Planning an aspheric scratch build
142 posts / 0 new
sedstar
Last seen: 1 year 1 month ago
well… since bulldogging thru, worked this good so far? might as well go with THAT for this session… no sense wasting being in the zone…
QUOTE
2 Aspheric lens pairs
A second aspheric lens can be added in front of the collimating lens to focus the light over a desired area. The illuminated
spot diameter at the focal plane (FP) is given by:
ENDQUOTE
well? we can do THAT now, if everything else was correct… screw it…
spot diameter = DIAMsource * (Ffocus / Fcol)
spot diameter = ? well, we know if nothing else, the diameter of the source, thats 1mm, right?
spot diameter = 1mm * (Ffocus / Fcol)
we got half of this, anyways… the spot diameter is 1mmTIMES THE RATIO, and a real nice number. more importatly? the millimeters inthe ratio will cancel out wharever they are… the answer is in millimeters, left over last unit from the 1mm source diameter, after canceling out?
million… dollar… question….
what freaking ratio? we are 1.5 equations away, from walking on water… i only know,i got the tiger by the tail and dont wanna lose it…
okay… stop… think??? we can SET the spot diameter after the lens pair? to be whatever we WANT it to BE…just, what do we ant it to BE?
uhmmmmmm. in the LAST one lens zoomie math model? using “best lens scenario”, above which the extra lens power is “useless” as the entire set of “rays” escaping the waiven collar is captured mathemastically? what more is there to “gain” than THAT?
okay… lets “go with that” assumption… we only GOT THAT optimum setup? simply because we used a waiven collar, which fired up the emitter hyper, and contained an escape angle of 60 full, 30 above the x axis… right?
so… maybe, and i mean just maybe? this portion is reserved for “getting optimum” assuming we DIDNT use the waiven collar? that we COULDNT find a suitable lens with the proper stupid numerical aperture… which is simply the F-number hiding under an assumed name…
so… we… what? we want to SET THE RATIO so as… to accomplish this, assuming we NEEDED To.???????
i’m thinking out loud…. i am talking myself into this line of thought… we are only stuck here, simply because we are ALREAY capable of finding lenses that are “optimum capture angle” already with the one lens model.
what if we WERENT ABLE TO be “here”? which is any time without THIS special emitter, without THIS special case of using a waiven coller… we WOULD want to “be here” regardless, right???
and… setting THAT RATIO, will PUT us where we want to “be”.
okay, i talked myself into it…. i am forgetting the whole single lens zoomie workup? that was just an academic exercise to get me HERE, working with THIS portion…
go back, see “what” was optimum about that setup…we RE-make it HERE, with this stupid ratio?
shrugs i like the logic train of it….
houston, we have a problem… we never calculated a “spot diameter” back there… all we calculated was a “beam diameter”. is that the same thing? engineer dont use terminology lightly… whatever the differenc ebetween a beam and a spot “is”? it might mean something… of course, it could also just be a convention based on whether you use one lens or two lenses.
decisions… decisions… decisions….
also? any clue i take from the previous session? is “switching backwards”… if i like to think of calculating this spot diameter, as the same as the beam calculation previously? the one lens collimated beam diameter, was the 2NA*Fcol equation… here? its “more like” the previous divergence formula… and my next equation, also containing this holy ratio we set? is switching the collimator/focus ratio upside down… its a reciprocal… and, thats the divergence equation in THIS section, looking more like the other equation back there…
what to do?
okay…. pondering the pnderables? lets say maybe the spot diameter and the beam diameter arent the same thing… i dont know… BUT, i am just bout to calculate the divergence, and while the equation is way different than last time? a term is a term… divergence is… divergence.
since i am trying to assume that we couldnt set divergence “optimum” and now would be our chance to do it? we couldnt get the cool lens we had for optimum last time? then i want my divergence set to “optimum” we got lucky and HIT optimum in the single lens, maybe i can use that as an “answer” then solve for the ratio i want? that will produce it?
its a thought… well, thats one variable out of the way… i need ONE of those ratios to be set for me…
hmmm. maybe we COULD use the “single lens” optimum, use that as the bigger forward focusing lens? i mean, lets not waste it… thats another variable down… where we at in the second equation? if i can SOLVE for the ratio last need, i will have the ratio to plug into the previous equation?
scrtew it, lets try that…
the optimum theta divergence, only because we HAD an attainable lens? WAS an answer of… ehat was it?
