haikelite MT01 Trekker Test & pictures outdoor
41 posts / 0 new
The backpack on...
The backpack on the road's picture
Last seen: 10 months 4 days ago
Hi friends
This is a-guai , a flashlight-enthusiast and Outdoor-travel enthusiast from china.
I received a MT01 sample sponsored by Haikelite company.
It’s my first time to post here, if i make any mistake, please be kind to correct me.
All my collections are AA , AAA size small light. Personally i dont like big flashlights very much.
MT01 is my first 3×18650 form flashlight, it’s smaller than i thought, very compact size. I like the design and shape.
2200 OTF lumens with 100 minutes constant brightness, this light is really a practical light for outdoor travels or working.
Share some beautiful photos first ;
Specifications from HaikeLite
www.haikelite.top
—Emitter: CREEXHP50 V2 CW / 5000K NW
—Aluminum Alloy body with HAIII Anodize black surface Finish
—Battery: 3×18650 / 18700 in parallel (works on all kinds of 18650 battery, flat-top or button top)
—Aluminum Reflector
— Ultra Clear Double-sided AR coated toughened Glass lens (99%light transmittance)
— IPX8 Waterproof underwater 2 meters
—Max Brightness: CW 2500 Lumens
—Shot distance: 300 meters
—Full Current Regulation; Boost driver ; Real driver efficiency > 93%
— Build-in Anti-reverse protection in flashlight driver. If you put the battery reversely, there is no drain coming through.
— Anti-discharge protection;
—Brightness Level:
Low Low 50lumens 75 hrs
Low 250 Lumens 15 hrs
Middle 850 Lumens 5 hrs
High 2500 Lumens 95 minutes
Strobe: 2500 Lumens
Size: 135mm length x 51mm Head x 45mm body
Weight:280 Gram
UI:
Click on — Click off
Hold switch to change mode
Dolbe click Hidden Stroble
With Last mode momery
Packing is made of some kind of PVC, a light but very solid nice box.
Now open it up. a flashlight ; O rings ; lanyard and a manual
HaikeLite in my hand; My hands are very small as a man , but still very handy to carry it. Anodizing surface finish feels good, not slippy at all in a sweating hand.
Since my hand is small, It’s hard to imagine the real size of MT01.
Now compared MT01 with other 18650 lights side by side.
From left to Right: Olight r50 ; JETBEAM T4pro ; MT01
some 16340 , AAA , AAA size from my collection
Size and Weight
From my measurement , the net weight is 320 gram ; Size: 140mm length ; 53mm head diameter ; 43mm body diameter. Considering the size and weight, it’s not an EDC light , however as i said , it’s a very practical light in work and daily life.
With batteries, it weighs 464 gram
Really like the black finish
Emitter, Lens and Reflector:
MT01 uses the newest CREE XHP50 v2 , i heard it has better light efficiency. The reflector is not SMO , but a Micro orange pill finish. Emitter is well centered, that is nice.
Anti reflector coating Lens also looks clean and nice.
Bezel is flat and made of stainless steel.
Aluminum Reflector size: 46mm diamter and 25mm height, 14.5 gram weight
2mm lens
Take the bezel apart
emitter inside:
There are 2 screws to fasten the DTP MCPCB. The wires seems like #20 or #22, i am not sure, Haikelite have not reply me. Intergrated emitter shelf is nice for heat-cooling.
The emitter
Cooling grease on pcb
Switch:
The switch is electic switch and solid rubber boot. Clicking and changing modes is smooth and convenient. But personally i like metal switch more. The black rubber switch gets ash and dirty easy, you have to clean it.
Cooling fins , 5 cooling fins are thick and deep. MT01 has very nice heat transmission, i can hold the light in a outdoor camping all the time on high mode.
Three logos
I think the “MT01” logo should have been engraved harder.
the landyard hole is big enough to attach the SS claw of the landyard, but i am afraid SS claw will wear out the anodizing surface.
The backcover can be taken off. But you can not put in the batteries from the back.
head and body apart; trapezoidal threads is nice and smooth. 3 threads is a bit less, maybe 4-5 threads is more stable, not sure, but each thread is strong enough.
All threads are anodised.
Disassemble the driver.. nice looking driver
The body from upside. As you can see, the edge of the un-anodizing part is not identical. What? The upside edge is thicker and the downside edge is thinner. the factory should be aware of this.
1 or 2 or 3 pcs of battery can work well due to the boost driver
Beam Shot
My version is CREE XHP50 NW 5000K , The edge of beam has a little bit green. Beam is nice , no pwm, NW tint is kind of yellow.
50 lumens extreme low mode, 1.5 meters from wall
Outdoor 50meters distance
HaikeLite MT01 2200 Lumens
Olight R50 2500 Lumens
Jetbeam T4pro 2580 Lumens
Beam angle
Waterproof test IPX8 (underwater 2 meters, but i have no suitable tool to test it underwater 2 meters, i drop the light to a small fishbowl and let it last 10 minutes)
Turn the light on and off underwater from time to time
Soak the turned-on flashlight into the water for more than half an hour; It works all good, waterproof test passed.
Continue at post #2 and #3
Sorry for the rough and simple review and bad chi-english.
Thanks for reading.
a-guai
I am just a stranger on the road
Edited by: The backpack on... on 06/04/2017 - 09:14
The backpack on...
Sorry for coming back late. I am busy with my job.
Runtime test:
MT01 2200 Lumens —Uncooled condition
Room temprature 26℃,without cooling,Use 3x Sansumg 35E,Voltage 4.185V、4.189V and 4.175V.
turn on 2200 Lumens mode,Beam is 1 meter distance from the luxmeter, Recording the date every 6 seconds, 10 sets of recording date in 1 minute , Total 1900 sets of date, Then i get the full illumination curve.
