh 18650s and 30k lumen latticebright powered flashlights. Establishing a baseline for comparison with real dimensions and values should be useful.
Enderman
Enderman's picture
tekwyzrd wrote:
That’s assuming the lenses are sold with accurate characteristics in the description. Often these lenses are offered via sites that also offer 5000 mAh 18650s and 30k lumen latticebright powered flashlights. Establishing a baseline for comparison with dimensions and results should be useful.
The diameter and thickness are pretty accurate, that’s all you need to know to replicate a lens similar in the software.
Playing around with the diameters and focal lengths and stuff you can see why it is better to have larger diameter and longer focal length.
The ray tracer emits all rays from a single point though, so to see the irl divergence you need to place the origin of the rays about 1mm below the x axis (depending on the led) and look at how much divergence the rays have.
The farther the optic is from the LED, the less the rays diverge.
sedstar
Last seen: 1 year 4 months ago
@enderman…
try to appreciate, i spent most of my life relatively uninterested in photography, beyond if i needed to take apicture? i wanted a camera. i was always fascinated by japanese tourist cameras, as we called them in the old analog days… but, as a mechanical curiosity to me only. if you had one? i wanted to touch it, i wanted to play with the focus and be allowed to snap a pic.
i was always at these times, curious of what “the weird controls were”. its unexplainable to a complete camera noob. they would set the shutter and iris control? i was allowed to “play the focus” and snap my few pics.
then came the night vision projects? LMAO. i had to jump INTO this, and unfortunately? i suddenly hada burning NEED to understand as much as i could about the math of optics, if i was to design something, to uncover something. i had to “grok” the entire system in as much mathematical model as i was able to.
to be into night vision though? is to be into focusing flashlights, though. suddenly? i had to learn about “zoomies”. how to mod a regular zoomie into one. how to make it better. which lens to use… i devised strategies, both mathematical and practical hand tuning… to construct 2 lens zoomies. i can make a “true zoom” zoomie.
i can do those things back into camera lenses too… it all related and intertwined.
my background in computer science and mathematics in a former life? allowed me to do this, and in a deeper, fuller way than the guys just building builds…
but, i “See” all this… for lack of no better WORD… “how” i see it… and i know that the f-number relates image brightness, and the same way translates into PROJECTED brightness. i achieved what i set out to try to do, to make a infrared flashlight that put my emitter, same one everyone else was using… to a distance record at that time. i achieved something for myself in my hobby field. i ended up with my very own “build” and i got to name it.
visible flashlights? being here? was at first, just a fluke., i was into this, only cause i needed tobe… but, you know, had to get just one LED visible flashlight, LMAO… caught the bug.
i can mathematically model a second lens onto any lens, thats imaging or zoomie, and pick my f-number and focal length? practically at will… nd its only possible thru math, and an understanding of the importance of what an f number is, and how to use it, design wise.
look… i am starting to “grok” what YOU mean now? your recent post with the 10/10 and 1000/1000 lenses “both being f1.0” got me seeing a little from your point of view… but… if now YOU can try to see things a little from MY point of view?
a L-O-T of “flashlight people” were wandering into our night vision site? and i gotta tell you, they dont “grok” it completely the way YOU just tried to explain “what you meant”… what do they “know”? what do they take away from what you guys say? this:
1) to SAY the phrase “diameter is alllllll that matters! nyah nyah”
2) they actually believe, naively and incompletely? that we were supposed to choose out lens, to build our next better zoomie? simply by picking any, and i mean A-N-Y… larger diameter lens.
look, i asked the guy that “came to help us out, since we needed help”? i asked him this:
“sir? let me take out 17 different lenses. random focal lengths. all the same diameter. the individual lenses? they have focal lengths, ranging from as low as 10mm FL… up to one thats 1200mm FL… all of them, though, are 60mm in diameter… are you trying to tell us here, that ANY of those lenses, slapped onto our infrared zoomie build? will all work equally as well? just because they are all 60mm diameter? is that what you are saying?”
he said:
“yes, you finally got it!”
then someone (one of our “lens whores” as we call them there?) whipped up, for a joke… three impromptu zoomies, you know, workbench temporary slap togethers… all the same emitter, with 3 VERY different FL lenses, and showed him what he was implying we “should do”… when he finally SAW that the CAMERA SENSOR needed a certain S-I-Z-E of focused emitter to fill the screen????
he went “oh……” and went very quiet.
all…..he…… grokked……
because of HOW it gets stated? was that “bigger diameter is better! focal length is meaningless!” and we took him for, well… somewhat of a moron.
