SOLD-WTS- S2+ Triple. $60 shipped, PRICE DROP
12 posts / 0 new
BeardedRaleigh
BeardedRaleigh's picture
Last seen: 1 day 2 hours ago
Hey guys, this thing has been sitting awhile and I’m looking to trade it for something new. works flawlessly and is in great shape.
-FET + 7135 Driver – 17mm – MTN-17DDm – New Updated Version – Wires + Spring Option: Complete | Wires + Bypass – FET Firmware: guppydrv
-(3) CREE XP-L High-Intensity V2 1A LEDs on NOCTIGON 3XP MCPCB + PRE-BRIDGED
-10507 Carclo Lens – 3-UP Narrow Spot Optic
-Copper Triple Spacer for Convoy S2+
Small ding and scrape on tail cap, some wear near clip (both seen in pics).
Interested in a bad ass thrower, multi emitter lights, copper lights, 18650-26650 lights preferred but will do others. Tell me what you have worst I can say is no.
here is my build thread. http://budgetlightforum.com/node/49786
Slow is smooth, smooth is fast.
Edited by: BeardedRaleigh on 07/16/2017 - 16:48
BeardedRaleigh
Will throw in 4 Sony VTC3’s. 1600mah IIRC.
Joey Adams
Last seen: 47 min 48 sec ago
What do want for it?
BeardedRaleigh
Not real sure what the going rate is for these, was hoping for cool trade offers.
I would do $80 shipped with 4 VTC3 sonys.
wdkingery
wdkingery's picture
Last seen: 1 week 4 days ago
how’s the UI on that work?
BeardedRaleigh
guppydrv DUAL Clicky Firmware Option
This firmware allows the ultimate in user customizability, with 22 built-in mode groups, that the user can select via a series of button presses and a user programmable turbo timer that will automatically step the power down to 50% after the set time is hit (see below for instructions).
Low voltage protection: With 1S cells (non-zener mod) the light will begin to step down output at around 2.8v under load. The light will not shut completely off, but will continue to run at a moonlight level.
User Selectable Groups:
2% – 25% – 100% | Memory
100% – 25% – 2% | No Memory
2% – 25% – 100% – Strobe – Beacon | Memory
2% – 25% – 100% – Strobe – Beacon | No Memory
15% – 100% | Memory
100% – 15% | No Memory
100% Only
100% – Strobe | No Memory
Strobe – 100% | No Memory
ML – 5% – 33% – 100% | Memory
100% – 33% – 5% – ML | No Memory
ML – 5% – 33% – 100% – Strobe – Beacon | Memory
ML – 5% – 33% – 100% – Strobe – Beacon | No Memory
ML – 100% | No Memory
100% – ML | No Memory
ML – 100% | Memory
ML – 5% – 15% – 50% – 100% | Memory
ML – 5% – 15% – 50% – 100% | No Memory
100% – 50% – 15% – 5% – ML | Memory
100% – 50% – 15% – 5% – ML | No Memory
2% – 15% – 50% – 100% | Memory
2% – 15% – 50% – 100% | No Memory
Guppydrv ​Instructions
To switch mode groups: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch the same number of times as your desired mode group. The light will blink and your mode group will be memorized.
Example: To select mode group 3, tap the switch 8 times quickly to enter programming mode. As soon as the light enters programming mode and beings flashing, tap the switch three times. The light will blink to recognize the mode group change.
To set the turbo timer: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash. With the light in programming mode, tap the switch 30 times to enter the turbo timer set mode. The light will then switch to 100% power. When the light is at the desired temperature for the turbo step down, turn the light off. The turbo timer will then be set. The turbo timer steps the light down to 50% regardless of the mode group set.
wdkingery
wdkingery's picture
yeah i guess i could have googled that; turns out i already have a light that functions this way. just that low mode photo in the other thread got me to wondering.
BeardedRaleigh
$65 shipped until the other light I want sells.
BeardedRaleigh
bump for having good pictures. Cool
BeardedRaleigh
bump, $60 shipped with 4 VTC3’s.
bigshoe83
Last seen: 6 months 6 days ago
PM sent
BeardedRaleigh
SOLD.
