Can anyone identify this??
10 posts / 0 new
teacher
teacher's picture
Last seen: 31 min 56 sec ago
This may not be the correct place to post this, but I figured if anyone could tell me what this was it would be one of you guys.
It came with a solder station and I have no idea what it is. Pictures below of un-assembled and assembled.
US Quarter is for size reference. Black handle is made of plastic, U shaped wire thing & screw are metal.
Thank’s in advance……… Smile
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
Man Without Shadow
Man Without Shadow's picture
Last seen: 13 min 39 sec ago
It’s an IC POPPER.
It’s called an IC popper and is used to remove surface mount components from a circuit board. You slide the metal wire under the component, melt the solder, and gently lift the IC off the board.
When I'm spending money foolishly, I like to do it wisely...
I have all the flashlights I need, but not as many as I want...
teacher
teacher's picture
Thank you, for the info & picture! I was totally at a loss. Wink
jf_smm
Last seen: 3 hours 26 min ago
ManWithoutShadow wrote:
It’s an IC POPPER.
!http://farm2.static.flickr.com/1256/857276352_850154f496.jpg!
+1
3 posts and contributing already Smile
NeutralFan
NeutralFan's picture
Last seen: 2 min 46 sec ago
jf_smm wrote:
+1
I would expect nothing less from a fellow Wisconsinite!
I’d rather use my flashlight around the house than turn on the lights.
allcool
Last seen: 5 hours 13 min ago
Had no clue what that was. I’ve got a couple of them too. sure could of used that little suker a few times… lol
Thanks for that question, teacher…
And thanks for the answer MWS Thumbs Up
Smart little tool,,, so you’d put prong(s) under the chip and just using its handles weight, like its sitting in the pic, thus keeping easy light pressure on the chip so it pops off when it reaches temp..?
teacher
teacher's picture
Your welcome ‘allcool’. I am just glad to finally find out what it is…. Wink
james y
Last seen: 1 day 18 hours ago
I see the potential of using this tool to spear the dome of LEDs and lift them up…..
teacher
teacher's picture
Let us know how that works out for you. Wink
Angler
Angler's picture
Last seen: 11 hours 22 min ago
This looks like something people make in prison called a socket popper.
You stick it in an electrical outlet and then light a cigarette off of it.
Big SmileFacepalmLOL
