Battery ?
296 posts / 0 new
Venom
Venom's picture
Last seen: 19 hours 52 min ago
teacher wrote:
Venom wrote:
@teacher Is a year after the manufacture date for a Eneloop someting/nothing?
If you have a 4 bay charger do you set it at 2 amp so you can get .50 in each bay? What does 1000ma mean? In post 116 you said 1C threshold what does that mean? Smile
@ Venom …. What Pete said above. Smile
You been slacking on your homework?? Wink We covered C-rate back in post #6…
http://batteryuniversity.com/learn/article/battery_definitions
Big Smile
I read it, I just don’t remember it. There is alot of reading in all of those links you posted. My brain was full and started emptying things out. Big Smile
teacher
teacher's picture
Last seen: 1 hour 57 min ago
@ Venom … I understand. Wink .. I was just messing with ya’. Big Smile
      You never know how a horse will pull until you hook him up to a heavy load. / Paul "Bear" Bryant ~/~\~ "Slow is Smooth, Smooth is Fast"
       Texas Lumens Flashlights  <>   M4D M4X Deals : sign up - save $$$$    ||||
         Rudeness Level /\ mΩ /\ {width:70%} /\ LightWiki /\ LED Tint Chart /\ LED Tint Picture /\ Xlamp size chart /\ BatteryU                   Flashaholic? Need Professional Help???   wink   /\ TheOriginal /\ TAB /\ LightSearch /\ BatterySearch /\ 14500's /\ DiCal
Venom
Venom's picture
I know! All fun and games. j/k
With cc17 charger can you charge 2 AA and 2 AAA at the same time or do you have to charge all AAA/ AA at the same time? Can you recharge them anywhere in the house like kitchen or do you have to go somewhere more suited? Do you have to keep putting your hand on them while charging to check for heat? My guess they should stay cooler than my Milwaukee M18 battery pack. When the Eneloop come freshly off the charger are they 1.2v or are they higher? I read online people are taking them off the charger at 1.4/1.5v, not sure what are the max charging volts to be safe.
On the battery it says AA BK-3MCCA 1900 Mah HR6 and AAA BK-4MCCA 750Mah HR03. I can’t read the imprint on the battery. My sister read the date 16 04 but not sure if it right
teacher
teacher's picture
@Venom ………….. Just put the batteries in, plug the charger in (indoors preferrably), and it does the rest. When that charger quits charging they are done.
Copy of a CC17 Manual below.
Oh yeah, when they are fully charged they will be above 1.2V
Thank you for purchasing the Panasonic BQ-CC17 Charger
This manual contains important safety and operating instructions for the Panasonic
BQ-CC17 Battery Charger.
Before using, please read all of the instructions and warnings on (1) the battery
charger; (2) the batteries; and (3) the product using the batteries.
1. To reduce the risk of injury, we recommend that
Panasonic Ni-MH rechargeable batteries are used.
2. Do not use non rechargeable batteries.
3. Do not use the charger in humid conditions.
4. Do not use the charger if it has a damaged plug.
5. Do not use the charger after it has been dropped or damaged.
6. Do not open/disassemble the charger.
7. Unplug the charger before maintenance or cleaning.
8. Do not use the charger in direct sunlight.
This appliance can be used by children aged from 8
years and above and persons with reduced physical,
sensory or mental capabilities or lack of experience
and knowledge if they have been given supervision
or instruction concerning use of the appliance in a
safe way and understand the hazards involved.
Children should not play with the appliance.
Cleaning and user maintenance should not be made
by children without supervision.
OPERATING INSTRUCTIONS
In this charger 4 AA and/or 4 AAA batteries can be charged in several combinations
(see fig. 4)
1) Observe polarity by matching () and () on the batteries to () and () on the
charger.