optimum radians? WAS 1 / 86.6…
so…
(1mm / 86.6mm) = 2 * NAbeam * (ratio)
mm’s cancel out…
.011547344 = 2 * NAbeam * ratio
.011547344 = 2 * .5 * ratio
.011547344 = 1 * ratio
BUt, following this line of thought? ratio = reusing the cool lens, as the “forward focus lens”?? equals 86.6 as the bottom of the ratio…
.011547344 = 1*(Fcol/86.6)
? eh
now, need the “new” collimating lens, to be… smaller than the focusing bigger lens… which is 86.6…. if i solve this, i might get the focal length of the new collimating lens, hat used with this lens, would make the optimum lens setup, assuming i didnt already have it available with one lens previously… hmmm, watch this give me a nonsensical answer, LMAO
1 times anything is anything, i am left woth…
.011547344 = Fcol/86.6
.011547344 times 86.6 = Fcol?? try it…
i get “1mm” as the proper focal length of the collimating lens….
wait a minute! that actually might make sense!
since we already HAVE the “optimum one lens”, and i was using that radians answer to derive the rest of the ratio? it is stating that the “ratio” is already set up? maybe?
okay… thats either nonsense, or it means maybe what i think it might mean… lets try this… with… a “lesser lens” and solve for the same radians answer, the optimum we already know from the one lens example…
maybe i can “hit it” based on any focal length lens i CHOOSE to use for the focuser? okay, lets se what it would be for… a 100mm FL focusing foreard lens… nice round number…
.011547344 = 1*(Fcol/86.6) scratch that….
.011547344 = 1*(Fcol/100)
.011547344 = (Fcol/100)
.011547344 = fcol/100
multiply both siddes by 100, duh…
1.1547344 = Fcol
heck, a ratio is a ratio, right? lets fire this puppy in with a… 600mm forward focusing lens… we’re just setting a ratio, right? maybe THAT will get the focusing collimator up into something reasonable to fiond in a col. lens??? worth a shot. i can create a ratio out of thin air like this… and i can still run any ratio back up thru the “spot diameter” equation see what it spits out…
.011547344 = 1*(Fcol/100) scratch that… bigger number, to get a realistic collimator mm fogure…
.011547344 = 1*(Fcol/600) now we’re either totally lost? or were cooking with gas…
.011547344 = (Fcol/600) cos 1 times anything is anything…. multiply both by 600?
NOW i get Fcol = 6.9284064 = 6.3mm collimating lens
THATS more realistic…. to “find”… in asmall collimator…
i am NOT calling this solved? i’m saying this is a possibility….
just, let me feed this “600 ratio” back into the above equation? see what he spot diameter is… maybe it will be similar to the “optimum” one lens beam diameter was? i am either close or done? or completely lost…
spot diameter = DIAMsource * ( 6.9284064 / 600) source diameter always was 1mm…
spot diameter = 1mm * (.01157344)
spot diameter = .01157344
does that even make sense??? check it… look for it…
HEY!!!!!!! i got rthe SAME RADIANS!!!!!! witha totally different equation!!!!!!!!
i’m am NOT calling this solved? i am just calling this… best whack i ever took at it…
someone suffer thru this logic trainwreck see what i might have had abrain fart? or else… i am a golden god? (and i just cant be… i aint that smaert… there has to be a monumental logic *&%$ up… this is way above mypay grade…)
still… i got “something” working… sort of? pinch this off, before i hit a bad key and lose all this work…
With enough black coffee and cigarettes? all things are possible…
I am currently still shipping… REAL GENUINE CREE xp-g emitters, the classic… brace yourself? as low as 20 cents apiece!! Check out the SALES THREAD, everyone is happy… then PM me
SALES THREAD:
http://budgetlightforum.com/node/52528
if you are into reloading? this is my site… I inherited the remains of what was once arguably the best reloading site on the internet… its the “BLF” of reloading sites…
http://reloadbench.freeforums.net/
if you think night vision would be cool? It IS… this site i am a member of, and its basically the “BLF” of home made scratch-built digital night vision. They are at the leading forefront of advanced DIY for digital night vision, and thats gun mounted or handheld… builds rival and exceed commercial offerings…
http://nightvisionforumuk.com/
sedstar
if i even think thid might be a solution? backfeeeding mt ratio, in the spot diameter estimation? what the &^%$ is my answer supposed to be units wide? radians? see i was thinking millimeters…
nut… still… the WAY the equations are flipping around, and reciprocals of reciprocals back and forth? maybe the answer IS IN radians… i dont know…
and? i am about to come out of my “zone” and “lose it”… i need a bath… and sleep… butonly after i decide if i epic failed or walked on water…
i mean, these new equations? are “sort of” looking like the opposite equavelants back trhere….
anyone knoe if calling something a beam or a spot, indicated whether the anser is experessed in radians or millimaters?
all i know is, i am getting “realistic LOOKING” small collimatror lens figures out of this…
my brain is about to explode….
good night and god bless. i need a bath… and hey? atleast you guys got your answer… i just pray i got MINE.