I suppose N-O-W i am seeing that in the flashlight world? ehhh. you just want a really bright light… a super charged emitter… and you place any lens over it. if its a flooder, its a flooder… if its a thrower its thrower… you can get USE out of it, no matter whether its a mule, a mid grade, or a pencil super thrower?
but… in night vision? the size of that projected emitter? better MATCH the camera view. you know what i mean? a flooder is useless, a tiny pencil mean is useless.
that guy had learned NOTHING about making zoomie flashlights? except to repeat the following phrase like a parrot:
“focal length doesnt mean anything….. only diameter has any bearing on anything….”
and honestly? theres a zillion peole running around the internet world, going off half cocked with this idea. it would be so bad, but… they CORRECT everyone having any discussion, as if they are sage wizards. and most of them cant build anything.
i was on a telescope building site? doing my duty for he night vision site, seeing what optics pros i could find and drag onto my site, to help us? i thought surely some telescope builder could helpus maybe, hey, i was trying…
the telescope guys told me about “some moron” who came to their telescope site? telling THEM that for astral photography? they didnt need to “worry” about focal length and f numbers, because… well, they needed to “understand the truth” that only lens diameter “mattered” for pusposes of getting more light thru the telescope system.
so, when i said i was there “seeing if anyone could give me any designideas for a multiple lens flashlight projecty” they eyed me with GREAT SUSPICION, as you can well imagine, their previous meeting with a “flashlight internet guy” having been so moronic. i had to “prove myself” with a few light math post discussions, before anyone wouldtalk with me about my project.
i’m not entirely sure, that you guys realize what impression this is leaving in the minds of people with no backgroundin math, in your hobby, trying to learn how you math guys do what you do?
all many of them are learning, is to repeat one single phrase:
focal length does nothing… only diameter makes it pass more light…
and they authoritatively are “correcting” people, having some air of grand knowledge…
am i making my point, of what i have encountered, better? people with no math to them (and there are many in the world) are learning to repeat the phrase, like a parrot… i think there needs to be SOME more ideas given to them. if you know what i mean?
eh?
i acted, like i acted??? i thought everyone was acing as if the f-number didnt exist and focal lengths were irrelevant.
for ME? controlling the exact projected size of the emitter (degree size, projection) isnt just a flood or throw “what kind of light do i feel like making today” kind of thing…
for a 3x night vision system? i need a specific FL zoomie lens, to fil THAT scope view correctly.
on 5x? i need a different FL
on 9x? i need a different FL
my focal length, on my IR zoomie? completely controls the size of my emitter in my field of view, expressed mainly in radians, and half angles, and projective geometry.
then of course, i want to pump as many amps thru the poor emitter as it will stand my build heatsinking without making magic blue smoke, lol…
in my design world? i dont have the luxury of making whatever “beamshape” i feel like making. so yeah, focal length and f numbers are critical. they are design criteria number one two three and four five and six.
are you now seeing things from my perspective? peolpe from flashlight sites were coming in and saying things completely backwards, IE, “bigger focal length makes a bigger emitter!” and we point out thats backwards? “oh well, it doesnt matter anyways! only diameter means anything for more throw!”
the night vision guys, and even the telescope guys on that site? we were all math guys, and we were wondering where these morons were coming from, that understood nothing, except to repeat that one phrase, like a parrot.
