Jetbeam E10R Review
18 posts / 0 new
Bc412
Last seen: 6 months 1 day ago
Jetbeam E10R Review
I purchased the E10R from Gearbest when it was on sale for $16.99. At that price I couldn’t say no. A sub-twenty dollar AA/14500 flashlight with micro USB charging. Take my money! Please! I paid the extra few dollars for upgraded shipping and it arrived 8 days after my order. Pretty amazing for crossing the globe. It arrived with packaging still in great shape.
Where to buy (Affiliate links)
Jetbeam E10R @ Gearbest.com
http://bit.ly/2qCvoX5
Other Jetbeam flashlights:
http://bit.ly/2pWbfie
Manufacturers Specs:
LED: CREE XPL-H1 LED
Output / Runtime:
1x AA battery:
High: 190 lumens/1.1 hours
Medium: 46 lumens/9 hours
Low: 4 lumen/100 hours
1× 14500 battery:
High: 650 lumens /0.5 hours
Beam Intensity: 4100 cd
Throw Distance: 129 m/423.2 ft.
Impact Resistance: 1 meter
Water Resistance: IPX-8 (Submersible to 2 meters for 30 minutes)
Direct recharging function via micro-USB port (NiMH and Li-Ion batteries only)
Multi-LED Battery charging indicator
Remembers last used mode via memory function
High efficiency circuit board provides up to 35 hours runtime on lowest output level
3 unique brightness settings
Powerful defensive strobe mode
Multi-function side switch
Stainless steel pocket clip
Tailstand capable
Titanium ring protects bezel from damage
Toughened ultra-clear mineral glass with anti-reflective coating
Aircraft-grade aluminum body
Anti-scratch type III hard anodized
Compatible with NiMH, Li-Ion, alkaline, and non-rechargeable lithium batteries
Dimensions:
Weight: 1.25 oz/35.4 g
Head Diameter: 0.75”/19.1 mm
Body Diameter: 0.75”/19 mm
Length: 3.85”/97.7 mm
My Youtube Review
Construction
The quality of this light is on par with the Jet-I Jet-II, Jet-U MK. The anno is smooth and surprisingly scratch resistant. The glass is nice and clear, the o-rings arrived in great shape. Threads are decent and came lubed. The light is in 3 pieces. The tail cap has a spring and magnet. The threads are anodized so you can do a physical lockout of the light. The threads are tight so I haven’t had any issues with it loosening or tightening in the pocket while locked out. The light does tailstand well. The magnet is weak and wont hold the light at a 90 degree with a battery inside. It will hang upside down no problem. Looks like it could easily be replaced with a stronger magnet as it looks like the only thing holding it in place is the tail spring. The battery tube section contains the USB charging component. Which is awesome because it separates it from the driver/head in the event that you want to do any modding. Smart Jetbeam! The head end of the battery tube does not have a spring on the inside so it is actually quite picky with batteries. I did get a weird combination of flat top and button tops to work. Flat top Efest IMR14500s worked, but my flat top Sanyo 14500s did not. Same randomness with my button tops. On the outside of the battery tube there is a spring that makes contact with the driver. The USB port is in the thread section of the head so you never have to worry about small rubber boots or covers. The driver appears to be press fit, with no sign of glue. Mine does wiggle slightly when I hit it with tweezers. The light operates with a side e-switch only. Bear this in mind if you are looking to mod the light. There is a very small button on the positive connection to the driver. This mates with the spring from the battery tube. The reflector is smooth and came free of defects. The bezel is said to be titanium, but I could care less. Not a feature that interests me. I was unable to open the bezel. Perhaps it’s glued, perhaps I have small girly hands. The pocket clip is a bit of a horror story. It is a small bent strip of stamped steel that wedges between the tailcap and battery tube. It spin freely even with the tailcap cranked tight. On the reverse side of the pocket clip is a small triangular lanyard loop. This is probably the most uncomfortable thing on earth. Have a kid jump on your lap and your going to have a small thin pointy piece of metal digging into your leg. Being it is opposite of the pocket clip you can not position it away from your leg. Yikes. I don’t foresee myself using the pocket clip now that testing is over! Not so smart JetBeam. Not to mention it is very thin and easily gets caught on fabric couches, seatbelts, etc. There is a small lanyard hole in the tailcap as well so you do have that extra option. Overall the light is mostly done well, with the exception of that awful pocket clip. I should also note that the e-switch is nearly impossible to find in the dark. The light is round and has no way to index the switch. It operates smoothly and haven’t had any issues with it missing mode changes… yet.
