Bicycle Mount for ZL SC62w ????
Can anybody recommend as per the title …. I’ve one of these
https://www.amazon.co.uk/MyArmor-Universal-Bicycle-Handlebar-Flashlight/dp/B01F2Z79QU/ref=pd_sim_201_7?\_encoding=UTF8&psc=1&refRID=90FM3FHTQHYWYSJAPKZ6
cheap ones … although I paid quite a lot less for it from China
I know it’s only time until the arm that secures the light snaps and want to get something before it does.
Can anyone recommend something the lights easy to remove and remount from that’s half decent but doesn’t cost silly money???
I quite like the look of these as I think it’d be really easy to remove / replace the light
https://www.amazon.co.uk/360-ã-Bicycle-Cycle-Flashlight-Holder/dp/B00HHQI28C/ref=cts_sp_1_vtp?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_p=1212178027&pf_rd_r=M8ED13YZ3PPBQ8PX0G22&pd_rd_wg=OCjwK&pf_rd_s=desktop-detail-softlines&pf_rd_t=40701&pd_rd_i=B00HHQI28C&pd_rd_w=o5Rk4&pf_rd_i=desktop-detail-softlines&pd_rd_r=M8ED13YZ3PPBQ8PX0G22&\_encoding=UTF8
But at that money it’d probably only last 5 mins and even if it did last longer can see the band snapping after the 1st winter when it becomes rotten.
I have good experience with this style:
https://m.fasttech.com/products/1251801
Simple and effective. I think it’s probably a copy of the twofish lock block design. I have the twofish one and the one from China and they both work.
Is the Fenix too spendy?
I don’t have it but heard good things.
Fenix
I highly recommend Fenix ALB-10 Bike Flashlight Mount. After you have tried this, you would probably never ever consider a budget mount again
EasyB …. Funnily enough I found that one recommended elsewhere jut after I posted my query … someone even suggested if the velcro’s not great onto the handle bars just use zip ties instead to make it ore stable … at the cost I must admit I’m very tempted.
Flip side of the coin …… I’m also tempted to say it’ll be something I use for years as a regular hobby so the initial cost becomes considerably less when used repeatedly for a number of years and is a semi serious hobby.
I may try the cheap one, see how good it is, if it’s great hang onto it but if it’s just “OK” then put it on the Mrs bike as she very occasionally needs one but not as a regular user.
Thanks for the suggestions from all … very much appreciated!!!
On that velcro mount, I have also added a layer of rubber around the handle bar, like from an inner tube. You still have to tighten the strap pretty good, but this helps keep it from rotating up or down easily.