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
Barkuti
Barkuti's picture
Last seen: 5 min 21 sec ago
This may be of interest to you, my focusing freaks: Focus Tunable Lenses for LED Lighting by Optotune AG
Cheers
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
luminarium iaculator
luminarium iaculator's picture
Last seen: 6 days 20 hours ago
Sedstar,
Sunnranger(you know and most of guys here don’t know) is multiple lenses system illuminator(or flashlight) based on yukon night vision device 3×42, F1.4? (there is also bigger version ).
Plenty of guys on nvforum were comparing it throw to 67 mm aspheric (X searcher and T67) and it had beaten them in terms of throw but they did not take one important variable – they were not all build under same conditions (same driver, same emitter).
So with proper variables(all systems with same driver and same emitter) when we use SR with IR emitter (4715as for example) has spot size somewhere on half way of hotspot on 50 and 67 mm lenses and visually it really seems that it is out throwing 50 mm and very close to 67 mm one because it has ultra clear die projection I never seen in my life. I can’t measure invisible light…
But I’ve also decided to build fet driven xp-g2 s4 2b SR pill to convert it into flashlight and I really expected that it will kill at least 50mm aspheric and that it will be close(performance vise) to 67mm one since nothing in classic aspherical flashlight world has clearer die projection.
Seriously guys you’ve never seen clearer die projection than in mentioned Sunnranger system but when I put it on the lux meter it was total disappointment throwing around 10-20% less than classic 50mm ones Angry so it has smaller die projection than 50 mm one and yet throwing less…
Now something good is probably happening when we use IR light source(or even red emitter source inside such system) since it seems that it is passing that light through system much better than visible white led light.
My thought is that special NV AR coating on SR lenses is killing white led light transmission by stopping of blue or other important color that needs to be projected through lenses to give best performance…
I want to say that this system has great potential Why? 42mm lenses that should throw close to 67mm lenses size which means more throw in smaller head diameter.
sedstar
Hi Luminarium !
Luminarium is from my nigh vision site… we are all “zoomie guys: dyed in the wool… we have no choice but to be zoomie guys…
i was already wanting to make a multiple lens zoomie, and while i was arguing with everyone it was possible… look at my equations… (nobody will look at or cares about equations, by the way) so while i am aguing its possible, and its desireable? at the same time, they were all oohing and aahing over the light he is talking about!
i still remember seeing it, and realizing it was a multiple lens zoomie, and one guy said “good god, i was wondering when he would notice it”..
so, while everyone is telling me it wont work, or that its not practical? at the same time,they are all using it !! (kind of ironic)
also… i had gone and was making 2, then 3… and even one 4 lens zoomie setup… trust me, “the lads” on the site? will remember me and my software to perform the math so no one had to solve equations… not one download, but, they will remember me posting about it if nothing else
i was posting pictures and a short movie? showing MY light, with the same emitter? beating larger diameter “single lens” traditional zoomies. i had the same emitter, and either the same or less current driver… it allowed the lower diameter len SYSTEM to “punch above its weight class”
DIAMETER, you run into a wall… you cant get bigger after a certain point in a gun mounted system… which therefore limits you? adding a second lens behind it? i am able to DROP the f-number and change the focal length…
by running the equations at design time? i found i could pick my f-number and focal length of the system? practically at will…
diameter was NOT the only way to get more moonbats thru the lens… i simply added a lens, which dropped the f-number, and changed the focal length…
i am still the only one on the night vision site? that routinely adds lenses to existing imaging lenses? to change the focal length, and drop the f-number… driving night vision performance UP…
i might not still have the distance record? but i should check… even if i dont? i am not sure erveryone realizes my distanceswere achieved? with the OLD oslon emitter, and the wimpy 1A drivers we were limited to at the time… my high distances? were with half powerful emitter and lower amps than what they use today…
smaller diameter lens, less amps, still keeping up with the joneses !