(i wanna be able to define the collimator lens build, gawd dammit)
SALES THREAD:
sedstar
and? just in case i did walk on water? THESE collimator/focusing lens focal lengths? would be the puppies to look at ray traces… if i am even CLOSE to anything remotely resembling “right”? something might “pop out at you” on the ray traces.
keep in mind? you would want to use “these” focal length figures… and move them back and forth see if the rays started lining up cool, i guess? (i always assumed if things were working, you could just “see it” heppening in rays… i really dont know nothing though)
bed… bed.. bed…. i’ll find out tomorrow how close i got, maybe…
SALES THREAD:
sedstar
how in the *&^% do we even “check my work” ?
SALES THREAD:
luminarium iaculator
luminarium iaculator's picture
Last seen: 16 hours 29 min ago
Sedstar and Enderman,
Guys sometimes all maths and calculations means nothing without experiment. Lets build something out of available and known lenses scraps for cheap to get approximately close to something that we could call multi aspheric flashlight.
And just to mention old de domed XP-G2 S4 2B(R.I.P) was and remains the best throwing emitter and the most suitable emitter for fet driver setup.
Osram Oslon Flat could serve for smaller setup and it is fet driver friendly but it is XP-E2 size (so stick it on 70 + mm lenses and wow! Tiny laser Smile even with precoolimator ) but we have XP-E2 which after de doming should be same or better than that even at lower currents.
Djozz about Osram oslon flat black:
“Much encouraged by these results, I did a Brinyte B158 mod with this (very) led and a direct drive AK-47A+FET driver (ledboard glued to the pill with an as thin as I could make it layer of Arctic Alumina Adhesive to get the required electrical insulation between led-minus and pill) in the hope that it would crush the throw of the dedomed XP-G2 S4 2B led, but unfortunately it did not, I got ‘only’ 285kcd from the Oslon BLack Flat, with 322kcd for the S4 2B”
sedstar
luminarium?
technically speaking… equations are equations.
assuming the following…
1) the given stated equations i worked with were correct?
2) if no one can detect any “algebra errors” in my flight plan?
3) if i didnt make some huge logic error in setting up my final solution?
the work should be “checkable”.
i am a “lot more confortable” with the mathematical modeling of the single lens zoomie…
the “way” i went about my (possible) solution of the pre-collimation calculations? flipa coin, i figure i could be totally right, or, totally off base…
i cant check my own work? i’m “in love with it” i need peer review…
but…my gut says i am “probably right” on the single lens model…. and that i cant rise above “50 percent” on the collimation equations…
but, “either or both” if they would be right? are now repeatable, and if right, i could use to find stuff. and this is ll assuming i wasnt “given errors” woth anything wrong in the edmunds scientific paper.
but… those “precollimaor” fogures? look reasonable… which dont mean nothing, but still…
SALES THREAD:
sedstar
question?
what was that “height” that vinz claimed was the holy height for the precollimator? and what lens was the focusing lens? i mean rough focal length?
if i got close to THAT,a given working solution? that would be a slightly warm fuzzy feeling…
SALES THREAD:
Here: http://www.candlepowerforums.com/vb/showthread.php?365868-Dereelight-DBS-with-de-domed-XP-G2-and-pre-collimator-lens
Everything he wanted to reveal is in that thread(4 years ago). Main lenses are Dereelight DBS which are same as nightmaster(V1 V2andV3) and I really don’t know nothing about focal lenght.
He said around 0,7mm from emitter and it is… The higher you’ll go the larger projection and larger lux drop therefore you must hit the sweet spot.
Vinz is the best modder in a world.
Edit: Right one are main Dereelight 50mm lenses Vinz used in mentioned build:
sedstar
…and i have to entertain the NOTION that vinz would lead us all astray, on exactly “how”… this is his bread and butter, and his reputation as top dog on the line…
those pre collimation equations? they “compleyely” rely, one way or the other? on the RATIO, not on specific vales…. that much is obvious and evident form looking at them.
technically? a RATIO, has any possible (infinite) number of “solutions”… one you assume ONE, the other should be solveable?
thats the way i’m seeing it, though… giventhe forward focusing lens? you can calc the FL of the precollimator… and given the precollimator given? you can then calculate the new forward lens.
unless i am missing something. but if i am, i am not seeing it. (duh) why would i see it right now…lol
SALES THREAD:
sedstar
all right… my ego completely aside? I need this from you…
1) COMB thru my “work”. if i make any error in algebra? or in my trig “soh cah toa” descriptions? someone needs to POUNCE on me for it. if i dont stand to peer review? i dont have a CHANCE.
