browsing for the E01, I found the Mateminco S02
Anyone knows stuff about them? Quad TIR, electronic switch and onboard charging, I especially like the black alu one. But I dread the UI, they can not have used the BLF-A6 firmware for this one..
manker e14 + manker e11
-> TA DA
Awesome :smiley:
I would prefer if mid part was taken from U11 model.
Nice find!
DELETED.
Sorry, someone doesn't want them to be here.
Ooo, is that a USB charging port I see there? If so very interesting & that black model should make a nice EDC…
So you actually have one, freeme? If so, how’s the UI?
I’d be in for the black aluminium version if the UI does not ruin this light.
I hope this model will not be hijacked by Banggood, like happened with the Mateminco E01: since the Astrolux K01 is announced, the Mateminco version has virtually disappeared. It is silly, but I find the Mateminco brand name way cooler!
Is that going to be the new Manker E14 II?
E-switches make a lot of sense for high-drain lights but I’d be surprised if they get anything about a firmware right on their own. Somebody call ToyKeeper.
Agree! Or Tom, I would not mind Narsil on this one :smiley:
DELETED.
I don’t know if my opinions are mainstream, but here’s what I want from an e-switch UI:
  • A short-press from off should turn the light on in a reasonable mode. This could be last-used, a decent medium, or high.
  • A short-press from on should turn it off.
  • There should be a shortcut from off to the lowest mode without turning on in a higher mode first.
  • There should be a shortcut from off to the highest mode if that’s not what’s used for the short-press.
  • If there are blinky modes, it should be very difficult to access them by accident. Things like short-press to change modes with double-click to strobe are incredibly obnoxious.
  • It would be nice to be able to cycle through modes in both directions.
Plus the usual good mode spacing, LVP and such.
Thanks for the info freeme!
That machine-translation sounds like they translated the BLF-A6 user interface for e-switch. That may actually be a nice UI.
I’m certainly in for a GB now. :slight_smile:
Well , if this GB happen I’m pretty sure you will have a Narsil driver coming your way :smiley:
Maybe they did like the Convoy BD series and put a power-cut switch on the side, using clicky firmware?
The stuff about downshift and anti-touch lock doesn’t seem to fit that theory though.
I like the looks of both versions. Looks better than the s41
I’d be in for an aluminum version with an extension tube for an 18650. Ideally, aluminum with copper, Not fond of the stainless steel
Sounds like you are describing Narsil ramping. Maybe could have blinkies a little more difficult to access. Right now if at max, dbl click goes to an intense strobe, but if you don't want strobes at all, they can be disabled in the configuration.
Weird, sounds like some kind of hybrid UI... Some of A6, some Manker style in there with breathing mode, etc. Plus USB charging.