Charging
Here is another horror show. When you put in a 14500 it charges at around 4.8v under the load and .85a. So in a perfect world I’m sure it’s a 5v 1a charging component. There is a small led at the head of the battery tube that lets you know when it is charging and complete. The light did actually switch colors, and I checked the 14500 and it was at 3.75V. I put it back in and left it a few more hours and it was still at 3.75v. That’s a pretty massive amount of undercharging going on there. I didn’t even bother to try NIMH because I’m just not ever going to use the charging port based on my results with 14500. I’ve read other reports of undercharging, so it does not appear to be just me.
Performance
Not too shabby. My lumens came in significantly lower than the advertised specs. This could be a calibration issue as I have changed equipment so please take this into consideration. My Utorch ut01 also came in about 50 lumens below advertised so I think I need to work on my calibration. The great part about this light is that it does run full blast with a 14500 and gradually declines in brightness. My assumption is that it goes into direct drive for 14500 use. Your going to get a good 30-35 minutes of usable light with the right battery. My light shut off so there does appear to be working LVP I checked and the battery was at 2.70V after shutoff. It did rebound to around 3.0v so you can definitely go back and squeeze a few more minutes out of it in an emergency situation. The light gets pretty darn hot after about 10 minutes. Not hot enough for me to abandon the runtime test, but I wouldn’t want to be carrying it at that temperature. NIMH gave a very nice regulated 200 lumen output for a little over an hour. Alkalines put out a decent showing… but they are staying at the kid’s table. The light also has a mode memory but you do have to leave it on for a few seconds for it to kick in.
It’s a tough light to compare to other lights because most manufacturers of AA lights that produce over a couple hundred lumen have a step down. So although you get a longer runtime with some of these other lights, you do only get a few minutes of actual turbo. It takes about 30 minutes to get to about 50% of original brightness. So if you like at a light like the olight s1a or s1r you do get a lot more light for tat 30 minutes.
Overall this light puts out like a prom date. I ran this light hard with a 14500 test, nimh, and alkaline test back to back with no cooling. No problems whatsoever. It can take the heat, it can take the extended runtimes. If only they would fix the charging!
+ Beam Shots:+
Parasitic Drain
So I really don’t have a meter accurate enough to give you exact figures. I checked it several times with several batteries and got some wildly different answers. All of my results were in microamps or very low milliamps. The pattern I saw is that there is definitely more drain with NIMH batteries. Either way, it looks like you’re going to get a few months before it drains the battery. Not a big issue at all considering you can lockout the tailcap.
PWM
I’m not seeing it with my eyes. I tried waving the light in front of my hand, and checking in the shower. I’m not seeing it, but I’m also not sensitive to it at all. I’m not seeing it on camera either. This doesn’t mean there isn’t PWM… like I said I’m not sensitive to it at all. Except the Nitenumen NE01. I can see the PWM on that just looking at it. Yeah, I’m weird.
Conclusion:
Although the light has some flaws, it is an absolute homerun for the price. A magnet upgrade and a new pocket clip and I would be in love with this light. I can overlook the problematic USB charging, because I rarely use it on lights to be honest. My cell phone is USB-C so I don’t have normal old USB cords laying around anyway. It performs well, can handle the heat of long runtimes, and has a simple easy interface. Not much beats a 3 mode e-switch flashlight for the simplicity of everyday carry. The tint is cool white, and pleasant to look at. The beam is pretty smooth as well and it has enough throw to make it useful for outdoor activities like hunting, camping.
Improvements I would like to see
Better pocket clip
A flat for the e-switch so it can be located in the dark
Fix that usb charging!
A lower low mode – and I mean moonlight!
If you’re going to have strobe, have a beacon. A small beacon that lights once every 10 seconds would be awesome for camping. I set down and lose flashlights until morning a lot! A moonlight beacon is a beautiful thing for people clutz like me.