For AA battery, insert from the (+) terminal and push on the (-) terminal. (fig 2)
For AAA battery, insert from (-) terminal, then place () terminal into () contact
place. (fig 3)
2) Plug charger into standard 100–240 V AC outlet;
3) Charging indicator light will be lit after blinking fast several times, indicating that
charging is being conducted. If indicator light does not come on:
4) a) Make sure batteries are inserted, making proper contact with terminals in
each slot;
4 ) b) Make sure charger is plugged into a working AC outlet.
4) After charging fully the charging indicator light will turn off. The charger should
then be unplugged from the AC outlet and the batteries removed.
The auto-off feature will automatically shut off the charger when the batteries are
completely charged.
Charging times shown in Table 1 are only indicative and can vary depending on
temperature and battery status.
MAINTENANCE, CARE AND CLEANING
●Care and cleaning is essential.
●Unplug charger from AC outlet.
●If necessary clean with a dry cloth to remove dirt and grime.
●Never immerse the charger in water or in any other liquid.
Table 1
Battery
Size Capacity Charging time
1-4 pcs
AA
2400 – 2500 mAh 9.0 hour
1900 – 2000 mAh 7.0 hour
950 – 1000 mAh 3.5 hour
AAA
900 – 950 mAh 7.0 hour
750 – 800 mAh 6.0 hour
550 – 650 mAh 5.0 hour
SPECIFICATIONS
Model : BQ-CC17
Input : AC 100–240 V / 50–60 Hz 0.2 A
Output : DC 1.5 V —- 300 mA x 4 (AA size)
DC 1.5 V —- 150 mA x 4 (AAA size)
Operating temperature : 0~35℃ (Indoor use only)
Warranty: The warranty starts from the moment of purchase.
PECE will repair or replace with equivalent charger in case of justified
complaint.
The warranty is for the charger only.
The warranty is only related to defects in materials and workmanship.
Details can be obtained at Panasonic Energy Europe N.V. or at
www.panasonic-batteries.com
Venom
Venom's picture
@ teacher The battery info I posted in post 125, are they the Eneloop you said to purchase?
teacher
teacher's picture
As long as they are Eneloops and made in Japan your good to go as far as I can tell. Thumbs Up
That is the same Pack you had been talking about getting isn’t it??
If you go HERE & RIGHT HERE you can learn all you’ll ever want to know about Eneloops. Smile
Venom
Venom's picture
Yes it’s the same pack I been talking about.
The first link I found it doing a Google search after I last posted. The second link I think it has some good info on Eneloops and it answer some of the question I had. One answer I couldn’t find if you can charge 2 AA and 2AAA at the same time in the cc17.
I think the next thing I’m going to get is Xtar SV2 first (easier to get) then Lii500 and more Eneloop. Can you test the accuracy of a DMM with the SV2 or do you need the Lii500? Do you know what’s a good battery storage case/container that keep the batteries seperated?
teacher
teacher's picture
  • OK… same pack.
  • Questions about AA & AAA charging are on Page 1 of your instructions. … Fig. 4 ….. look it up to remember it. Wink
  • Not sure about the SV2.
  • All kinds of good storage options. Do a search…. if you can’t find something suitable let us know. Smile
Venom
Venom's picture
  • OK… same pack.
For storage I was looking at ammo boxes but the AAA Eneloop will fit in the slots but when upside down there all over the place. What are some of your idea/opinion on storage box.
Speed4goal
Last seen: 2 weeks 4 days ago
You put them in plastic battery storage cases then in the ammo can
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
teacher
teacher's picture
Venom
Venom's picture
@ teacher Is there any reason why the Lii 500 isn’t sold here? I found one place and they want $80 for it.
teacher
teacher's picture
Beats me my friend. ??
Order it from where I suggested. If you had done that instead of second guessing yourself…. you would already have it. Smile
Pete7874
Pete7874's picture
Last seen: 4 hours 48 min ago
Gearbest has it in their US warehouse sometimes. That’s how I bought mine.
teacher
teacher's picture
I forgot about the US GB Warehouse…. they never seem to have it when I want it. Smile
@ Venom …. Click on link in my sig line that says M4D M4X DEALS, get signed up& do as he asks….. keep it private. Get codes for good deals. Wink
Venom
Venom's picture
The place where I found it was on Amazon and after I read it again it’s for EU plug.