(whos your daddy… smak-smak-smak,,,, whos your daddy… smak-smak-smak)
SALES THREAD:
sedstar
what great amusement the world gets, out of forcing the software engineer, who SHOULD be just designing prototypes out of cardboard and plastic? what hes good at?
i dont understand the amusement at making the software engineer learn metal fabricating skills, and machining, and now foundry work? because the machinists refuse to build his units that work better.
the designer? should design. when the prototype works better? then the builders should… well… build it!
i dont ask my mechanic to design me a GPS unit, do i? no… its insane.
my plumber wouldnt ask me to fix his toilet, would he? no. insane.
so, why do i have to go thru all this, for a couple years?
i dont know… but i know this…“they” finally ticked off the wrong software engineer this time… heh heh heh
I am almost complete, in a COMPLETE vertical organization strategy, a-la Henry Ford…
1) i am going to go from scrap aluminum? directly to machining stock in a single step. cost savings.
2) i am the machinist and the fabricator? i dont have to pay a machinist 25 dollars an hour for his time. cost savings.
3) i am the electronics guy, i wire and “mod” everything myself. no outside electronics work. cost savings.
4) i always WAS the designer, doing what everyone else says cant work, showing prototypes that DID work better.
when i am almost done, and i finally come home? “clear me a path”, they aint gonna know WHAT hit them, ha ha ha
i have the persistence, usually reserved for only the truly demented, lol…
SALES THREAD:
sedstar
some of my friends? they think i’ve gon completely mad, i tell you, lol…
all the notebooks of equations? invisible flashlights? machining equipment? now one stops over, i am pouring red hot molten aluminum in my living room? laughing like a madman?
some of them think i have gone stark raving mad…
SALES THREAD:
Sedstar knows well what he is talking about…
Multiple lenses system have potential. I (and a lot of other guys along with Sedstar) have build it and I know what can be achieved…
The most crisp and sharp die projection ever but in my case it is not equally followed by candela or lux performance when I use classic flashlight emitters because of special NV coating issues I have with yukon lenses… They don’t pass certain color of white emitters so performance is lower than it should be. But with IR emitter and NV equipment is clearly seen potential of such system.
Flashlights based on camera lenses or night vision lenses? Achievable!
I think I will try again but this time with some cheap China variable lenses without AR coating.
And I am also the guy who thinks that aspheric after certain size is undesirable… It is individual but to me sweet spot is 50mm aspheric so if I can have 42mm(or even less) multiple lenses system that will throw like lets say 67 mm lenses than that system is worth a try.
If anyone will read what we are talking about it looks like this:
That should be equivalent to 67mm IR illuminators single aspheric system.
Enderman
Enderman's picture
Sedstar
Could you try to form complete sentences or paragraphs please?
It’s hard to read the jumble of text…try to keep it short too, thanks.
Whoever said that only diameter matters is completely wrong.
Both diameter and focal length matter.
Saying only the F number matters is also wrong, because of what I explained with 10mm vs 1000mm
Both diameter and focal length matter independently.
Multi-lens systems are good if you want to collect as many lumens as possible, this flashlight uses a dual lens system to collect nearly 100% of the light into the lens:
The problem with multi-lens setups is that
A) any defects in the lenses get multiplied at every stage, therefore you need extremely high quality lenses or else there will be visual artifacts
B) there is a lens closer to the LED than in a single lens setup, which increases the divergence hence giving the projected spot a “less sharp” or “larger” size.
Ideally, an LED would be a point source of light and it wouldn’t matter how close the optics were to the LED. We would be able to build flashlights with 10mm lenses that would throw just as much as 1000mm lenses.
This is Mjolnir from Vinz right?
This is not multiple lens system; afaik it uses precoolimator lenses only for main beam enlargement. So it is single lens system with added precoolimator to the emitter. But maybe I am wrong?
Sunnranger is triple(or even 4) independent lens system with de-focus to over-focus ability.
Although it has multiple lenses it has clearest die projection ever. This is example with red emitter:
Or this in comparison with classic aspheric beam:
Enderman
Enderman's picture
!{height:400px; width:600px}http://i1057.photobucket.com/albums/t394/fizzbangwhallop/SAM_0935_zps3b0...!
The precollimator is a tiny lens, so yes it is a multi-lens system.
You can see in your image that it is not a clear die projection at all. There is massive red spill around the image, obviously caused by all those stages.
A “clear die projection” would not have that massive red corona round it.