2) if no one can find an obvious “error? then theres a decent chance my math description of the single lens zoomie, best build might be an accurate model.
3) same thing in my “crazy man rantings” on the second set… if theres an algebra error? POUNCE on me. tiniest thing matters.
4) then, if anyone finds a “logic error”, i could have easily made a false logic assumption. if you think you see something? maybe you see something.
5) one major assumption i am making? is that all these equations? form a giant “tautology”, which of course i might be in huge error of that… the first set of equations, might not have anything to do with the second set, and i am making the giant intuitive/deductive step that they are.
6) on the initial one lens model? if the ray trace even remotely resembles anything in real life? then, we should be able to see SOMEthign in the ray traces… one lens should at least INDICATE something… and namely that “a bigger diameter lens wouldnt do more” if it reads like i think it does.
7) the second solution? flip a coin… at this point i cant know.
SALES THREAD:
Enderman
Enderman's picture
Last seen: 3 hours 47 sec ago
I’ve researched it, the XP-E2 curve starts dropping down much sooner than the flat black, at about 3A.
Everyone knows the old XP-G2 had the best intensity, but both djozz and saabluster tested a single flat black and it had higher intensity than the G2. Djozz probably got worse with the flat black due to not enough current due to the Vf. This is why I go with constant current controlled test results and not “in-flashlight” test results.
This is what saabluster had to say:
“Sample size of one in my tests.
Relative Beam intensity
2A
BF 1040
XPG2 942”
Nobody is talking about “lower currents” here, or inconsistent FET. The LED will be driven at the peak of it’s curve through constant current drivers. Since the black flat is not sold in sorted bins, I plan to purchase about 10 or more and bin them myself to find the optimal one. If Saabluster and DJozz got better intensity at the same current with a sample size of ONE led, I’m interested to see what a binned one can do.
Another plus is that the flat black doesn’t need to be dedomed, which will make testing all of them easier.
PS- when I do build this light, I will use coolaboratory liquid ultra, which is a liquid metal paste and performs much better than regular thermal pastes. The only thing that would beat it is soldering the MCPBC to the heatsink, which I would rather not do, ever Silly
sedstar
mannnnnn. i hope i didnt screw the pooch royal, lol…
SALES THREAD:
coolaboratory liquid ultra Question sounds interesting and now I got to order it… Smile
I did soldering of mcpcb to brass pill but I did not notice any significant improvement over silver paste neither I noticed significant difference between copper, aluminum and brass pills (well up to 5A setups I probably can’t see any difference… At higher currents that variables could matter)
But Osram is still to tiny imho i even consider de domed XP-E2 to tiny for my regular setups (last time I used them was in Jacobs A60 reflector light since it was more than fine for Jacob stock driver that draw 2,2A of current and for some small aspherical builds, still have some of them).
It would need some crazy precoolimator to make it usable on 70+ mm size aspherics.
tekwyzrd
tekwyzrd's picture
Last seen: 2 hours 51 min ago
Waiting for delivery of lenses from surplus shed. I think I have a couple of two lens combination that should work nicely. One uses the 100mm 135mm fl that I ordered from fasttech and the other a 73mm 148mm fl from ss.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
Good luck with lenses Thumbs Up
sedstar
tekwyzrd?
if you didnt follow the math i did in my long series of “work” posts? thats OKAY. But, at least listen to the implications… and what known evidence already exists, without going off half cocked… just a suggestion. I just dont want you spending a lot of money on “cool lenses” constantly, and maybe not getting the results you are expecting or looking for.
most of my lenses? i took things apart and salvaged them… over time, you get a lot that way, and doesnt cost you much…
i have been sitting on these “engineering paper” i posted about a while now (which no one yet, anywhere, has claimed to have read? i wish someone would just red them….sigh) anyways, most of my “Early talk” about 2 lenses?? is aimed at getting people to use the IDEA that 2 lenses can be combined to make a “compound lens” you can treat as a single new lens.
creating a new compound lens? is not BY ITSELF going to instantly give you any of the results you are looking for… knowing what you want to make, and having an idea how to go about it? are two different things.
now, nothing i did technically means anything YET, without any confirmation i didnt make any algebra or trig “mistakes”… but, until someone comes forward claiming anything? i can say this…
1) i am a lot more confident in the first set… the “modeling” of a single lens setup. at least for the first set? if “peer review” doesnt come along in a timely fashion? i am going to have to assume i am “alone” in this, and that its up to me to write another paper based on that, to “boil it down”… which will explain it as best i can, and allow anyone with high school “algebra”, and “trig” to understand what it says, and some “cookbook” problems to work thru, which will allow a lot of people to USE the information it gives you.