Below is my self-made box device
As you can see,It starts at 47200LUX from 1 meter, Not until 1089 sets of recording date,the illumination comes to 40 000 Lux. It means the runtime is 108.9 minutes on 2200 lumens mode. All the process is very stable and smooth. Good current regulation performance
2200 lumens , without cooling
On 1090th Set( 109 minute) , the illumination goes down to 39800LUX. On 114.2 minutes, the illumination goes down very fast to 11480LUX. The brightness remains the same from 114 minutes to 133.3 munites.
Then on 133.3 munites the flashlight starts to flash to alert low-voltage. On 170.5 Minute , the flashlight shut down.
Now i took out the batteries , All at 2.87V , nice cut-off voltage
The backpack on...
Conclusion:
Pros:
1. Perfect driver. Brightness on high mode mantains for 100 minutes without step-donw, all functions seems good.
2. Good brightness space
3. good anodization
4. size is compact for a 3×18650 flashlight
Cons:
1. Logo is not in line with the switch
2. Triangular tailcap design makes the tail-standing unstable , especially in wild place.
3. no moonlight mode
4, Beam is green,perhaps all xhp50.2 has this issue.
5, I dont like rubber button switch, occasionally it fails to turn on & off.
I was told they have done some improvements in new MT01 lights.
stephenk
stephenk's picture
Last seen: 51 min 58 sec ago
Thanks for the review. Interested to see some beam shots. How does it handle the heat when running continuously on high mode?
The backpack on...
thank you. I am working on uploading the photos. I used a small fan to cool the light on high mode runtime test. would try to put it in the water to test again.
all tests are ready, except the runtime test on middle low and extreme low mode.
M4D M4X
M4D M4X's picture
Last seen: 1 hour 17 min ago
wow
great first post!
thanks for thr nice pictures Beer
(could you please make them.smaller Wink )
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
The backpack on...
M4D M4X wrote:
wow
great first post!
thanks
sure, what size should i make? 500px or 800px? still have a lot of beam photos
leroycp
Last seen: 5 hours 42 min ago
Nice! I have one on the way. I do like these Haikelite’s. Good pics. Thanks TBO
Gerrit
Last seen: 14 hours 20 min ago
Thanks for the nice review so far, Thumbs Up could you take some pictures outside please. I think I go for the CW version.
Let There Be Light
mrheosuper
Last seen: 1 day 19 hours ago
is it 6V or 12V led, the 12V will make sense because it uses 3*18650
Forgot my pen
The backpack on...
6V xhp50, the 3*18650 are lined in parallel
The backpack on...
Will added some more pictures when i have time. I also ordered a cw xhp50.2 , have not received it.
Gerrit
Thanks backpack, I hope you will get the CW version very soon. Maybe you can do some beam shots between the NW and CW version.
Let There Be Light
Petroleum Lante...
Petroleum Lantern Guy's picture
Last seen: 20 hours 44 min ago
Thanks for the review, just ordered it!
I love all kinds of lights... storm lanterns, kosmos & matador lamps, gas lanterns, tallow lanterns, flashlights, lasers, tritium vials...
stephenk
stephenk's picture
Thanks for the review updates so far, and the effort you’ve put into the review. As well as aforementioned heat handling on high, I’m interested to know the beam profile and angle (light vertical against white wall).
The backpack on...
here it is
stephenk
stephenk's picture
The backpack on the road wrote:
here it is
!http://i.imgur.com/vicM3n0.jpg!
Excellent. Thanks!
bibihang
bibihang's picture
Last seen: 5 days 17 hours ago
Incredible photos! Thank you!
gregor
gregor's picture
Last seen: 12 hours 26 min ago
Very nice, thank you Smile
Wieselflinkpro
Last seen: 43 min 19 sec ago
Can you try a driver mod with resistors?
And can you make some more pics from the driver? Is there a R020 Resistor?
hIKARInoob
hIKARInoob's picture
Last seen: 2 hours 13 min ago
Hey how are you doing? Thank you very much for the fine review. The pictures are really beautiful! I also like the beamshots that show hints of Asian flavour. Smile
longmire
I was thinking about using protected batteries on this one. Do you think I’ll have a problem with this? Since it doesn’t specify otherwise, like on the MT03, I figured I’d be ok.
I couldn’t find any specs to help me, but I doubt I’d be able to interpret them anyway, since I’m a newbie. Smile
sorotantaz
sorotantaz's picture
Nice review..how far the max visible/usable throw?
adirondackdestroyer
Last seen: 1 week 5 days ago
Any update regarding the runtime tests?
firedome
Last seen: 4 days 19 hours ago
Great photos! Thanks!
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
joechina
Last seen: 10 hours 3 min ago
Great first post!
Nice light and I like the packaging!
But for the same price there is the BLF Q8 http://budgetlightforum.com/node/45915
delete
Last seen: 1 month 1 day ago
joechina wrote:
Great first post! Nice light and I like the packaging! But for the same price there is the BLF Q8 http://budgetlightforum.com/node/45915
not problem. i will buy both them Big SmileBig Smile .
adirondackdestroyer
Light looks awesome, and I love my MT03, so I’m a believer in Haikelite, but I’m waiting for the runtime graphs before I jump on this one.
quangtan
Last seen: 9 months 3 weeks ago
I hate Chinese products
The backpack on...
Runtime test updated in Post 2 & 3.
Will upload a video soon.
The backpack on...
I was told haikelite uses metal switch in all their new lights.
What i saw in their official QQ group.
CREE MTG2 with metal button switch, looks good
