making a small batch of Texas Avenger "TA" Drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
249 posts / 0 new
Lexel
Lexel's picture
Last seen: 3 days 21 hours ago
so finally reflowed all those 200 AMCs and some MCU sides of 17/20/22mm
in the picture on the left side drivers that are ready to be programmed and tested,
already passed visual check, with some that needed some parts aligned right, remove solder blob shorts between pads
on the right side drivers with AMCs missing as I expect 100 from the last order I added after I got more MCUs and fets to build some extra drivers
I did learning by doing for reflowing drivers
I learned how to apply a tiny but sufficient amount of solder paste with some tricks
just see one of the first vs the last, optical far better, but electrical identical
so we got for programming
1 15mm Narsil
4 17mm Narsil
9 17mm Bistro
1 20mm Bistro
1 20mm Narsil
1 21mm Bistro
3 21mm Narsil
1 22mm Bistro
1 22mm Narsil
12 30mm 2S LDO Narsil
4 30mm 1S Narsil
3 38.5 1S Narsil
Texas_Ace
Texas_Ace's picture
Last seen: 19 hours 48 min ago
At this rate you will surpass myself in the most TA drivers built lol.
The latest drivers do look much better, you don’t need much paste at all. This is why the stencils are so nice, they give you the perfect amount and put it in the perfect spot every time and in a a couple of seconds too boot!
A tip for better reflowing is to reflow the top side components first and heat the pcb from the bottom with about ~350-380c air. First off this lets you use much higher air speeds without blowing components off and it also ensures the best possible connection.
The 7135 side just do like normal from the top of the components. They are much easier to deal with like this.
Lexel
Lexel's picture
Added indicator resistors to all Narsil drivers
Wiring like in this picture
Lexel
Lexel's picture
first driver flashed and under testing and temp calibration
MRsDNF
MRsDNF's picture
Last seen: 1 day 12 hours ago
With lots of happy on lookers. Smile
Lexel
Lexel's picture
first 8 Narsil driver cleaned from flux, electrical check
test and temperature calibration
KawiBoy1428
KawiBoy1428's picture
Last seen: 12 hours 2 min ago
Wooo Hoooo! Beer
KB1428 “Live Life WOT
Etex
Etex's picture
Last seen: 2 years 4 months ago
Thumbs Up Wink
Lexel
Lexel's picture
Input
100 AMC7135
3 17mm boards
Output first orders complete to get shipped
Lexel
Lexel's picture
this is now the 3. board witch such an issue
not enough solder mask paint, and I get ground short from back of one AMC7135
costed me 1.5 hours so far
board looks messy when you unsolder those AMCs too often
Texas_Ace
Texas_Ace's picture
Those shorts are almost always a result of too much solder paste. This is why I recommended the stincles. They make it much easier to get the right amount but not too much.
This is a case where less is more.
The mask looks good, the solder looks to have been pushed up from the FET having too much paste.
Generally if you replace the 7135 and reflow it back on it will work fine as that removed a little bit of solder paste when you do that.
JasonWW
JasonWW's picture
Last seen: 13 hours 30 min ago
Lexel, can you explain what “tactical” means on your spread sheet?
Also, on the drivers with resistors added for LEDs, can you explain the difference between indicator LED and lighted side switch LED?
Thanks
I still haven’t decided which version of Narsil to go with.
Lexel
Lexel's picture
tactical means if you got a tailswitch the light always get in turbo as you turn the power on
there are 3 settings atm for start up, 2 blinks with low mode, turbo and no light
indicator LED blinks out what you configured it in UI settings
lighted sideswitch just lights the switch as soon as you connect the battery with tailswitch, but it has parasitic drain and can overdischarge batteries
electricjelly
electricjelly's picture
Last seen: 5 days 1 hour ago
Sorry for the setbacks. I hope you’re having some fun putting these together. I can tell your very organized. I’m sure that has helped make it much less frustrating.
