Manker MK41 2000 Lumen Cree XHP35 HI/HD Led 4 AA/14500 Popcan Flashlight is Releasing
19 posts / 0 new
Mankerlight
Mankerlight's picture
Last seen: 21 min 22 sec ago
Manker MK41 2000 Lumen Cree XHP35 HI/HD Led 4 AA/14500 Popcan Compact Thrower Flashlight is Releasing
Specifications:
1.Emitter: Cree XHP35 HI / HD (CW and NW for your choices)
2.Maximum output: 2000lumens for HD CW version (NW version output is about 20% less than CW)
3.Maximum beam intensity: 67500 CD (520 meters)
4.Working voltage: 2.5V-7.2V 10V-16.8V (Over discharge protection)
5.Driver: Most efficiency constant current circuit driver
6. Material: Aircraft-grade aluminum body
7. Surface treatment: Premium Type III hard-anodized anti-abrasive finish
8. Lens: Toughened ultra-clear glass lens with anti-reflective coating
9. Water proof: IPX8 (2 meters under water)
10. Impact resistance: 1.5 meters
11. Tail stand
Dimensions:
Length 105mm, Head Diameter 44mm
Weight 191g (Without battery)
Accessories: O-ring *1, Lanyard*1, User manual*1 Holster*1
Operation:
1.When the flashlight is off , one click ,access to moonlight mode (left part of the figure),
one click to circle: moonlight-Low-Medium-High. Long press for off.
2.When the flashlight is off, long press to access to the mode your last use as in left part of the figure (Memory function), one click for circle. Long press for off.
3.When the flashlight is off, double click access to Turbo, one click for circle. Long press for off.
4.When the flashlight is on, double click to switch between the two groups(left and right part of the figure)
5.Long press for off and still keep on pressing will get into dragon breath mode directly.
Side switch battery indicator:
1. Blue: More than 75% 2. Purple: 50% 3. Red: Less than 20%
Lock out:
One click-Double-Triple from any mode to lock out the flashlight.(Only the battery indicator works when lock out)
Engineering Mode(Choose output level for Moonlight mode): Quick click for 4 times from any mode to get access to engineering mode. One click to check different levels and long press to make your final choice.
Please visit http://www.mankerlight.com/manker-mk...00-flashlight/ for more details.
Tangra
Last seen: 42 min 16 sec ago
Nice looking flashlight.
I will orded one.
NW version, diode XHP 35 HD because I wll use it only with AA battery.
Mstevens113
Mstevens113's picture
Last seen: 52 min 33 sec ago
Like the look of this, HI version seems like a nice pocket thrower.
The Miller
The Miller's picture
Last seen: 8 sec ago
Looks nice
Love this format
So can’t wait to see some objective reviews!
djozz
djozz's picture
Last seen: 7 min 49 sec ago
I usually do not dig Manker’s designs but this one I find really attractive. I would like to see it next to the competitors to compare size: SD10, EA4, D40A, VG4 etc.
hIKARInoob
hIKARInoob's picture
Last seen: 7 hours 58 min ago
Nice one Manker; really dig the price as well! Can you please tell me the parasitic drain value? Thanks!
my9221
Last seen: 1 hour 51 min ago
Runtime on turbo mode only last 5 mins?
Mankerlight
last 5 mins and then step down.
khas
Last seen: 1 hour 48 min ago
Really nice looking flashlight, nice with the dual battery option, but I think the best part is the NW emitter option Thumbs Up
Enderman
Enderman's picture
Last seen: 3 hours 7 min ago
I love popcan/cylinder lights Smile
Hey, how are you? :)
Hardware
Hardware's picture
Last seen: 11 min 12 sec ago
A nice compact Pocket Thrower. I like it very much. Interesting is the option with 4x 14500 battery. Fits very well into my booty scheme and comes on the have-want list. Thank you for showing me.
zelee
zelee's picture
Last seen: 8 hours 5 min ago
maybe on my next payday Cash
Don’t mistake my kindness for weakness.
I am kind to everyone, but when someone is unkind to me, weak is not what you are going to remember about me.
mrheosuper
Last seen: 13 min 18 sec ago
4*14500, it really attracts me
Forgot my pen
Trevi_lux
Trevi_lux's picture
Last seen: 39 min 20 sec ago
I like the light and the power with 4xNiMH, Thumbs Up
about option 4×14500 not interested in use this configuration…. for use Li Ion I prefer other options like 26650, 1 or 2 ×18650, etc.
turboBB
Last seen: 9 hours 55 min ago
Here's an in-depth vid review of both the HI & HD; features both indoors & outdoors beamshot comparo's vs. other 4 x AA (albeit older gen) lights (Sunwayman D40A, ThruNite TN4A XP-L V6, Jetbeam SRA40) as well as Runtime on Turbo with various batteries:
Working on the written portion which should be up in a day or two.
EDIT: Apologies for the horrendous audio for majority of review, had incorrect setting on the camera... Sad
my9221
I may take the HD depends on the price!
Edit: Price a bit high than I expected!
turboBB
I measured standby drain as follows:
This is outstanding and is so trivial as to not merit concerns with leaving Eneloops (or equivalents) in the MK41 long term. While it’s still excellent for 14500’s, due to the substantially lower capacity, I’d exercise a little caution.
*leaves cell’s self-discharge out of the pic so anticipate slightly lower
Tangra
Can protected 14500 fit without problem?
hIKARInoob
Thanks a lot! Well, personally I consider a 1 year drain time with Eneloops only “acceptable” if I really like the light a lot. Unlike lithium ion, Eneloops do have a self discharge time of many years, which simply is not taken advantage of… I (personally) compare this light to the Thrunite TN4A, which has a self discharge time of 35 years (65 uA)! I do wonder now what the parasitic drain on the bigger MK35 is… Perhaps you can be so kind to measure this as well?
To me, parasitic drain is perhaps a more important aspect of a light than UI.
