making a small batch of Texas Avenger "TA" Drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
249 posts / 0 new
Tom E
Tom E's picture
Last seen: 19 hours 38 min ago
Are you guys talk'n bout a tail bleeder LED (Bistro - clicky) or locator LED w/Narsil? For Narsil I use somewhere between 2K and 15K, depends on the LED(s) and visibility of the LED.
Texas_Ace
Texas_Ace's picture
Last seen: 4 hours 19 min ago
Well, it sounds like he is talking about installing an indicator LED using the tailcap bleeder pads.
So it would remain on 24/7 and drain the battery continually. 50k ohm resistor tends to have the final output be around ~0.050ma from my testing, so a little over 1ma per day of drain.
-X3-
-X3-'s picture
Last seen: 3 days 19 hours ago
I want to use the Narsil option to activate/desactivate the locator LED, not simply use a bleeder resistor + LED Smile
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Texas_Ace
Texas_Ace's picture
This makes more sense and it also means you don’t need a resistor, or at least as big of one. But in this case you can’t use the bleeder resistor pads. I am not sure what pads you need to use but I think the voltage divider pads. Never used an indicator LED with narsil before myself.
Tom E
Tom E's picture
Ooops, removed this post. Lexel is using an older version of NarsilTriple, so not sure about the Indicator LED support.
solRNY
Last seen: 17 hours 26 min ago
What would you recommend for a broken thorfire s70s driver?
Texas_Ace
Texas_Ace's picture
The TA30 was designed for the L6 and S70. I love it in my L6 although it can get really hot if you run it on turbo.
JasonWW
JasonWW's picture
Last seen: 2 hours 7 min ago
Tom E wrote:
Are you guys talk’n bout a tail bleeder LED (Bistro – clicky) or locator LED w/Narsil? For Narsil I use somewhere between 2K and 15K, depends on the LED and visibility of the LED.
I’m not sure what aplication X3 is using.
I was talking about a side switch led for the L6, not tail switch.
I don’t know much about the “indicator” or “locator” led. My plan was simply to have the side switch light up whenever the tail switch was turned on.
When not using the light I will click the tail switch off which cuts all power.
I want LVP, so I got Lexel to install Narsil v1.2.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
JasonWW
JasonWW's picture
BTW, I have a 1.45 milliamp drain on one of my drivers. Is that considered high? It has had zero effect on battery life so it doesn’t seem to be a big deal.
Tom E
Tom E's picture
JasonWW wrote:
BTW, I have a 1.45 milliamp drain on one of my drivers. Is that considered high? It has had zero effect on battery life so it doesn't seem to be a big deal.
Narsil is wayyyy lower, after you wait 10 secs or so from turn OFF. Did you wait long enough? In the newer versions it's reduced to 5 seconds or so.
It should be 0.021 mA without R1/R2. If you are using R1/R2, depends on what values you use. I typically use 192K and 47K - 10X less drain for the old resistor values, so resulting drain is 0.038 mA.
1.45 mA is like 38X greater.
JasonWW
JasonWW's picture
Tom E wrote:
Narsil is wayyyy lower, after you wait 10 secs or so from turn OFF. Did you wait long enough? In the newer versions it’s reduced to 5 seconds or so.
It should be 0.021 mA without R1/R2. If you are using R1/R2, depends on what values you use. I typically use 192K and 47K – 10X less drain for the old resistor values, so resulting drain is 0.038 mA.
I was asking about an FX-30 driver I’m using.
Also, what kind of drain do you get from a zener modded driver?
Lexel
Lexel's picture
Last seen: 19 hours 42 min ago
the locator LED/sideswitch LED can be used with tailswitch lights without a problem, that was its main purpose
for lights with no tailswitch a locator LED should have a pretty high resistor, like Texas_Ace wrote to get low parasitic drain, you can still get brighter that trits with parasitic drain af a few 100uA
khas
Last seen: 4 days 27 min ago
My drivers arrived today, they look very nice.
Thank you for doing this, can’t wait to put them in to use.
EDIT : Just finished putting one of the drivers in a Skilhunt H02, re-flowed the original emitter to a Noctigon MCPCB, the UI is great with lots of options and the ramping is fast and smooth.
It get very hot very fast Big Smile
-X3-
-X3-'s picture
My driver arrived today, and is already in his pretty host : Nitecore HC30
What a wonderful UI ! I love the ramping, really intuitive, and fast at the same time !
Thank you very much once again Lexel !
Etex
Etex's picture
Last seen: 1 year 9 months ago
Received mine today, as well, that was quicker than expected, thanks.
lampyris
lampyris's picture
Last seen: 1 year 6 months ago
Thank you Lexel, received the drivers Tuesday!