I saw plenty of aspheric beam and used almost every commercial available aspherical flashlights in a world and I can say that Sunnranger has the clearest die projection…
You can’t avoid little reflection from emitter.
This is sunnranger with white emitter:
Although camera can’t catch all sharpness you can see with your eye it should be clear as day to anyone who have dealt with aspherical flashlights that this is the cleareast die projection ever (far better than lets say B158 which also has very nice beam projection).
For me since I also use precoolimators in my aspherical builds; precoolimator is just a way to enlarge main beam projection without lux loss so I never thought about it as dual lens system although technically as U said it really is dual lens system (precoolimator + main lenses).
In sunnranger you can also add precoolimator to emitter and then you would have 4-5 lens system.
Enderman
Enderman's picture
The large circle of light is not from “reflection from the emitter” it is caused by the large amount of optical stages, and refraction between the stages.
As I said before, these multi-optic systems give more lumens but also increases the size of the projection.
A single optical stage would not cause that circle of spill light, and would create a smaller projection while collecting less lumens.
If you look at a high quality single-lens projection of a die you will see that it is just as clear as the sunnranger.
Unfortunately I can’t find any specs or product page for the sunnranger?
sedstar
the sunranger build…
it started life as a regular zoomie. crelant something rings a bell??
someone tried a night vision imaging lens in place of a regular zoomie lens on it? and it kicked @$$ on accident.
they had to fabricate it up at that point. it was just on a lark? next thing you know, it was the “best build” for an infrared illuminator for a while.
since we use infrared emitters for our night vision zoomies, and since it was a night vision camera lens it worked out very well. (the coatings would have been optimized for night vision infrared, and when used with an infrared emitter, well, things lined up well)
PS – should i be watching my spelling as well as my grammar and punctuation? lol…
SALES THREAD:
Enderman
Enderman's picture
Yeah, punctuation and grammar helps a lot, especially when there’s so much text.
sedstar
QUOTE
ENDQUOTE
i might have to throw a flag on the play.
size of the emitter projected? is purely a function of two things… actual emitter size, and the focal length of the lens.
it doesnt matter if you use one or 9 lenses? the overall focal length of the single or compound lens, will determine the emitter projected size… now, THAT STATED? i do know what you meant by that statement…
SALES THREAD:
sedstar
QUOTE
ENDQUOTE
eh?
SALES THREAD:
Enderman
Enderman's picture
When you have multiple optic stages vs single stage, (assuming the final lens is at the same distance) that means the other optical stages are closer to the LED.
Since they are closer, the focal length is shorter, which means the delta angle is bigger and results in a larger die projection.
Of course if you have the closest lens at the same distance at the single lens then the focal distance is the same and the size would be the same, but then there isn’t really a point to the multi-lens system because it would take up more space without increasing the light captured.
(Assuming same diameter)
PS- there is a quote button at the bottom right
Enderman
Enderman's picture
The main point of multi-stage optics is to have the system collect more of the light from the LED without increasing the lens diameter to gigantic sizes.
It’s easier to move a lens closer to the LED than to make a giant diameter lens in order to capture more degrees of light.
sedstar
oh, no! we have violated Coghlan’s law of absolute throw!
we made something better, without increasing diameter!
snicker
now… mind you, i am impressed you know whats going on with dual lenses. thats a rarity in the flashlight world.
do you know how to calculate the focal length of a dual lens setup? optically,the 2 lenses being used are thought to be combined into one compound lens, with one overall focal length, and are treated as a single lens…
SALES THREAD:
Enderman
Enderman's picture
But the point of doing that is not throw, it is increasing optical efficiency by capturing more lumens…
It has more lumens, but projects them over a larger area, therefore making a bigger spot with more lumens, and not more throw.
With a multi lens setup you use the focal distance of the closest lens, every optical stage after that continues to increase the divergence.
You can use any ray tracer to see how adding stages affects the divergence.
Often with multi-stage optics you need a bunch of custom made precision pieces and there’s a ton of variables, I much prefer working with single stage optics to not have to deal with error/imperfections getting multiplied at each stage, and lower production cost.
sedstar
ho… not so fast… slow down.
your right, but, you are making an assumption that doesnt necessarily need be true.