Edited by: Bc412 on 05/04/2017 - 23:58
Muto
Last seen: 9 hours 4 min ago
Quote “Overall this light puts out like a prom date.”
Best line ever in a flashlight review, bar none:)
Good review, agree with all facets including hokey clip.
Later,
Keith
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Big Sky Country
Trevi_lux
Trevi_lux's picture
Last seen: 9 months 4 weeks ago
Thanks for the information, I can understand that people can use this with unprotected 14500 batteries? I mean, do you confirm that there is no over-discharge?
Regards
freeme
freeme's picture
Last seen: 1 hour 44 min ago
I got 591lm for high. cool
crz6662
crz6662's picture
Nice review.
Paul321
Paul321's picture
Last seen: 2 weeks 4 days ago
Nice review,
You got your’s at smokin’ good price. I am bummed about the under charging, magnet, clip, switch. The package specifically recommends Ni-MH, yet undercharges!
This light was released too soon
Paul-
Bc412
I did my testing with unprotected efest imr14500 batteries. Towards the end the light dims to about nothing then shuts off. It’s tough to miss because your only putting out about 20-30 lumens the last bit
However, I would never trust a protection circuit enough to leave a light unattended
kramer5150
kramer5150's picture
Nice… NiMH-turbo output actually INCREASES with run time and temperature? How is that happening? Is it drawing more tailcap current through the run?
Looks like a winner and a great deal at that price.
Too bad about the charging though. Not a deal breaker for me, but others are going to need that feature.
Hopefully jetbeam can get the bugs worked out of these.
Bc412
Probably ambient room light. I think I started that test early in the morning. Old house with lots of huge windows…
OMark
OMark's picture
Thanks for the great review, for the price you got it at it sounds like a steal, but too bad about the magnet, under charging, etc. Hopefully the updated version will see some of these fixed.
djozz
djozz's picture
Last seen: 1 hour 11 min ago
Thanks for the nice and honest review.
I have replaced the magnet with a slightly bigger one on mine, this helps a bit, it can be postioned horizontally fine now but nowhere as well as some other lights (the Olight S15 sticks much better.
One minor detail: you mention the lens is nice and clear, I have had the lens of my E10R out and looking at a white surface through the lens shows that it is slightly brownish which even affects the colour temperature of the light output by a few hundred Kelvin. (I have seen that before in many other AR-coated flashlight lenses btw, i.e. EagleTac). I suspect that an uncoated lens would transmit just as well or even a bit better (but does not look as cool).
Abqjohnny
Last seen: 11 months 2 weeks ago
Interesting I followed you on YouTube for a long time and didn’t know until today that you were on BLF. I watch all of your stuff and enjoy your reviews. Keep up the good work.
samgalax
Last seen: 4 hours 55 min ago
Is going to be available an updated version of this flashlight with the issues fixed??
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
Paul321
Paul321's picture
Djozz, what size magnet did you use?
Paul-
blue wood
Last seen: 11 months 3 weeks ago
did a quick test, doesnt seam to be overcharging to me. batt volt = 4.1 charging volt 4.22. using a brand new keeppower cell.
Tinderbox UK
Tinderbox UK's picture
A review i read said it charged an 14500 to 4.19v so maybe not all have problems charging li-ion cells. But they all seem to only charge NiMh to 50% Sad
John.
Maha C9000 – LaCrosse BC-900 – Floureon BT-C3100 V2.2 – Accumanger 10 and 20 -Thunder AC6 LiitoKala Lii-100 – Cozypony 24W Solar Panel – Soshine H4 – Soshine T2 – Soshine E4S
Barkuti
Barkuti's picture
Last seen: 27 min 22 sec ago
Nice, yesterday ordered one of these for a friend. He had a couple of unused TrustFire IMR14500s, nice to see operational lvp logic.
Has anyone inspected the emitter's board? Any emitter swap done? I guess a 219C on 16mm board would rock, at least for the CRI discerning fellows.
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
jahanclix
Last seen: 2 years 5 months ago
Thanks a lot to share a nice review here.. I will go to market tomorrow to have a one pc of this product.
Anne J. Kain
gunscopeguy.com