Excellent work Smile
Etex
Etex's picture
Got mine installed & working. Convoy L6, inspite of discovering my led is in backwards (reverse polarity).
Still trying to figure out how to get ramping to continue in the same direction. It seems to want to change directions.
Edit: nevermind about ramp direction, got it now.
Also, can I switch it from initially coming on at turbo with rear clicky, to the 2 blinks?
Thanks
Etex
Etex's picture
Is this normal?
!{width:50%}20170504_172255!
JasonWW
JasonWW's picture
Maybe it’s on a moon setting?
How do you turn the light off with the side switch, press and hold?
Etex
Etex's picture
The illumination is way lower than moon or firefly. If it’s normal, it’s not a bad way for me to tell if I have turned tailswitch off, since I don’t have illum switches.
Side switch functions:
Press and hold = ramping(up or dn)
Quick press = on / off (with memory)
Double click = turbo
Etex
Etex's picture
Here’s how mine works… your results might vary.
Convoy L6
TA Driver Infineon LDO Tactical 65° with Narsil V1.2 ?
From off…
-1/2 press of rear tail switch = momentary on (in Turbo) for signaling or instant glimpses.
From off…
-Full click on rear tail switch turns on to Turbo.
Side switch then controls:
>-Click = On / Off (with memory).
>-Double click = Turbo.
>-Click and hold = Ramping up or dn.
>-Long pause (1.5+ seconds) between Click & Holds continues ramping in the same direction.
>-Short pause between Click & Holds reverses ramping direction.
>-Short side switch click , turns off at any point in ramping and saves that level in memory, for when side switch turns it back on.
>-Tail click to off, or lockout, erases brightness level memory.
How do I program tail switch modes?…
A) Turbo (default)
B) 2 blinks
C) Nothing until side switch is pressed.
JasonWW
JasonWW's picture
Etex wrote:
Convoy L6
A) Turbo (default)
B) 2 blinks
v1.2 has low voltage protection, but no temp control. If you do have temp control, then you have v1.4 and no lvp.
I understood it that tail switch modes had to be programmed into the firmware. They are not user adjusted. Lexel told me it was a few lines of code that had to be altered to get the tactical setting.
Etex
Etex's picture
I specified temperature control, and they were marked as such, so I guess it is V1.4.
I misunderstood those tail switch options as being user defined. Turbo is the only way to have a momentary function, so its not bad in that respect. And a quick click of the side switch turns it off.
Looking across my acreage, I can quick scan a lot of ground in momentary mode in a second or two with it.
The ramping is awesome, and a lot more user friendly to fine tune the levels than I expected.
The faint LED could be an Infineon vs SIR800 difference, guess we’ll see.
Etex
Etex's picture
Lexel wrote:
I tested the drivers with a Nichia 219 triple so on LDO drivers I did not drive the driver and LEDs with 2S voltage
My guess on that glow is a faulty 7135 that causes a very low leak current
Thanks
Texas_Ace
Texas_Ace's picture
Thanks
I agree with this assessment. I have had this happen to me as well with 7135’s on 2S drivers.
Lexel
Lexel's picture
http://budgetlightforum.com/node/54053#comment-1121216
new batch is almost ready to go I said I start ordering stuff when 30 drivers are requested and will order parts for 50
JasonWW
JasonWW's picture
Thanks
There’s only one 7135 on there so it looks pretty easy to swap out. Maybe you have an old driver you don’t need that you can strip a 7135 off of. If not, MTN Electronics sells them super cheap.
Etex
Etex's picture
I actually have a stip of 7135’s, just have to get some more practice in before attempting. I think dealing with these itty bitty parts is how I messed up my original driver (resistor mod), total noob, and not steady 63 yr old hands. BTW, there’s 8 7135 on one side and the single on the other….???
JasonWW
JasonWW's picture
Oh yeah, post #102 shows the backside. So 9 in total. I wish I knew how to narrow it down to find the faulty one.
Removing all of them and cleaning the pads is not too hard, but soldering new ones would be a pain by hand. You’d need a hot air reflow station and solder paste to do it quick and easy.
Its some pretty bad luck. If you really want to fix it, maybe ask Richard at MTN if he could do it.
I hope it’s a rare occurrence.
tekwyzrd
tekwyzrd's picture
Last seen: 3 hours 15 min ago
Package delivered today. I’ll force myself to wait for the solder station I ordered that’s scheduled for delivery wednesday before starting on the lvp mods for the 2s light but will install one as-is in the D01. I’ve been searching for another grey D01 but the major sources are out of stock so it will remain 1s3p until I find another, make a 2s battery tube, or cut and extend the 1s tube.
Nothing travels faster than the speed of light with the possible exception of bad news, which obeys its own special laws. – Douglas Adams