1) lets use as an example a single lens setup, one lens with focal length of 100mm
2) a lot of light as we know, wont hit the lens, its lost to the sides before it hits the lens 100mm away
3) what to do? well, we will use two lenses. one of them, the one with shorter focal length? will be closer to the lens, and will collect more light. it will focus it a little,keeping more light now to hit the bigger lens.
4) it is true, that if the same 100mm front lens is kept, the new compound lens? will indeed have less than 100mm combined focal length, and so the emitter projected will be bigger because of the lower focal length of this new compound lens. and yes, it will be brighter because that first lens collected light that would have been otherwise lost, so, efficiency is up and the bigger projected emitter is now brighter.
5) the assumption you are guilty of making? who said we will KEEP the original front 100mm lens?
to wit…
6) we will replace the single 100mm FL big lens? with 2 lenses, true… but two different lenses! we WANT the projected emitter size of the 100mm FL single lens? so, we obviously WANTED that size of emitter projection, right?
7)why couldnt we simply pick 2 lenses… such that theres a smaller lens with shorter FL near the emitter, giving us the efficiency we want…
8) we simply pick the correct new front lens? of a focal length that those 2 combine to produce a resultant compound lens… that is 100mm focal length in total!
9) we get a free lunch here…the rear lens collects more light earlier, we have the higher efficiency we like… if it combines with a front lens that the compound lens is 100mm FL overall? we get the same size projected emitter! and its still brighter!
i know, how hard would that be? easy… i found the proper equation(s) to predict it, ha ha… and i can prove it.
you dont poop your pants over a little algebra, do you? go on… dare me.
SALES THREAD:
Enderman
Enderman's picture
No, the divergence of the beam depends on the LED distance from the first optic.
Once the light hits that optic then the divergence can only get larger, not smaller.
You can ignore all the other stages, because the first stage close to the LED will already cause more divergence than a large 100mm lens farther away.
Here is an extremely exaggerated example:
In order to simulate a non-point-source of light, the rays are coming from a few mm above y=0, representing light coming from some place that is not the center of the LED.
The closer the first optic is to the LED, the more divergence there will be.
the green line would represent a point source of light right at the focal point, which results in perfect collimation.
the red lines represent the minimum and maximum angles of light coming from the LED.
Hopefully you can see why a long focal distance is important.
PS- you’re right, you can use math to figure this out, it’s just a bit of trig.
sedstar
i’ll get to the equation in a second… but first? I mean… if i may?
we have a problem. we want it solved. that much is obvious… and we even know what we want.
just like everyone else? you are spending all your obvious considerable intelligence, abilities, and energy? explaining why it CANT be done. what is the point of that? what do you expect that to get you? problems dont get solved, by looking for more reasons why it cant be done.
your second mistake? your point of view is all wrong, from the get go… you wonder IF this can be done… i dont think like that. I simply assume it can be done, then i assume that i’m the man who’s gonna do it. you might find this way of thinking? “arrogant”. I call it “confidence”.
the problems you are creating by doing this? are that everyone ELSE keeps hearing a list of reasons why its not supposed to be able to be done. they keep repeating all the reasons why ot cant be done to each other and to more people. now, instead of a bunch of smart people working on the problem in a systematic manner looking for answers? all that is going on is everyone ends up sitting around talking about what cant be done.
so, everyone ends up doing more or less the same things over and over… wondering why things arent getting better. I mean, Einsteins definition of insanity? “doing the same things over and over, expecting different results”
now, with THAT proper frame of mind? why dont we simply list the things we NEED, then go looking for them. we already know everything we need, you just dont realize it. its just a matter of a little time, a little reading, a little leg work? to find ALL of those things we need… in one simple equation.
see? thats yet another problem right there. everyone goes looking for the answer, and if its not already done for you, and handed to you? in a nice equation in “chapter 7” somewhere in a class? they assume there is… no answer. That doesnt necessarily mean there ISNT an answer? that just means no one has found it yet… or? much more likely? the answer is already there, somewhere… its just in an equation, being used for something else, and you just dont SEE that it just needs rearranged into such a manner as to give YOU what YOU want.
