Bistro firmware question
7 posts / 0 new
Smittymojo
Last seen: 2 days 13 hours ago
Hello all,
I’ve got an Eagle Eye X6 with the FET + 7135 driver and the Bistro firmware. I’m having trouble activating the mode memory feature. All other configuration options seem to be working correctly,
Sometimes it will go to the next higher mode or it might even start in a lower mode the next time I turn the light on.
How long should I have to leave the light off before the mode memory will be activated?
Any ideas what’s going on with this.
Thanks
DB Custom
DB Custom's picture
Last seen: 4 hours 28 min ago
Sounds like it may be an issue with the Off Time Cap or the bleeder resistor for the lighted tail cap
ToyKeeper will most likely know, or pilotdog68.
Too drugged for a pinched nerve in my shoulder to remember things clearly, but that bleeder resistor seems to be flagging my memory…
Dale
vresto
vresto's picture
Last seen: 6 min 36 sec ago
i want to ask-bistro driver i can program from 7 modes to four by the 15 tap tap method?thanks
EDC-Convoy S2+ xml2 red/blue bistro driver,Romisen RC-T5
Headlamp-Imalent HR20 nw
keengeorge
Last seen: 6 hours 32 min ago
What you want is here:
    ~toykeeper/flashlight-firmware/blf-x6v2: Contents of ToyKeeper/bistro/bistro.txt @Latest Revision ie:208 (ToyKeeper) (Rev 206 used by Manker for BLF X6/X5)
     http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/blf-x6v2/view/head:/ToyKeeper/bistro/bistro.txt
Best Regards,
George
vresto
vresto's picture
ok.i did 15 times of tap tap…i want 4 modes group.low mid hi turbo…
when it starts to blinking and strobo…what to do? iam waiting for 4 times blinking,which should mean,iam in 4 modes group….how to fix it please?iam mad of it….
g_sintornillos
g_sintornillos's picture
Last seen: 8 hours 7 min ago
vresto wrote:
ok.i did 15 times of tap tap…i want 4 modes group.low mid hi turbo… when it starts to blinking and strobo…what to do? iam waiting for 4 times blinking,which should mean,iam in 4 modes group….how to fix it please?iam mad of it….
If you want 4 modes without moon you should select 5 modes group and turn off moon
1.- To enter to config mode: tap tap until light not respond
2.- To enter to change mode group: wait until the 5th group of blinks (5 blinks), then, during the buzz, tap
3.- To select the group: wait until the 5th group of blinks (5 blinks), then, during the buzz, tap
Quote:
The config mode has several options. It will blink out a number to show which option is active, then “buzz” or “stutter” for a bit.
Click during the “buzz” to select that option. Some options may enter a secondary config mode after the light turns back on.
Options include:
5. Mode group. Choice of 1 to 8 regular modes from low to turbo.
After clicking, the light should come on in a special group-select mode. In this mode, it slowly blinks 8 times, pauses, then repeats. Turn the light off after N blinks to select mode group N. The number of levels in each group is equal to the group number, and all levels within are evenly-spaced.
Example: To select low-med-high, let it blink three times then click the button.
On the production X6v2 / X5 lights, the mode groups should have approximately the following output:
  1. 1400 lm
  2. 5, 1400
  3. 5, 293, 1400
  4. 5, 135, 543, 1400
  5. 5, 79, 293, 688, 1400
4.- To turn off moon: you should enter to config mode again, then wait until the 3rd group, then, during the buzz, tap
Now your light have 4 modes without moon: low, med, high, turbo and hidden modes as BLF A6
Sorry for my bad English (gogole translator)
STREAMHAWAII
Last seen: 5 hours 12 min ago
Does this Bistro firmware have “.5 or 1 lumen moonlight”?