I’m looking forward to having four more lights unified, all running Narsil.
I appreciate the work You, Texas_Ace, TomE and others have done to make these possible. Beer
JasonWW
JasonWW's picture
Okay, mine doesn’t say tactical on the spreadsheet, but it should.
Also, I only need the lighted side switch, so I think Narsil v1.2 is what I should go with. That way I also have the low votage protection.
Thanks
Lexel
Lexel's picture
Thanks
v1.2 has no temperature protection, so if thats Ok for you
Tom E is too busy to make LVP / indicator switch into Narsil triple v1.5
JasonWW
JasonWW's picture
Yes, that’s fine by me. My hand is the temperature protection. Lol
Plus, I’ve recently switched to unprotected Liitokalas for more output so the LVP is more important to me even though I’ll have the lighted side switch to tell me if the rear switch is on or off.
staticx57
Last seen: 5 hours 7 min ago
These do look great. Thank you for making these for the community.
Lexel
Lexel's picture
mattlward
vinte77
statix57
Kawiboy
Etex
MrJohnny
sent today
Lexel
Lexel's picture
reflowed now all boards
tomorrow doing a lot programming and testing
last chance to check if your divers are set up as you wish
when you did not specify any temperature limit it will be set to 60°C
Lexel
Lexel's picture
all drivers are now flashed configured and tested
did pack em as well
last chance to check the Excel sheet if everything is right
tekwyzrd
tekwyzrd's picture
Last seen: 7 hours 59 min ago
Thumbs Up Excellent!
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
electricjelly
Thanks for all your hard work. I’m looking forward to receiving them and building me some awesome lights. Thumbs Up
Sukoi
Last seen: 3 months 4 weeks ago
+1 Beer
Tom E
Tom E's picture
Last seen: 4 hours 3 min ago
I posted this in TA's driver thread as well:
So made some  progress on merging Narsil 2 channel and 3 channel, so I have one source code base now with a header file called setups.h. In setups.h, you define all the board configuration settings and other compile time user option settings.
It's compiling now for 2 channel and 3 channel, with indicator LED enabled or disabled, and using R1/R2 or internal V1.1 ref for voltage monitoring.
Totally untested, but it compiles. smile
Next to do is actually try it...
Some Details:
It has the more advanced, simplified version of the configuration settings UI that's in the 2 channel latest version of Narsil, v1.3. One new feature is ability to set the temperature threshold for thermal stepdown. There's probably a couple more tweaks as well in LVP and thermal stepdown, results from more recent testing.
Testing will take some time - may need to actually build up a couple boards, etc.
Slayer1
Slayer1's picture
Last seen: 17 hours 51 min ago
Thank you Lexel. You have been epic!! Thumbs Up
-X3-
-X3-'s picture
Last seen: 6 days 12 hours ago
Thank you Lexel once again, your work is truly appreciated !
Can I add a Locator LED if I want to ? Thanks !
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Lexel
Lexel's picture
X3 wrote:
Thank you Lexel once again, your work is truly appreciated ! Can I add a Locator LED if I want to ? Thanks !
locator LED with resistor can be simply added to the bleeder resistor pads
Tom E
Tom E's picture
Just little more Narsil update news -
  • no further progress yet - project juggling cry
  • looks like the new BLF GT buck driver that's in the design/proto phase will be a perfect fit for this combined Narsil version - I'm calling it NarsilM for now: Multi-channel configuration
  • the GT buck driver will just be another channel configuration, but with some special needs. Two I/O PWM pins, but slightly different behavior
  • I'm a big fan of the TA triple drivers, so I want/need to get this done!! (as I hit myself over the head...) smile
Texas_Ace
Texas_Ace's picture
You will need to add a resistor inline with the LED in this case or it will drain the battery very quickly. A normal through hole resistor could be used easy enough. Something around 30k-50k ohms generally works out ok.