2) i spent a long time on another site? where we use lenses a lot? and no one would look at the engineering paper, i have had them a couple years now… all i get, is people saying “it makes my head hurt”. i just got sick and tired of waiting for “the right person” to answer the questions, and even though i personally feel i am “close but not best” at answering the call? it unfortunately seems that “so far? i am all you get”.
3) the engineers at edmunds optics? wrote that paper, to explain to people how to build better illumination systems… and in my opinion, so reduce “returns” on people buying things they think will do what they want and it doesnt.
4) i have been saying, for a long time? that there is some “misinformation” going around the flashlight zoomie world. That the information isnt “wrong” as much as its “misleading”, and that its giving people slightly askew ideas. Everyone keeps repeating that same information over and over again, like its “holy writ”… and its not. It pains me to say it? But, one of the favorite “catch phrases” needs to get a “make over”. Because it doesnt “jibe” with the engineers at edmunds optics. Blame them.
5) now? until you guys find a better more qualified person, to do my work, and to check it? you are stuck with me… and i cant wait to hand it off, but… until then? i can tell you this… i am NOT the worlds best math person. I only “had to” take a lot of math to “do my field” i used to be in. I honestly dont LIKE math, lol… its just a necessary evil to me. I was surrounded by other university students EXCELLING in better math classes than i could perform well in. Problem was? they cant explain it to someone else and help them… THATS what my “gift” at university was. I seemed to be one of the best at EXPLAINING what i “can do” to anyone else coming up and having trouble.
i cant run around the top levels of the math tree? but, any branch i am on, i can explain how to get where i am… thats what people at my university had a hard time understanding why i had to job i had in the mathematics lab? i clearly wasnt the best math student there, plenty others way better, why was i doing that job? simple… i was one of the best at EXPLAINING anything i understood to anyone else.
if my light bulb goes off? i can turn on the light bulbs around me, so we can all understand it and USE IT. this is what made me good at my software engineering job…
now that i went thru the first part of that paper? i can now begin to explain it all, what it means in practical terms for us… and the second part? making dual lens illuminators that “beat” single lenses (delta trace issues aside, lol) which we all know EXIST but we have trouble making them? i either understand them or understand them a lot better now… and i am in a position to describe them much better.
does anyone want this paper written in a new post? or, is this going to be like the last couple years, no one listens and ignores it all?
SALES THREAD:
tekwyzrd
tekwyzrd's picture
@sedstar I did read the document you linked and a bit more on the edmund site. Your post in the new thread is essentially what I was thinking. The order I placed was two lenses, selected based on that. I plan another order of three more.
JonFlippen
JonFlippen's picture
Last seen: 2 years 1 month ago
I think info from this forum I’ll use in my future scientific essay next week. Set of ray traces later with different focal lengths on each lens can be really very interesting to my groupmates.
Agro
Agro's picture
Last seen: 6 hours 10 min ago
Superb thread.
Too bad the experiments with lenses of different strengths were not done. I may do them at some point.
Also, the conclusion:
"Enderman" wrote:
-A single lens (first case) still has better collimation than two lenses, but only collects a fraction of the light.
is not really a fair one.
To make it fair, we shouldn’t compare one moderate lens vs. 2 moderate lenses but rather 1 moderate lens vs. 2 weak lenses. After seeing the traces I wouldn’t be surprised if it was possible to improve both intensity and output at the same time. At least with ideal lenses like the ones traced. Wink
Agro wrote:
Superb thread. Too bad the experiments with lenses of different strengths were not done. I may do them at some point. Also, the conclusion:
is not really a fair one. To make it fair, we shouldn’t compare one moderate lens vs. 2 moderate lenses but rather 1 moderate lens vs. 2 weak lenses. After seeing the traces I wouldn’t be surprised if it was possible to improve both intensity and output at the same time. At least with ideal lenses like the ones traced. Wink
I have precoolimator lenses + main lenses that improve lumen for about 100% but lux output remains the same.
So I will claim that 2 lenses could have same coolimation properties as a single lens but with big advantage of increasing lumen output or enlarging main beam projection.
tekwyzrd
tekwyzrd's picture
Still collecting components and materials but the project continues as the RPG-100.