I was going to ask about Gearbest in the U.S. if it was the same company. I once order a packagr from outside the U.S. and they said it got delivered and it never did so I got beat on that deal so when it comes to ordering outside the U.S. I sometimes have second thought on it.
Do you know the website for Gearbest U.S.?
Pete7874
Pete7874's picture
Gearbest only has one website, but they have multiple warehouses. If a product is available at their US warehouse, it’ll show you that on each product page when you click on the Shipping Cost / shipping options link. They only offer a limited number of some of the most popular items in that warehouse.
teacher
teacher's picture
@ Venom …… Hey man…… Please PM me your name, with shipping address & DO NOT order a Lii 500. Smile
Venom
Venom's picture
PM sent
Mr.Scott
Very nice teacher! Thumbs Up
teacher
teacher's picture
Venom wrote:
PM sent
PM received & reply sent. Thumbs Up
Thanks, just attempting to “Pay It Forward”. Wink
teacher
teacher's picture
teacher wrote:
Venom wrote:
@ teacher, Is the Innova 3320 accurate? Do you have to calibrate it? How do you calibrate a any DMM?
1. Yep the Innove 3320 seems fairly accurate.
2. You have to calibrate it only if it needs it.
This question was asked the other day about the accuracy of the Innova 3320 DMM.
Well I though some of you might find the following interesting.
A BLF friend from the United Kingdom sent me a brand spanking new VC99 DMM and a VRM (Voltage Reference Module). So I decided to test it all out as well as the accuracy of my Innova 3320.
The VRM is programmable to test for 10.0V, 7.5V, 5.0V, & 2.5V… DC of course.
Now please remember, while the VC99 & VRM were brand new; the INNOVA is at least 5 or 6 years old, probably a lot more… and has been riding around in my truck or car for most of those years in a plastic container I got at Walmart. Thru heat of summer and cold of winter too……. in other words it has not had an easy lift. Smile
I’ll just let the pictures speak for themselves…. no adjustments were made to either meter. It was not necessary.
Innova 3320
VC99
Pete7874
Pete7874's picture
Wow, that’s impressive.
I have an Etekcity/Uni-T one, and it reads a little low, but nothing major.
teacher
teacher's picture
Yeah, I was pretty impressed myself. I figured the VC99 would be right on the money since it was new… and it was.
I had no Idea the Innova 3320 would be too though, after the treatment it has received… but it was.
And now all my other “cheapos” are right on the money too after I calibrated them. Thumbs Up
The VRM (Voltage Reference Module) is not expensive at all either…. BUT, well worth it’s money for sure.
They are all over ebay. I think mine was around $5. Smile
Pete7874
Pete7874's picture
Yeah, I’ve got a couple of different voltage reference boards around. Unfortunately, there is no easy way to calibrate my DMM. I can only tell that it’s off a bit.
teacher
teacher's picture
That’s to bad. I was lucky, even my cheapos had a way to calibrate them.
I had to re-calibrate one 3320 (I seem to have collected three of them thru the years…. Facepalm ) that I had apparently “un-calibrated” a few months ago to a source I though at the time was accurate. Facepalm
Oh well, live and learn. Glad my buddy sent me this VRM though……. Smile
Pete7874
Pete7874's picture
Is the innova 3320 easy to recalibrate?
teacher
teacher's picture
Yes, very easy. Loosen 2 screws, remove the back, turn it on, hook up the leads, get your little screw driver and turn the “adjuster thing” very slowly till it reads correct.
I then turn it off & on again, recheck, & if all is still good. … put it back together.
That’s it. Smile
EDIT:“adjuster thing” = potentiometer
Wink
Venom
Venom's picture
Was it the Uni-t ut61e?
Venom
Venom's picture
@ teacher It’s good to know how accurate the Innova is and how its been holding up all these years. Its seems like a reliable DMM.