on wikipedia, the basic optics page? everything is right out in the open, easy basic equations. i laughed when i finally SAW it. The answer had been staring me in the face all along. I must have read it a hundred times, and just didnt realize it.
we have 2 lenses. each has a focal length. there is some distance between those two lenses, or, they could be touching. there will be some distance from the first smaller lens back to the emitter. and the whole new compound double lens? will have an overall new focal length.
if we knew those things? we would be done, obviously, right? lets list them…
F = new overall focal length
F1 = lens #1 focal length
F2 = lens #2 focal length
D = airgap distance between lens 1 and lens 2
BFL = back focal length, I.E. the distance from the back lens to the emitter source
Like most incredibly confusing problems? the answer is hiding RIGHT out in plain sight, for all to see, on wikipedia. Its right on the optics page, we probably most of us read it before, learning about lenses. i wanna remember they were callef the “lens makers equations” or something like that…
here they are…..
if the 2 lenses are touching? ( 1 / F ) = ( 1 / F1 ) + ( 1 / F2 )
if there is an airgap between them? ( 1 / F ) = ( 1 / F1 ) + ( 1 / F2 ) – ( D / ( F1 * F2 ) )
and the back focal length is always BFL = ( F2 * ( D – F1 ) ) / ( D – ( F1 + F2 ) )
there… theres the keys to the kingdom. hiding RIGHT in plain sight, on the basic math of optics wikipedia page. I realized? there was every one of my variables i was going to have, and whats more important? i knew the value for every one of them! the only thing i didnt know? was what i wanted… namely, what is the resulting new compound lens’s overall focal length, if two lenses are separated by an airgap with a back focal length.
simple algebra tells us, that given any equation, if we have all variables known, and one unknown? we simply solve the simple algebra problem, to isolate the unknown variable we want to know on one side by itself.
in this case, I was primarily interested in knowing the overall new focal length of the compound lens… so i simply solved the airgap equation for F… because i was unable to FIND it stated like that anywhere else.
But, let me back up a hair? originally, i was just writing down all the known variables, as stated in the given equations. all numbers. and the “F” was what i would solve for. i used paper and pencil and my trusty scientific calculator. I just ran the numbers over and over, with different focal lengths and different airgap each time, until it produced a resulting focal length closer and closer to the exact focal length i was looking for, and also had a close enough back focal length it created efficiency.
this WORKS? problem is, i was doing the probloems on the calculator and paper/pencil hundreds of times, adjusting the variables up and down a little at a time, one at a time… until i GOT the exact resultant focal length i was WANTING. This was highly inefficient…
so, i simply started SOLVING the airgap equation, in order to ISOLATE the “F” by itself ??? THIS was the ANSWER! i only had to plug in the numbers and it spit out the answer much quicker, with way less key presses on the calculator, and, way less scribbling with penciul and paper to get each answer.
this cut my work down considerably, but… since i use to be a rather high end software engineer back in the day? i was like, “dummy! simply write a short visual basic program, that allows me to enter values in for all the known variables and let the software instantly spit out the answer every time i adjust one of the values.”
which was of course exactly what i did.
after that? all i did was sit there amazed? as i plugged in different focal lengths and airgap values, watching the new overall focal length get spit out… so, when i saw the answer i wanted? i knew which two focal lengths i was looking for to buy, and also how much distance to put between the 2 lenses. i also instantly knew the back focal length, so… i also knew how far away from the emitter to place the first lens.
this? allowed me to do a-n-y-t-h-i-n-g i wanted to do!
1) i can take 2 identical 100mm FL lenses? touching (airgap zero…) and know that it makes ONE 50mm FL lens! back focal length is trivial, its 50mm…
2) as i separate them with a bigger and bigger airgap? the new focal length inches UP until it gets almost to 100mm FL, and as this happens? the back focal length is inching its way
closer to the emitter (system getting more efficient)
3) i can instantly change either or both focal lengths, and adjust the airgap… and get instant running answer as i adjust things…
4) if i know i can only have certain focal lengths of certain lenses available to me on my workbench? i can pick amopng those values, and adjust the airgap until i find the resulting new focal length I am LOOKING for.
