Test/review of Charger Panasonic BQ-CC57
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 10 min ago
DSC_3988
DSC_3989
DSC_3990
Panasonic has a line of NiMH chargers, some are fast and smart, others dumb. This one here is fairly fast smart charger with power bank functionality.
I found this charger on ebay from jp-prime-mk (Japanese dealer).
DSC_3980DSC_3981DSC_3982DSC_3983
I got the charger in a blister pack.
DSC_3984
The pack included the charger and a fairly long instruction sheet. Not the usual multi language one, only Japanese (I assume), with a lot of explanation on.
DSC_3994DSC_3995DSC_3996
The charger has a foldable US plug.
DSC_4535
The charge status indicators are more than just a red/green led, they start from red and slowly changes to green while charging (A bargraph would have been more practical, but not looked as fancy).
DSC_3991DSC_3992
The charger has a usb output, it will work both as power bank and as usb charger. The button must be pushed to turn the usb output on, the green led beside the button will be on when usb power is on.
DSC_3997DSC_3998
DSC_3999
The charger has the typically two level slots used for AA and AAA batteries.
supportedBatteryTypes
supportedBatterySizesDSC_4000DSC_4001
Measurements charger
  • When not powered it will discharge the battery with below 0.01mA
  • If the charger detect an error the red led for that channel will flash fast.
  • Charge will restart charging after power loss, or battery insertion.
  • Power consumption when idle is 0.3 watt
Panasonic%20BQ-CC57%20(eneloop)%20%231
This is not a -dv/dt termination and it is slightly premature, but the one hour top-off charge mostly compensates for that.
The top-off charge adds about 100mAh extra.
Panasonic%20BQ-CC57%20(eneloop)%20%232
Panasonic%20BQ-CC57%20(eneloop)%20%233
Panasonic%20BQ-CC57%20(eneloop)%20%234
Two -dv/dt termination and one that probably is isn’t, but the battery is filled in all cases.
Panasonic%20BQ-CC57%20(eneloopPro)%20%231
Panasonic%20BQ-CC57%20(eneloopXX)%20%231
Panasonic%20BQ-CC57%20(powerex)%20%231
With the 3 high capacity batteries only one has a final temperature raise, i.e. is full, but all are very close to full.
Panasonic%20BQ-CC57%20(eneloopAAA)%20%231
Filled with -dv/dt termination.
Panasonic%20BQ-CC57%20full%20(eneloop)%20%231
The charger is not fast to terminate on a full cell, the speed is what can be expected for a -dv/dt termination.
The top-off charge is not really needed here.
Panasonic%20BQ-CC57%20(4xeneloop)
With four batteries the charger current goes down, but it do terminate correctly.
Temp3077
M1: 46,1°C, M2: 44,4°C, M3: 39,2°C, HS1: 46,4°C
Temp3078
M1: 44,0°C, M2: 45,7°C, M3: 44,5°C, M4: 41,2°C, HS1: 60,9°C
The batteries are about 5°C warmer under the lid, it is probably a good idea to charge with it open.
Poweron
When turned on the charger plays with the lights, before starting to charge, this takes nearly 5 seconds.
Charging34
With 3-4 cells the duty cycle is changed, removing the extra cells will not change the duty cycle again.
It looks like the charger has one 2A charging circuit and will switch it between 2 or 4 channels, depending on number of batteries.
USB output
  • Output turns off after about 100 seconds with below 70mA load.
  • The power bank requires four cells to be activated.
  • Output is coded as Apple 1A
  • Batteries are used in series for usb output.
USB output mains powered
Panasonic%20BQ-CC57%20load%20sweep
The efficiency is not very impressive when used as a usb charger and it can barely supply the 1A current.
Panasonic%20BQ-CC57%20load%20test
Running for one hour with 1A output current is very hard for this charger, the voltage drops significantly, most phones will reduce the charger current with this voltage drop.
Temp3150
M1: 46,7°C, M2: 42,5°C, HS1: 48,5°C
Temp3151
M1: 36,0°C, HS1: 42,3°C
Temp3152
M1: 48,2°C, M2: 45,1°C, HS1: 49,3°C
10ohm
Noise is 10mV rms and 200mVpp
5ohm
Noise is 11mV rms and 207mVpp, the noise is low.
USB output battery powered (Power bank)
Panasonic%20BQ-CC57%20AA%20load%20sweep
On batteries it also has problems with 1A current.
Panasonic%20BQ-CC57%20usb%20out%2010ohm
Panasonic%20BQ-CC57%20usb%20out%205ohm
The 1A output is much better on batteries, than on mains power. Here the voltage stays at about 4.8V until the batteries is empty.
10ohmAA
Noise is 7mV rms and 170mVpp
5ohmAA
Noise is 57mV rms and 330mVpp, at full load there is some noise in the output.
Conclusion
I am not really impressed with this charger. Termination is fairly good, but not perfect, to handle this it supplements with a one hour top-off charge.
The usb output can be used for smaller phones, with only 1A charging it is not going to fast charging anything. The power bank capacity is fairly low, due to the AA batteries (A single 18650 would be just as good), but it is larger than a 4×18650 power bank.
If you really want everything to work on NiMH batteries, this may be the device (It works fine), but getting seperate device may take up less space and work better.
Notes
My website with reviews of many chargers and batteries (More than 1000): http://lygte-info.dk/
MRsDNF
MRsDNF's picture
Last seen: 3 hours 3 min ago
Thanks HKJ.
My current and or voltage measurements are only relevent to anything that I measure.
Budget light hobby proudly sponsored by my Mastercard and unknowingly paid for by a hard working wife.
djozz said "it came with chinese lettering that is chinese to me".
ChibiM
ChibiM's picture
Last seen: 49 min 14 sec ago
Thanks HKJ for the review.
It`s definitely an “emergency product”. Something that can be very useful in Japan with all the natural disasters. I always had a mini solar panel charger in my emergency kit to charge my phone, so this could be something useful for families.(who do not know/want to use lithium batteries)
RollerBoySE
RollerBoySE's picture
Last seen: 1 day 9 hours ago
Thanks for the excellent review!
Just out of curiosity I wonder:
Which, in your opinion, is the better Eneloop charger?
This (I assume it uses the same charging electronics as BQ-CC55) or the BQ-CC16?