5) maybe i want to glue a certain small focal length lens, lets say 5mm off of the emitter? i just pick values and move things around until i SEE a back focal langth thats 5mm… and a overall focal length i WANT.
as you can see? i now had the keys to the kingdom. i can make or do anything i want to. and? since i know how to MEASURE the focal length of ANY lens of any style i pick up and find? i dont have to depend on happy chinese specs, i KNOW the focal length of ANY lens i put my hands on if i want to know.
there is practically nothing i cant do with this, and quickly. when i start playing and building on the bench with visible emitters? i simply blow cigarette smoke into the light path in a dark room, and i can SEE on a piece of white paper the exact diameter lens i need to put there to capture ALL the light of the system without losing any. AND i dont have to use a bigger lens than i NEED. And??? if i know i “need” two 100mm lenses to get what i want? i can also use two lenses pout together like this to create ONE of them, use THAT for “lens 1” and start playing with making two other lenses be the OTHER “lens 2”… thereby easily and fairly quickly creating a 3 or 4 lens system.
which puts the lenses in a row, with more regular space, capturing and shaping the cone of light along the path, adjusting to not “lose” any as i go.
you see? if i try to do something “actually impossible”? the equation tells you! you get an undefined divide by zero answer. or the back lens is touching the emitter. or, you run out of space or get an error before theres enough airgap to yield the focal length you are looking for? i simply bump up one of the focal lengths and bring it back into shape.
since i already know how to predict the SIZE of a known emiters projection ata known distance (differant easy trig equation, childs play)? if you want an xml2 to be for instance 100 feet across at 300 yards? it will tell you wen you solve the chief soh cah toa, what focal length you NEED as the overall focal length to paint that size emitter at that distance.
if it calls for a 200mm diameter lens to capture all the light? poop to thatr! we just start adding lenses… click clik clik… until we have our system solved.
surplus shed? has so many different lenses of different diameters and focal lengths? its ridiculous, they are all cheap… my simple program makes it easy to play what iof for a few minutes, until you get the criteria you want.
a simple “jig” on a workbench and some cigarette smoke and a piece of white paper? allows me to do the prpototype build.
once i fab up the prototyoe out of pvc or cardboard tubes? i can cast a piece of stock and machine up to make it out of aluminum.
you keep telling me made up reasons why it “cant” be done? i already DO IT on a regular basic before! i have SEEN units that do stuff like this, its not impossible. and i have MADE the stuff before, it works.
3 or 4 equations, and i can solve hem for what i want to find by isolating any variable i want with paper and pencil… then enter the equation in the visual basic program so its yet another answer being spit out. ( i like it when my software keeps a running tally of how big an emitter is “painting” at 100 yards, i find it a handy reference)
if you wanted? i suppose i could list several emitters, and let them ALL spit answers out, or, let the person adjust the distances to see different results.
its just a couple basic equations, and a short vis basic programi made before, i could make it again in short order.
now then?
you know that phrase, “hey, he puts his pants on one leg at a time just like everyone else.”
well, hate to break it to you? i dont… i kind of hold them in front of myself and just JUMP into them all at once.
SALES THREAD:
sedstar
and yeah? i do this same thing with imaging lenses too, for night vision.
i buy a lens with longer FL than i want? and drop the FL by adding a lens behind it… which lowers the F number to wjerever i want it to be.
since the F number controls how “powerful” the night vision unit will be? it should be obvious my units are, uhm… “better”. and i can do things the other night vision builders cant do. or that they think is impossible or priced like unobtainium.
dont you see? i am an ENGINEER, i used to make “mathematical models” for a living when i was younger. i have 2 university degrees in mathematics and computer science.
look at my tag line? “with enough black coffee and cigarettes? all things are possible.”
thats not just a phrase to me… thats what i “do”.
SALES THREAD:
